Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Apr 6, 2016 at 4:58 PM
    #581
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Please elaborate?
  2. Apr 6, 2016 at 5:01 PM
    #582
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    On what? The cracks or flat belly?
    Regarding the Flat Belly: I think it would best to track down the current owner of Kevins truck. Kevin was the founder of ArmorTech. I tried to get his contact info from 4xInnovation Owner but he wouldn't/didn't have his number.
  3. Apr 6, 2016 at 6:12 PM
    #583
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Cut the stock crossmember out and notch a rectangle tube with a few holes drilled in it and sammich it to the frame, raises the GC around 3". You'd need to be a prerunner or have a clocked transfer case to get er done
    MTopp and Crom like this.
  4. Apr 6, 2016 at 6:30 PM
    #584
    HBMurphy
    Paul
    So California Coast
    None
    I have to take you out to lunch. :) When will the tomatoes be ripe? ;) Looks great!!! I would like to talk with you though. :)
  5. Apr 6, 2016 at 6:44 PM
    #585
    Stevenwr
    Stevenwr Member
    2005 Tacoma SR5 Double cab long box
    Sorry if this is a dumb question but...for me to replace the rad support bushings do I have to remove the 4 nuts on the cab mount bolts?
    Also does changing the front sway bar bushings to poly make a big difference?
  6. Apr 6, 2016 at 8:40 PM
    #586
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Cab mounts? No you don't even have to touch them honestly.
    Changing the sway bar bushings to poly should make a difference. I don't have one anymore so I cannot confirm. It usually does though.
  7. Apr 6, 2016 at 8:41 PM
    #587
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Unless you're changing all 6 bushings, then yeah, remove the cab mounts as well :D
    12TRDTacoma[OP] likes this.
  8. Apr 6, 2016 at 8:42 PM
    #588
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Exacrryy!!! :thumbsup:
  9. Apr 6, 2016 at 9:02 PM
    #589
    Stevenwr
    Stevenwr Member
    Thanks for the info. I suppose if I'm going to replace the rad support bushings I should also replace the 4 cab bushings also.
  10. Apr 7, 2016 at 5:02 AM
    #590
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Replacing the cab bushings made a big difference in the ride quality in my truck.
    I went with Energy Suspension master bushing kit.
  11. Apr 7, 2016 at 7:02 AM
    #591
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Got a how to?
  12. Apr 7, 2016 at 5:56 PM
    #592
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Lol i tried to change mine, but I couldn't get the bolts loose. I need a air powered socket wrench
  13. Apr 7, 2016 at 5:59 PM
    #593
    VolcomTacoma
    Jeff
    NorCal
    Pretty sure you just unbolt from under the truck at the cab mounts, probably do all 4 at the same time, and just jack one side of the truck up at a time, just like you do the front bushings?
  14. Apr 7, 2016 at 6:15 PM
    #594
    MTopp
    05 SR5 4x4
    You gotta undo all 4 bolts that are in the cab and then the two bolts that hold each individual body mount in. The two bolts at each body mount were way too tight for me to remove unfortunately.
  15. Apr 7, 2016 at 6:18 PM
    #595
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Impact tools bro. I only speak in impactology. Youknowwhatimsayin'?!
  16. Apr 7, 2016 at 6:23 PM
    #596
    VolcomTacoma
    Jeff
    NorCal
    Despite you saying that, we can still be friends.
  17. Apr 7, 2016 at 6:23 PM
    #597
    MTopp
    05 SR5 4x4
    I used my impact on the in cab ones, but the ones on the frame are inaccessible by my impact. I need the air socket wrench one. I'll buy one eventually.
    #impacttools4lyfe
  18. Apr 7, 2016 at 6:45 PM
    #598
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't worry. There's more where that comes from. We were going to be friends anyways. That's just the way life works.
    Shit. You are right. They are indeed inaccessible. They are in weird spots under the frame.
    MTopp[QUOTED] likes this.
  19. Apr 7, 2016 at 6:49 PM
    #599
    VolcomTacoma
    Jeff
    NorCal
    FML.
    We need to have a mod day again in June. Once the truck gets back I need to install all my electronics and random bushings/mounts and such all over the truck. Then we're going over to Prairie City for a fun day trip. Maybe the Rangers will let us jump for a bit.
  20. Apr 7, 2016 at 6:53 PM
    #600
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Loosen the cab bolts first then jack the body up a bit and you will be able to get to the smaller bolts
