Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Jul 9, 2015 at 12:15 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My truck began life as a 4x4. Not an XRunner.
  2. Jul 25, 2015 at 5:20 PM
    #42
    CardiacTK
    CardiacTK TK3867
    AZ
    15 4x4-Sport DCSB V6
    Slide window bar,LED map&3rd brake-light, UHMW gas tank skid, OR-Fab cat theft skid, 883/5100 on 4-corners (level) Toytec 1/4" Taco lean spacer, Avid rock-sliders, TRD smoked headlights, 31.5 bar from CaliRaisedLED w/ stealth mounts from Apex Fabworks
    Replaced stock radiator bushings on my 15 sport this morning, it took about an hour... Must say these stock OEM radiator bushings suck, rubber so thin you can tear with ease. Thanks goes out to Roberto 12TRDTacoma for show/tell these polyurethane radiator bushings.
    12TRDTacoma[OP] likes this.
  3. Aug 12, 2015 at 4:57 PM
    #43
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
  4. Aug 12, 2015 at 7:14 PM
    #44
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  5. Aug 13, 2015 at 3:48 AM
    #45
    DrFunker
    DrFunker Well-Known Member
    :rolleyes: How are these holding up, for anyone that has placed them in? Living up to expectations?
  6. Aug 13, 2015 at 4:33 AM
    #46
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    sub a dub. Adding it to the list of possible stuff to replace as maintenance stuff. Getting three u joints tomorrow, then most likely inner/outer tie rods and upper/lower ball joints within the next few weeks. May as well add these to the list. Are the install instructions pretty good? I've never put these in.
  7. Aug 13, 2015 at 7:30 AM
    #47
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    Thanks for the link also. Just ordered a set myself. Don't really plan on doing a lot of off road wheeling but also don't like the crappy OEM rubber.
  8. Aug 22, 2015 at 2:55 PM
    #48
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    12TRDTacoma[OP] and Crom like this.
  9. Aug 22, 2015 at 3:20 PM
    #49
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Do the core support bushings mess with the cab to fender alignment?
  10. Aug 22, 2015 at 3:23 PM
    #50
    DrFunker
    Did you put the thick one on the top?
  11. Aug 22, 2015 at 4:13 PM
    #51
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I did put the thicker one on top. I may flip it back though. My core support is in pretty bad shape. I have fixed the cracks but it isn't very square anymore. Probably gonna take a body shop to fix it but i imagine i'll cage my front before that happens :)
    It did on mine by putting the thicker one on top. But I have fiberglass fenders and can easily fix it when I get around to it...if I ever do. It doesnt bug me all that much.
  12. Aug 22, 2015 at 6:42 PM
    #52
    1stDueL22
    Just got mine in. Do you have to do any jacking of the rad support to fit the top bushing in? Or is there space already left once the old rubber is removed?
  13. Aug 22, 2015 at 7:24 PM
    #53
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Yup used my floor jack and about 2 feet of 4x4 to lift it up to get enough room to slide the thick one on top. If you put the thinner one on top it should probably just slide in with just a crow bar lifting it a bit.
  14. Aug 22, 2015 at 9:07 PM
    #54
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Ordered.
  15. Aug 22, 2015 at 9:11 PM
    #55
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Mine came today.
  16. Aug 24, 2015 at 8:41 AM
    #56
    Crom
    Nick
    San Diego, CA
    Millions
    Alright fellas, my ES radiator bushings are coming today and I want to install them tonight. I've got the stock factory bumper cover on my truck. What instructions do I follow to get these in? Is there an install writeup written yet? Instructions? Factory torque values?
    I can go dig in the FSM, but would rather not, if I don't have to.
    Thanks in advance of any help.
  17. Aug 24, 2015 at 8:54 AM
    #57
    DrFunker
    No install included with these. You are flying blind really. :D
    No need to yank the front bumper off, it is all pretty accessible under there.
    I think the nuts are 9/16", don't quote me on that.
    One socket and one box worked for me. Oh, and a pair of pliers to yank the old ones out.
    The bottom factory bushing is easy, the top one takes a bit more muscling.
    I would suggest (haven't done it yet, I plan to do this later today to see if it helps with the creaking.) maybe smearing a little lithium grease where the poly touches metal.
    I put the small bushing on top and the big bushing on the bottom.
    Good luck.
    edit: Crom, are you doing radiator and cab?
  18. Aug 24, 2015 at 10:03 AM
    #58
    Crom
    Nick
    San Diego, CA
    Millions
    just the radiator ones for now. thanks for the comments.
    DrFunker likes this.
  19. Aug 24, 2015 at 11:30 AM
    #59
    DrFunker
    Lithium grease did the trick. :thumbsup:
    Think the noise was coming from where the two sleeves rub. It is pretty tight there.
    Crom likes this.
  20. Aug 24, 2015 at 5:43 PM
    #60
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    Tag for latter
