Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Sep 17, 2015 at 6:41 AM
    #201
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    I know I was just being facetious haha :D
    Crom[QUOTED] and 12TRDTacoma[OP] like this.
  2. Sep 17, 2015 at 6:43 AM
    #202
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I like how the title of this thread is Polyurethane Cab Mounts, but is more about the Radiator bushings. lol Thanks for the heads up. I've put it on my list of things to do when the time comes. I have a 2014, so not quite ready to replace mine.
    12TRDTacoma[OP] likes this.
  3. Sep 17, 2015 at 6:46 AM
    #203
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    People have been installing it without the internal metal sleeve? Geez. I show people how to do the thing on here and they somehow feel compelled to attempt to reinvent the wheel for this install. Lol.
    Revelations likes this.
  4. Sep 17, 2015 at 8:10 AM
    #204
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This is a good point. The thread has evolved
    @12TRDTacoma - If you wanted to you can alter the thread title without a moderator's help. Just edit the first post in the thread and save.
  5. Sep 17, 2015 at 8:13 AM
    #205
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Thank's Roberto I just ordered mine now just need to find out how to relocate this heavy ass battery.
  6. Sep 17, 2015 at 9:46 AM
    #206
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I'm having a hard time identifying if my cab mounts are shot. They're obviously rusty, but how does the rubber bushing look to you guys? I've never replaced bushings like this before so any advice you guys can give would be appreciated.
    Rears:
    Fronts Top:
    Fronts Bottom:
  7. Sep 17, 2015 at 12:43 PM
    #207
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Age, miles and elements have a lot to do with their shape. Definitely yours have been weathered by the elements.
    Mine had ~120k miles on them and were showing cracks. A picture should be in this thread.
  8. Sep 17, 2015 at 12:48 PM
    #208
    MostEpic
    MostEpic IG: letthemeatdust
    Los Angeles
    2013 PreRunner DCSB
    Party in the front Party in the rear
  9. Sep 17, 2015 at 1:04 PM
    #209
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Thanks for this thread, just ordered mine in red from Amazon as well.
  10. Sep 19, 2015 at 3:55 PM
    #210
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    Done, lots of clicks an noises when jacking up on the radiator mount to fit big bushing on top!!
    And the old ones!!
    Torspd, Crom and 12TRDTacoma[OP] like this.
  11. Sep 19, 2015 at 3:59 PM
    #211
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah you tend to hear a lot of clicking and popping when you are pry up or jacking up the support. I hate those sounds. Glad you got it done though!
    DaveEli likes this.
  12. Sep 21, 2015 at 8:32 AM
    #212
    PS78
    Rancher
    2011 DCSB TRD OR
    once i took the OEM bushings out i noticed on the bottom of the radiator bushing mounts there is a part that is stamped out towards the ground, would that metal just compress into the new poly bushings and cut and stop at a certain point? its just on top of the small bushing in my photo. OP you would probably know best what I'm referring to if you took yours out and flipped the big bushing from the bottom to the top was the big bushing cut or compressed into the shape of the stamped out metal?
  13. Sep 21, 2015 at 8:41 AM
    #213
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I know exactly what you are talking about. The metal is not sharp, its just essentially dimpled upwards if you are starring into the design from the frame upwards (as if you are laying down and looking up at the truck) I noticed the dimpling myself but upon install of it, this polyurethane material is so durable that the only thing that dimpling would do is just leave an imprint mark on the bushings, thats it. There is definitely more than enough material on the "upper" bushing to absorb and be able to handle that with ease.
    PS78[QUOTED] likes this.
  14. Sep 21, 2015 at 8:43 AM
    #214
    PS78
    Rancher
    2011 DCSB TRD OR
    only reason i was curious is because i put the thinner bushing on the bottom which has the dimple pressing into the thin bushing. Thanks for the info!! so far so good.
  15. Sep 21, 2015 at 8:48 AM
    #215
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Either way will be fine. I studied the dimpling and the best plan of attack for it, but ultimately concluded that since the bushings are much more sturdy in design they will not have an effect regardless of the way they mount on the frame and body when they are installed.
  16. Sep 21, 2015 at 8:36 PM
    #216
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Got mine installed (big bushing on top) this weekend, but I think I might have to flip them. With the big bushing on top, my hood appears to be 1/4-1/2" higher than the fenders, at the front. Not sure if the core support is too high due to the big bushing being on top, but it only takes 20 minutes, so Im going to flip it and see if it looks better.
  17. Sep 22, 2015 at 5:04 AM
    #217
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Did you use the washer and bushing?
  18. Sep 22, 2015 at 5:25 AM
    #218
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Yeah, I used a washer above the top bushing and below the bottom bushing.
  19. Sep 23, 2015 at 12:31 AM
    #219
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The reason the hood sits higher is because you raised the core support with the bushings and essentially are making the hood sit higher then it does from the factory. Fiberglass fenders have much more leeway when it comes to hiding gaps than the stock metal fenders so it doesn't surprise me you have gaps due to the install. As Badbrains suggested, remove the thick washer and see if it helps.
    RacecarGuy[QUOTED] likes this.
  20. Sep 23, 2015 at 12:45 PM
    #220
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Ordered mine yesterday, looks like yet another thing to add to my ongoing list... Gota love long travel....
    dcvt16 likes this.
