Poltergeist Air flow controls changing by themselves?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LITacoQ, Aug 23, 2019.
  1. Aug 23, 2019 at 3:38 PM
    LITacoQ
    LITacoQ [OP] Well-Known Member
    East Coast
    2003 SR5 Access Cab 2.7 5 speed lunar mist
    Hello all, having a weird issue with my 03 Taco. As I am driving, it sounds like the air flow controls are changing from the "foot" setting, to "head/foot" setting, to "head" setting, to "defrost" setting and so on by themselves. The fan is not even on, but the settings seem to be flip flopping, then will stop on their own and then start again.
    Any info would be great and thanks in advance
  2. Aug 24, 2019 at 6:31 AM
    TacomanTurd
    TacomanTurd Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Lol, I thought that shit only happens in German cars.
    May be a broken spring
  3. Aug 24, 2019 at 9:00 AM
    Glamisman
    Glamisman Well-Known Member
    Hope this helps. I am thinking that if you see this actually cycling when it shouldnt... I will read that protion of the manual and see if I can save you some time/steps and get back to you.
    Unfortunatly the FSM does not give a "this happens when you do that" breakdown of the climate control system. As I think about it it seems that if the control for defrost to foot heat checks out ok then the only other thing would be the amplifier. This might be one of those times where everything else checks out and you just have to put a part in it to test the system.
    LITacoQ[OP] likes this.
  4. Aug 24, 2019 at 9:59 AM
    LITacoQ
    East Coast
    Thank you so much. Unfortunately I will not be able to work on my truck for the next couple because of family I have visiting. You gave me a couple great attachments that will get me started. Really appreciate the info. :thumbsup:
