Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. May 29, 2016 at 5:09 PM
    #901
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Can someone give me the thickness on the cab mounts, not the core support mounts but the ones for the cab. I'm solid mounting mine and would like some measurements if available instead of pulling mine off and truck being down while i make em
  2. May 29, 2016 at 5:58 PM
    #902
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    My dog in the background agrees...
  3. Jun 11, 2016 at 1:38 PM
    #903
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Finally got around to installing the rad bushings, a thousand times easier with no front bumper lol! Took all of 10 minutes to do. Man its hot out right now though, I really wanna tackle the cab mounts, but we'll see lol. Haven't driven it yet, but going to grab lunch now. I highly doubt I'll feel a difference since I'm still getting used to the LT feel, but peace of mind really. My old bushings didn't look to bad, but the inner rubber sleeve was pretty chewed up already, so few more offroad trips and they'd probably be toast.
    yotastaco and Soul Surfer like this.
  4. Jun 12, 2016 at 5:43 AM
    #904
    yotastaco
    yotastaco Well-Known Member
    VA
    2015 MGM TRD OR
    See Build
    Man up, grab some Mike's Hard Lemonade, and install the cab bushings. It's not that bad. It's better to let the body roll and break in the whole kit instead of having super firm rad bushings and crappy cab bushings. Did you use the rad bushings with the full kit? I would personally recommend doing so.
    MTopp and Pigpen like this.
  5. Jun 12, 2016 at 6:42 AM
    #905
    VolcomTacoma
    Jeff
    NorCal
    I only bought the full kit, I'm not gonna mix and match on my truck. And yeah, haven't driven it, starting on the cab mounts this morning
    yotastaco[QUOTED] likes this.
  6. Jun 12, 2016 at 6:47 AM
    #906
    yotastaco
    VA
    2015 MGM TRD OR
    See Build
    Awesome! I'm sure you won't need any help and are aware of this thread. Please disconnect your ABS sensors and be careful with the lifting. Loosen all sides almost to the end of the bolt, and only remove the nut one side at a time. If you wouldn't stick your prick in it, don't stick your finger in it.
    Pigpen likes this.
  7. Jun 12, 2016 at 7:29 AM
    #907
    VolcomTacoma
    Jeff
    NorCal
  8. Jun 12, 2016 at 10:14 AM
    #908
    Pigpen
    Dan
    Northwest Montana
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Good advice for life, in general!
    R0dzilla75 and 12TRDTacoma[OP] like this.
  9. Jun 12, 2016 at 10:20 AM
    #909
    yotastaco
    VA
    2015 MGM TRD OR
    See Build
    Learned that from the Army during assembly/disassembly of the M2 in the Expert Infantryman Course.
    For shit like this at 7:20, man made Leathermans.
  10. Jun 12, 2016 at 10:24 AM
    #910
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Damn I miss working with the M2's. They are fun to assemble and definitely fun to fire.
  11. Jun 12, 2016 at 10:27 AM
    #911
    Pigpen
    Dan
    Northwest Montana
    On the subject of bushings, are your cab bushings quiet, or do they talk to you while you drive?
  12. Jun 12, 2016 at 10:28 AM
    #912
    yotastaco
    VA
    2015 MGM TRD OR
    See Build
    I don't hear them. Maybe loosen them all up and give your whole cab a few shakes to settle, then tighten it back up.
    12TRDTacoma[OP] likes this.
  13. Jun 12, 2016 at 10:40 AM
    #913
    VolcomTacoma
    Jeff
    NorCal
    Ok quick update, got one side down, really not so bad, but the ABS sensors aren't being pulled at all, when I had the front jacked up enough to freely slide the OEM bushing in and out I peeped the engine bay and nothing was being pulled at all.
    @58 Siesta I think it was your walk through, but for the record, the cab bolt heads are not 13/16th they are 19mm, Toyota uses all metric in their trucks :D. I found this out because of stupidity- Used the 13/16th first but it was free spinning so I figured Toyota changed something stupid...and it had a little bit of play on it, grabbed a 19mm and it fit perfect on the bolt head, then went to impact the cab bolt off again and its still free spinning...oops, I'm an idiot and had the socket set to tighten, not loosen LOL. :facepalm:
    Time for the other side now!
    Pigpen and 12TRDTacoma[OP] like this.
  14. Jun 12, 2016 at 10:41 AM
    #914
    VolcomTacoma
    Jeff
    NorCal
    Also, cab bushings looked pretty intact. Nothing torn or worn looking. So probably not needed, but again, peace of mind, and one more thing to add to the checklist of shit I've wrenched on the truck lol
  15. Jun 12, 2016 at 10:43 AM
    #915
    VolcomTacoma
    Jeff
    NorCal
    Edited for correct walkthrough person :D
    yotastaco likes this.
  16. Jun 12, 2016 at 10:50 AM
    #916
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It looks confusing to me. The install, sort of because of the way the bolts are positioned vs. How you can access them. I guess its not as bad as it seems?
  17. Jun 12, 2016 at 11:10 AM
    #917
    Pigpen
    Dan
    Northwest Montana
    I'll make the change in the OP
    It's not as complicated as it might seem in my write up. I'm the kind of guy who gives too many details when giving directions to my house.
    I might have to do this. If you were hearing what I'm hearing... I even dreamed last night that I tore the entire project apart to lube it. Not joking.
  18. Jun 12, 2016 at 11:41 AM
    #918
    VolcomTacoma
    Jeff
    NorCal
    No way man, if you wanna cruise by this afternoon it's actually not that bad. I was putting it off, but just got done, hardest part is getting over how high you can lift the cab. The first side I was so scared to do it and was barely lifting it, one I figured out I could lift it a bit higher than I thought without stretching anything, you can get a socket in there and its a breeeeeeze
  19. Jun 12, 2016 at 11:43 AM
    #919
    VolcomTacoma
    Jeff
    NorCal
    Your write up was great! The only thing I changed was instead of unhooking the ABS line on the passenger side, which was the only one I noticed getting tight, I just popped the wire holder thing off of the bracket and then it had plenty of slack and I was able to lift the passenger side up alot! Your write up definitely saved me at least a solid 5-10 minutes of checking each bolt for sizes and trying to figure out exactly what needed to be done :D
    Pigpen[QUOTED] likes this.
  20. Jun 12, 2016 at 5:35 PM
    #920
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I'll have to reattempt my cab bushings soon. Bolts for the actual bushing mount weren't budging and I was afraid to lift the body too high, but it sounds like it'd be no problem.
