Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Dec 30, 2015 at 7:48 AM
    #421
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Looks like I'll be switching them out this afternoon... Thanks Roberto.
    12TRDTacoma[OP] likes this.
  2. Dec 30, 2015 at 8:11 AM
    #422
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    I just wedged a big pry bar in and lifted the radiator core
  3. Dec 30, 2015 at 8:35 AM
    #423
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    what are you guys torquing these to?
  4. Dec 30, 2015 at 8:43 AM
    #424
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Thanks for the heads up.
  5. Dec 30, 2015 at 9:30 AM
    #425
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Remove the bolts from both sides to allow for the most movement, from there take a big prybar and wedge it between the frame and the radiator support crossbar. I had to pry pretty hard, but eventually I was able to get them in. You may possibly remove some paint in the process, so have some touch up ready if that sort of thing bothers you.
    All done.
    No problem :thumbsup:
    Jay's reply is spot on. :)
    Doesn't really matter, just make sure it's nice and tight. I used my 18V cordless impact to tighten them. The thing torques up to 118 ft. lbs. just to give you an idea.
    No problem! :thumbsup:
  6. Dec 30, 2015 at 9:39 AM
    #426
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    @12TRDTacoma Rather than prying between the frame and the support, is this method recommended after removing both bolts?
  7. Dec 30, 2015 at 9:42 AM
    #427
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You can do that too. If you put the bottlejack between your wheel and fenderwheel and lift after removing both of the bolts that should allow you enough to lift the support up and slide the bushings in as well. The prybar was just the quickest and easiest method for me at the time because I don't have a floorjack available when I work on the truck here at home.
    EDDO[QUOTED] likes this.
  8. Dec 30, 2015 at 9:51 AM
    #428
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    german spec
  9. Dec 30, 2015 at 9:59 AM
    #429
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's right Jay @tyfoon11 ... Guttentight
    :D
    DrFunker likes this.
  10. Dec 30, 2015 at 12:06 PM
    #430
    DrFunker
    DrFunker Well-Known Member
  11. Dec 30, 2015 at 12:07 PM
    #431
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
  12. Dec 30, 2015 at 3:08 PM
    #432
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I tried the install today. Removed both bolts but could not get the support to move.
    Having done DIY work on my vehicles for over 40 years I am not even feeling like using a pry bar on folded sheet metal. May try the floor jack next time.
    I did do a brake flush later so didn't feel too bad at the failure.
  13. Dec 30, 2015 at 6:18 PM
    #433
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I just ordered 8.4109 and 9.4101, I ordered direct and they didn't have the G at the end.
    Can't wait to do them all!
  14. Dec 30, 2015 at 6:43 PM
    #434
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you want to do them and want some help you are always welcome to swing on by my "crib" so we can install them. Lol. It'sthe least I can do for you after helping me out with the battery relocate wiring man. :)
  15. Dec 31, 2015 at 9:44 PM
    #435
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Roberto - Got the bushings installed today with expert guidance from @tyfoon11 . Thick on top with washer. Floor jack with a chunk of unistrut for lifting the radiator support worked like a champ. Thanks for starting this thread.
  16. Jan 1, 2016 at 12:09 AM
    #436
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There's more than one way to skin a cat right?! I'm glad it worked out for you Jay. Great job. I'm just here to help. :)
    simplehuman likes this.
  17. Jan 1, 2016 at 6:44 PM
    #437
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Couple of observations post installation.
    1. Truck feels way more solid going down the road and the pothole shudder in the cab is gone.
    2. Steering feels like there is less play in it, perhaps placebo effect?
    3. Before this the truck was level, taco lean having been corrected through coilover adjustment. Now it is 1/4" higher on the driver side. That is easily corrected by installing my fat ass in the drivers seat.
    Excellent result.
    tyfoon11, DrFunker, DoorDing and 2 others like this.
  18. Jan 1, 2016 at 7:13 PM
    #438
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Attaboy fat ass. :D
    In retrospect it is always better to install these before you adjust the coilovers. By the time you adjust them with the bushings in you will have no issues. Of course you could always do what I did from the get go and just adjust each side the same, so by the time you throw on the bushings you will not have a "reverse Taco Lean" going on.
    I'm glad you like them man!
    DrFunker and EDDO[QUOTED] like this.
  19. Jan 2, 2016 at 3:39 PM
    #439
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Switched mine around today. When went to remove the thinner one from the top, was slightly loose. It didn't go in that way, but glad I swapped it.
  20. Jan 3, 2016 at 2:31 PM
    #440
    samiam
    Sam
    Stinky Vegas
    It was more work than I was looking for on a Sunday afternoon, but I got them swapped.
    Large on top.
    DrFunker, Crom and 12TRDTacoma[OP] like this.
