Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Jan 1, 2017 at 4:32 PM
    #1021
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Here's the thing though, if you're putting the front bushing on upside down for a minor body lift, but not the cab mounts, you're putting stress on the body in between the two. I keep telling people that lol. Don't be surprised when you start seeing wrinkles in your body lol
  2. Jan 1, 2017 at 4:35 PM
    #1022
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    34 ft-lbs is what I went with. Same as the the torque spec for the Cab Mount Bushings.
    Full compression of the poly won't happen because of the internal steel sleeve/bushing is where you'll be torquing against.
  3. Jan 1, 2017 at 4:41 PM
    #1023
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Over 1/4 inch gains? Not sure how that works. I had 1/4 inch shim on top of factory bushing to shim my bumper and rallied the shit out of my truck on the beach for 2 summers. No wrinkles
  4. Jan 1, 2017 at 4:42 PM
    #1024
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    •TRD OR Tacoma•
    Thanks, what bushings did you use for the Rad support?
  5. Jan 1, 2017 at 4:43 PM
    #1025
    bski22
    Rob
    Toyota
    @VolcomTacoma our disconnect is I'm only talking radiator bushings
  6. Jan 1, 2017 at 4:45 PM
    #1026
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    For the radiator bushing I just tightened to yield. They are lock nuts, and when you tightened them, the sleeve and washers contact,then snug.
    bski22 likes this.
  7. Jan 1, 2017 at 4:47 PM
    #1027
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thats what I wanted to avoid. Inconsistency. I matched all the bushings. Body and radiator mounts have the smaller bushing on top. Torqued to 34ftlbs
    Cool. Ill match the radiator mounts then.
    bski22 likes this.
  8. Jan 1, 2017 at 4:48 PM
    #1028
    Subway4X4
    Lloyd
    NY/NJ
    I pulled this from the OP:
    Measurements are as follows:
    - Stock upper radiator support bushing thickness: .9375" or 15/16"
    - Polyurethane kit supplied washers are about 1/8" or .125"
    - Polyurethane "puck" bushing WITHOUT supplied washer thickness: .750" or 3/4" (WITH washer = 7/8" (.8750")
    So math here:
    0.9375" - 0.8750" = 0.0625" = the difference between the OEM upper and the ES Thicker Poly bushing.
    I'm not too terribly worried that 0.0625" will stress the body along the frame.
    Anywhoo... wrinkles give my truck character.
    bski22 likes this.
  9. Jan 1, 2017 at 4:54 PM
    #1029
    bski22
    Rob
    Toyota
    He's referencing if you're doing all the mounts including radiator. But I agree. Where you at in NY btw?
  10. Jan 1, 2017 at 5:00 PM
    #1030
    Subway4X4
    Lloyd
    NY/NJ
    Ah. OK. Now I understand.
    I'm in Congers, Rockland County, NY. Right across the Tappan Zee.
    fatfurious2 and bski22[QUOTED] like this.
  11. Jan 1, 2017 at 5:01 PM
    #1031
    bski22
    Rob
    Toyota
    Ah gotcha. Was just up that way recently. Im trying to stake out a few places for hiking and camping in this great state of NY. Wheeling would be fantastic too but unfortunately as you're aware we are
    Regulated to PA and CONN
  12. Jan 1, 2017 at 5:20 PM
    #1032
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    OK, I'm really trying to follow this and the fifty page discussion without any success.
    If I read the above correctly then installing "upside-down" with the washer results a spacing of .8750". This compared to the stock bushing of .9375". A difference of .0625" which seems very minor.
    Installing it "right-side-up" results in a *larger* difference. So it really seems these should be installed "upside-down" with the washer and if doing so you are at stock spacing within rounding error.
    But then @VolcomTacoma keeps saying my truck will eventually break in half like a Yugo if I install it "upside-down". It seems like installing it right-side up would be what would change the spacing and add stress.
