Poll: Stock intake with AFE Pro-Dry S Filter or AFE Stage 2 Intake with Pro-Dry S
Discussion in 'Performance and Tuning' started by fkli222, Aug 8, 2012.
What intake route did you do or would you do?
  1. Stock intake with AFE Pro-Dry S Filter
    111 vote(s)
    56.6%
  2. AFE Stage 2 Cold Air Intake with Pro-Dry S Filter
    85 vote(s)
    43.4%
  1. Oct 25, 2012 at 1:50 PM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    drop filters arejust exspensive and kind of a waste of money.
    stock replacement paper filters are best or if you want some extra performance go for the URD intake
  2. Feb 4, 2013 at 7:39 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    I got the aFe, but wish I had saved my money and gotten the Pro Dry.
  3. Mar 3, 2013 at 7:12 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Stock intake + napa gold filter, flow is insane, plus you can't beat paper filtering.
  4. Jul 25, 2013 at 10:03 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Stock, anything else is just a waste of money.
  5. Jul 29, 2013 at 12:50 AM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
  6. Jul 29, 2013 at 8:29 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  7. Jul 29, 2013 at 6:22 PM
    TacomaG26
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    What do you mean by Hot Air? the lid is on and this intake does run into the inner fender so it does pull cool air from there (but it will get warm as it goes through the box/tube as all intakes will)
  8. Jul 29, 2013 at 6:44 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Previous setup
    jba long tubes
    aero turbine 2525 and aero turbine ar25 run to dual
    afe pro dry drop in
    I switched to a stage 2 si afe intake with pro dry filter.
    As soon as i switched i noticed my scangauge was off by a little bit (usually very consistent). I gained approximately 1 mpg. I do not think i gained any power with the intake. It does make a lot of noise in the higher rpm though.
    This past weekend, driving with 285/75r16 duratracs i averaged ~19 mpg driving on the highway at ~70 mph.
    Two weeks ago driving on the stock sized dunlops i averaged ~23 mpg doing the same drive.
    Take this info however you would like. All i know is when i read about mpg's on here, i seem to always be getting a little better than others with similar setups to me. I also have allpro front and rear bumpers, and sliders.
  9. Jul 29, 2013 at 7:38 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I wasn't sure if u put the lid back on..... I've been running this intake for yrs and its a great design.
    And trust me..... I beat the shit out of it..... I've got the exhaust and fender liners coated in rubber still.... Despite scrubbing.
  10. Jul 29, 2013 at 7:53 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    .... Land of performance haters.
    I used to post links to dynosheets proving that these trucks can be improved upon even while n/a. I took a break from that tho.
  11. Jul 29, 2013 at 7:55 PM
    TacomaG26
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    Yea i leave it on with the little 2x4in ish front plug out.
  12. Oct 3, 2013 at 4:32 AM
    USArchangels
    USArchangels Well-Known Member
    Max
    Houston, TX
    '12 TX Pro Baja
    Stock BAJA: bfg ta ko 16's 60mm racing Bilstein & TRD coil springs up front 50mm remote resevior race Bilsteins in back 71/21 mpg MODS: AeroTurbine 2525XL Muffler on all stainless TRD exhaust. Chopped and dumped TRD Tailpipe. Now 90 degrees. Cut just after axle. aFe ProDry S drop-in air filter Secondary (wire mesh) Filter delete Wilson 4ft Flex Silver Load CB antenna Midland 75-822 CB - hardwired Passport Escort 8500x60 & TomTom GPS unit wired to interior fuse panel with add a fuse BAMF antenna mount (front for CB) Relentless Fab antenna mount (tailgate) Fake Bead Lock delete reversed white wall tires All mudflaps delete Predator Tube Step delete TX Baja decal delete debadged Avid bars front and back SnugTop Rebel Rear Diff Breather mod to bed storage compartment STANT locking gas cap with fishing wire. Interior Map lights - Green LED Interior Dome Light - Red LED ConsoleVault
    Already have a catback. Removed charcoal filter & intake mesh screen. Replaced stock filter with aFe.
  13. Nov 26, 2013 at 11:15 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    You've already paid for it so its done no need to keep buying paper filters. I knock the dirt out of mine every oil change and run water through it ever 2-3 oil changes.
