Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Dec 21, 2015 at 1:54 PM
    #381
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  2. Dec 21, 2015 at 1:54 PM
    #382
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Dec 21, 2015 at 2:13 PM
    #383
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^This is much better imo :)
    SLCYota likes this.
  4. Dec 21, 2015 at 2:15 PM
    #384
    SconnieHailer
    Marc
    True. But that's a lot of fab work. For the majority of us peasant off roaders the mount tor posted will get us by :)
    Torspd and 12TRDTacoma[OP] like this.
  5. Dec 21, 2015 at 2:17 PM
    #385
    VolcomTacoma
    Jeff
    NorCal
    True. Back to work, peasants. :rofl:
    Torspd likes this.
  6. Dec 21, 2015 at 2:39 PM
    #386
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    No problem bud. Glad I could be of service and help to the community! :)
    They are both the same thing. They both use the upper coil bucket assembly to tie in the bars, except the one Jeff shows has two bars running across so it mounts up in two different sections using different kinds of gusseting to tie it all together.
    Really though, the only difference between the two is that one uses the TC dual shock hoop which has a dimpled gusset additionally built which is tied into the coil bucket assembly and secondary shock inner tab for additional flex support.
    Jeff, I still really don't think the dual crossmember bar design will work for your setup because of the blower. The two outlets on the side cause interference, as well as the air pump assembly on the other side of the engine. That was a huge issue when it we were trying to design my crossmember bar remember?
  7. Dec 21, 2015 at 2:48 PM
    #387
    VolcomTacoma
    Jeff
    NorCal
    Yep, but I think something like yours plus one that runs behind the blower and some connecting tubes would be a boatload stronger. Also, my fab guy thinks instead of tubing he can run some boxed plate over the top to clear the SC. My limited grasp of geometry tells me that the way yours is designed just doesn't lead towards as much strength as possible during a hard hit.
  8. Dec 21, 2015 at 2:52 PM
    #388
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That was my concern as well, but upon talking to him he mentioned that all it's there for is to prevent distortion during an attempt at flexing the frame and as long as something is there (and it's not sideways) it will always help. He does this stuff on the regular so I trust his judgement enough to feel at ease in my mind.
  9. Dec 21, 2015 at 3:07 PM
    #389
    VolcomTacoma
    Jeff
    NorCal
    Ok. Well, I'm gonna make sure all of my stuff is over engineered to the extreme lol. Would rather that than twist a frame because someone 'does it all the time'. In my personal opinion, I would have asked Anthony to at least throw another tube along the back wall and connect the two around the SC. Even if its all bolt in stuff, the tubes going around the SC and connecting would provide much more support. Remember, you're the customer, if you don't think something looks right, even of the 'experts' say its fine, you should always question everything and strive for the best. Now, don't get me wrong, Anthony does great work, and that engine thing on yours looks pretty beefy, but the fact that its at sich an angle basically running along your radiator just doesnt seem right to me.
    But we'll see!
    We both know you're gonna test it out as much as possible :rofl:
  10. Dec 21, 2015 at 3:40 PM
    #390
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lmao. Right? I would had definitely preferred a secondary as well, hell, who is tho say that I can't have him add on one running to alongside the rear at some point, but I agree, I would had liked to have had two on there instead of just one. You bet your ass off I am going to test it out as much as possible!
  11. Dec 21, 2015 at 5:29 PM
    #391
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    WWSSTD?
  12. Dec 21, 2015 at 5:33 PM
    #392
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Righttttttttt…. ^^^
  13. Dec 21, 2015 at 9:45 PM
    #393
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Just ordered a set.
    650H1 and Crom like this.
  14. Dec 21, 2015 at 10:55 PM
    #394
    NotRed
    NotRed Well-Known Member
    So, I can't help but wonder about the radiator bushings; the way they seem to get all mashed up, is it because they are kind of a "sacrificial" part? I mean that they're getting warped because stuff is flexing and taking them out. If they are replaced with something much more rigid, is something going to crack or break later instead now that there is no "give" in the mounting system? Me thinks it better to replace rubber bushings than a cracked radiator or have to weld up sheet metal that was tweaked until it broke.
    Your thoughts please?
  15. Dec 22, 2015 at 5:44 AM
    #395
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    So is the general consensus small or big bushings on top?
  16. Dec 22, 2015 at 5:52 AM
    #396
    DrFunker
    DrFunker Well-Known Member
    I did the small on top.
  17. Dec 22, 2015 at 5:54 AM
    #397
    VolcomTacoma
    Jeff
    NorCal
    So, heres my thinking, if its designed to have the small bushing on top, wouldn't putting the large bushing on top be a form of a body lift, but if you only do it on the front end youd be causing stress on the body between the front end and the cab? Or am I missing something.
    Blacktacoma23 likes this.
  18. Dec 22, 2015 at 6:01 AM
    #398
    VolcomTacoma
    Jeff
    NorCal
    Ooooook, that made sense in my head and I wanted to make sure there wasn't any outside information I was missing. So putting the large bushing on top of a new truck is just asking for the body to tweak.
  19. Dec 22, 2015 at 6:02 AM
    #399
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    That's why the washer was left out.
  20. Dec 22, 2015 at 6:08 AM
    #400
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Had a clunk up front that was noticed when entering and exiting a steep driveway turning left or right (@2000kms) . Toyota said cab mounts were loose so they torqued them. Fine for another 10000kms, Toyota tightened them up again and now its back.
    Could my mounds be damaged?
