Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. May 14, 2016 at 6:52 PM
    #861
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    On mine, I started tightening the nuts and they seemed to go on farther than they i thought they should so I stopped. I wanted some advice before I continued on.
  2. May 14, 2016 at 6:54 PM
    #862
    DaveEli
    David
    Virginia Beach
    I'll do that in the morning, and see what happens. Is there a torque value?
  3. May 14, 2016 at 7:11 PM
    #863
    Pigpen
    Dan
    Northwest Montana
    I find this odd. My hood actually sits tighter after installing these fat side up. It's a pain in the arse to open now.
  4. May 14, 2016 at 7:36 PM
    #864
    Pigpen
    Dan
    Northwest Montana
    Interesting. I hadn't noticed any increase in the side gaps, I can barely get the tips of my little boy-size fingers in above the headlights to pop the hood.
  5. May 14, 2016 at 8:02 PM
    #865
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Shit. I saw the value in somebody's build once. I think it was @ckeene9 who had it written down somewhere.
    I tighten mine down, but one side loosened up four months later, on a 5-day, 250 mile crazy adventure off-road in Death Valley. I re-torqued them good and used a paint pen to mark /index them and check them when refueling. Haven't budged since.
    Make sure your threads, and bolt / nut face are dry and clean when reassembling.
    DaveEli[QUOTED] likes this.
  6. May 14, 2016 at 8:09 PM
    #866
    DaveEli
    David
    Virginia Beach
    Thanks, I'll crank em down tomorrow and torque paint em and keep an eye out.
  7. May 14, 2016 at 10:57 PM
    #867
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Well shit guys, I just tightened mine til tight. It works. Lol.
    DaveEli likes this.
  8. May 14, 2016 at 11:05 PM
    #868
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    wish I could install mine :pout:
  9. May 15, 2016 at 8:08 AM
    #869
    DaveEli
    David
    Virginia Beach
    You are right. Two more turns and it's perfect. Still like to know a torque setting.
  10. May 17, 2016 at 4:37 PM
    #870
    Pigpen
    Dan
    Northwest Montana
    Okay....
    I'm in the middle of my body mount bushing install and at least one of the bolts (p side rear) is seized to the bushing. Anybody else run into this? I worked the bolt back and forth with the impact driver while I had the body lifted on my floor jack with a piece of wood, but it didn't budge. I hit the bolt with a hammer - nothing. putting the jack under the bolt just lifted the cab too. I'm going to work on the D side while I wait for replies and suggestions. The front bolt just slid out without a problem, but I can't lift the cab with the back one seized. It's free of the tabs on the little bracket in the cab, so that's not it. That bolt is a PITA to access - I had to remove the plastic cubby under the seats to get to it - access cab problems.
    Thanks in advance.
  11. May 17, 2016 at 5:38 PM
    #871
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Spray some penetrating lubricant around the bolt head up top, it will work its way inside then slowly drip down, once you see it drip down from the bottom of the bolt's stud, then give it hell with the hammer til it comes free.
    Pigpen[QUOTED] likes this.
  12. May 17, 2016 at 5:47 PM
    #872
    Pigpen
    Dan
    Northwest Montana
    As it turns out, my PB blaster is in my storage unit - only a few minute drive away, but the entire truck is spread out across the yard. One problem at a time...
    I had to dismantle my dog platform/ storage box (and remove its contents) just to access the brackets covering the problem bolt heads. One problem at a time...
    I might have to let the penetrating oil sit overnight at this rate, not a bad thing, I guess. Back to clearing the piles of crap I keep in the truck. One problem at a time...
  13. May 17, 2016 at 6:06 PM
    #873
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Serenity now eh? :D
  14. May 17, 2016 at 8:16 PM
    #874
    Pigpen
    Dan
    Northwest Montana
    a little lube and some patience. Well, distraction, not patience so much. UPS showed up with my Pro headlights :D That gave the PB blaster enough time to do its job. I got one bolt out with a few whacks of my BFH. I left the other in for now - the body is jacked up on one side and I want the bolts on the other side there to hold the cab in place. Now the problem is the bolts holding the bushing plate... and there's so much fucking dirt under there... One problem at a time...
    12TRDTacoma[OP] and Crom like this.
  15. May 17, 2016 at 8:27 PM
    #875
    Crom
    Nick
    San Diego, CA
    Millions
    Hang in there! You'll get it. :)
  16. May 18, 2016 at 5:37 PM
    #876
    Pigpen
    Dan
    Northwest Montana
    Mission accomplished this morning with enough time to get to work - for half a day.
    After driving around today I checked the nuts. 2 needed a little tightening, but no bad.
    This job was a pain in the ass, but like most new work, It would be pretty easy to do another one now that I know the tricks. The truck rides sooo much better. It really feels like it's held together better. Not really stiffer, but more solid. I need to get a pic, but the pinch weld lines right up with the bottom of the rear fender.
    If anyone is getting ready to do the body mount bushings, feel free to contact me. I may have some suggestions that could make it easier.
    Edit: This is important!
    I also have reverse Taco lean. I put in the 1/4" spacer when installing 5100s @1.75 and it leveled me out. After this project I sit 3/4" higher on the driver side.
  17. May 18, 2016 at 6:03 PM
    #877
    Crom
    Nick
    San Diego, CA
    Millions
    Awesome to hear!
  18. May 18, 2016 at 6:59 PM
    #878
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think a lot of us would like a simplified cliff notes version of the cab bushings install and what to do to make them easier. I sure would as I am tired of running only poly up front and the rest rubber. I feel sort of ready to take on this mod and have one less project to do at last.
    Pcyc, IronPeak and Crom like this.
  19. May 18, 2016 at 7:04 PM
    #879
    VolcomTacoma
    Jeff
    NorCal
    This is probably one of the first mods im gonna do when I get the truck back.
    Rob lets have a mini mod day in June and replace all of our bushings. Ill help with your cab mounts if you help with my steering rack :rofl:
    Pcyc likes this.
  20. May 18, 2016 at 7:08 PM
    #880
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh shit... lol. I can't promise I'll help you finish. The steering rack bushings are a total bitch to do. We should have a mini mod day for sure though. It has been a while hasn't it.
    I actually just redid some connections on my stereo a little bit ago. The steering wheel adapter would sporadically work and then stop entirely on volume and track changing buttons I got sick of it so I pulled the t taps out (note to self, don't use t taps, or plan intermittent connection) and wired them in pin style connectors and managed to move some junk out of the way so the stereo would fit better. Worth the time for sure. Now I can enjoy my stereo with peace of mind.
