pollishing the golden turd, 1985 4runner
Discussion in 'CBI Off-Road Fab' started by rokbrkr, Feb 7, 2011.
  1. Feb 7, 2011 at 9:25 AM
    rokbrkr
    rokbrkr [OP] Active Member Vendor
    Idaho Falls
    Well I'm not much for typing so I'm going to try and keep this as simple as I can.
    Here is a list of parts that I have gathered from good used deals and bought new from selling my XJ.
    New parts: 4" trail gear front springs
    4" pro comp rear springs (will explain later)
    cheap pro comp shocks
    TG ublot flip kits f/r
    4- Big O 35x12.50x15 AT tires on 15x8 AL, wheels, tires are
    new, mounted on used wheels ($500 for all[​IMG]) not exactly what
    I was looking for, but the price was right and they will work
    good for 80% of the driving this thing will be doing.
    used parts: toy front end with high steer, high pinion 3rd with 5:29 gears,
    limited slip, chromo inner shafts, stock birfs.
    toy ifs rear end with chromo shafts, v6 3rd with 5:29 gears,
    and ARB locker.
    w56 trans mated to dual cases with stock gears
    All pro xmember with E-brake.
    TG hydro assist kit
    IFS steering box
    So I will post this in phases as I get them done.
    Here is a pic of what I started with
    And here it is as of now
    Well that's it for now. I have alot more to post as soon as I get time. Thanks, Steve.
    __________________
    www.cbioffroadfab.com
    www.tacomaterritory.com
  2. Feb 7, 2011 at 12:49 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    :popcorn: Can't wait to see how your Toy turns out.
  3. Feb 7, 2011 at 7:18 PM
    rokbrkr
    Idaho Falls
    Well this isn't in order but, we'll start with the rear axle.
    After building this cool cover for the assembled axle I noticed the spring perches weren't sitting evenly on the axle. After closer inspection I found that the housing was caved in around the spring perch on the passenger side and looked a little bent.
    I disassembled the axle and sure enough, the housing was slightly bent. I got the axle out of a crawler that had been rolled. I assume the axle was bent in the roll over.
    At this point I decided this wasn't going to be as quick and easy as planned, so I decided to slow down and take my time.
    The cover is simply protection and support.
    Since the first housing looked like it bent fairly easy, and I've seen a few of these housing dented from the ubolts. I sleeved the outer part of the housing with 3" .120 wall tube to give it some extra strength from where the housing steps dwon in size to the bearing cup.
    I figured while it was all apart, why not put a truss on it as well.
    All welded up and sanded down.
    Brake lines and driver side shock mount.
    painted and installed on the turd.
    I wanted to keep the shocks in the stock location for now. I mounted them like /\ on my last runner and had lots of body roll when loaded down with camping gear, so I'm going to try this out to start with.
    I'll see if I can't post up some more tomorrow.[​IMG]
    __________________
    www.snakeriveroffroaders.com
    www.duneratt.com
    [​IMG] [​IMG] [​IMG]
  4. Feb 7, 2011 at 7:27 PM
    747 function > form
    1st Gen.
    sub'd. :popcorn:
  5. Feb 7, 2011 at 7:27 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Those old 4Runner's are classic.
    I can't believe how clean it looks, only a few dings and faded paint!
  6. Feb 9, 2011 at 7:16 PM
    rokbrkr
    Idaho Falls
    And lots and lots of miles :D unfortunately it looks better in pics than in person ;)
  7. Feb 9, 2011 at 7:17 PM
    rokbrkr
    Idaho Falls
    So onto the pro comp rear springs. I chose these for ease in mounting since I am pressed for time on working on this thing. I only have weekends, so I can drive it during the week.
    I have talked with a few people in the past about these and they have said they work pretty good for awhile anyway.
    I mounted them up right out of the box to begin with, overload and all.
    Wow, what a stiff ride[​IMG]. So while I had the axle out I took the overloads out
    and cut two leaves out of the old stock pack and added them to this pack along with the short leaf that was in the front TG springs that I took out when I installed them for fear the front was going to be too tall.
    I was a little concerned that this would let the rear sag abit, so I cut down the overload leaf to work as block and attached it with the center bolt.
    This set up rides alot better! I'm sure once I get the rear bumper with swing away done and all the crap I carry with me it will ride like a cadilac[​IMG]
  8. Feb 9, 2011 at 7:34 PM
    Sandhopper
    Sandhopper Well-Known Member
    I so hated peeling off those stickers on my 85' pick-up... Loved the truck, hated those stickers! Looks like a great project. The 22RE was bullet proof.
  9. Feb 9, 2011 at 7:37 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    apparently you can buy the diesel 4 cylinder for those :cool:, as for the runner itself, they are bad ass with the factory suspension!
  10. Feb 9, 2011 at 7:39 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  11. Feb 9, 2011 at 8:10 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Nice stuff! What robot is doing you welds!!! :D
  12. Feb 9, 2011 at 9:19 PM
    musty40
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Well compared to what one might find here in Minnesota.
  13. Feb 9, 2011 at 9:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    ^^^ x2 Incredible welds!
  14. Feb 21, 2011 at 6:11 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Can't wait to see the rest and as everyone else has said nice weldin man
  15. Feb 21, 2011 at 6:20 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Those 85 toyotas are sweet, last year of straight axle and first year fuel injection, dam I want one!
  16. Feb 22, 2011 at 6:46 PM
    Jason'sLawnCare
    Any recent updates?
  17. Feb 22, 2011 at 10:20 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Looks great Steve! Can't wait to see it in person and finish my rear bumper since I now see where Toyota got the idea for that color. You will see what I mean when you see my bumper. Lol.
  18. Mar 1, 2011 at 6:12 AM
    rokbrkr
    Idaho Falls
    Thanks guys!
    No updates yet, I would like to work on the rear interior panels this weekend, we'll see how it goes.
  19. Mar 1, 2011 at 6:15 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    The welds are perfect...Wow.
  20. Mar 1, 2011 at 6:41 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    good start so far! Love the old runners