    I feel like I'm missing something connecting two dots here. Or else connecting two dots incorrectly.
    Little bit of help?
  13. Jan 1, 2017 at 5:25 PM
    #1033
    VolcomTacoma
    Jeff
    NorCal
    From the other thread I posted, Rubber is gonna compress more than Polyurethane. So measuring stuff off the truck is a bit different. Someone run by a dealer and get a body to frame measurement with new bushings in, and then measure your body to frame with the new poly bushings. Bet you get a difference still.
    DVexile likes this.
  14. Jan 1, 2017 at 5:27 PM
    #1034
    VolcomTacoma
    Jeff
    NorCal
    You know what though, its yalls trucks do what you're gonna do. I'm not gonna install something in a way it wasnt designed because "its not that different".
    XPOTRPR and Blacktacoma23 like this.
  15. Jan 1, 2017 at 5:45 PM
    #1035
    DVexile
    Ken
    Ah, got it. OK that all makes sense and was the part I was missing - compressed vs. uncompressed measurements with different materials at play.
    So it sounds like the best thing to do would be to measure the spacing in stock configuration with the OEM rubber bushing installed on a as yet unabused truck. Next through trial and error figure out what configuration of poly + washers produces the same spacing installed and torqued down. That seem a reasonable approach?
    Subway4X4 likes this.
  16. Jan 1, 2017 at 5:50 PM
    #1036
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I would run the big washer, big bushing on top, small bushing, small washer on bottom.
    You can also skip the big washer of you want, that's how I ran mine...
    I've run the universal both ways, right side up and upside down, and the Tacoma specific kit bushings.
    The ES Tacoma kit bushings are a lot softer and compress some, the universal bushings are very dense and don't really compress, IMO.
    The universal kit I felt offered the best performance.
    Here are some pics from my build when I compared the Tacoma kit, to universal.
    I ran the universal for one year.
    Subway4X4, DVexile and bski22 like this.
  17. Jan 1, 2017 at 5:51 PM
    #1037
    VolcomTacoma
    Jeff
    NorCal
    It does. I'd be willing to bet the spacing on new poly vs new rubber between frame and body is almost the same, wheras putting the larger bushing on top would create a difference. People like to talk smack but a year down the road they come back on here asking why their body has wrinkles and cracks and their subframe is falling apart. Just saying
  18. Jan 1, 2017 at 5:52 PM
    #1038
    bski22
    Rob
    Toyota
    :facepalm:
  19. Jan 1, 2017 at 6:04 PM
    #1039
    Crom
    Nick
    San Diego, CA
    Millions
    When I ran the larger universal bushing, I skipped the big washer. Ran it that way for over a year. I beat my truck on the worst washboard roads in the state. My fenders are intact, no sheet metal cracks, core support still in one piece, as best I can tell. It's something I look for when doing vehicle inspections.
    Also there are numerous reports of people fighting with the drivers core support bolt when reinstalling. That leads me to believe that everyone's core support is caving due to battery, or its some odd characteristic of the Tacoma, therefore normal.
    Airdog, DVexile and bski22 like this.
  20. Jan 1, 2017 at 6:32 PM
    #1040
    DVexile
    Ken
    Well of course, why didn't I just look at @Crom's build page first - everything is in there!
    So looking at this more it would appear that the stiffer 9.4101G would clearly provide less isolation than the 8.4109G. Similarly the 9.4101G would constrain the total movement of the core relative to the frame more as well.
    Interestingly in the Energy Suspension catalog when comparing uses for higher and lower durometer universal mounts they say this about applications:
    Clearly Toyota and Energy Suspension have chosen lower durometer mounts than the 9.4101 for their standard radiator mounts. But if this is for "off-roading/rough terrain racing" is the higher durometer material in the 9.4101 more appropriate?
    Since I've got time to kill and parts cost is small compared to inconvenience of doing the install maybe I'll email the ES techs and see what they say.
    Crom and bski22 like this.
