Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Mar 7, 2017 at 5:37 AM
    #1081
    Pigpen
    Dan
    Northwest Montana
    ChadsPride[QUOTED] likes this.
  2. Mar 7, 2017 at 5:38 AM
    #1082
    ChadsPride
    Sponsored by TacomaWorld.com
    :confused:
  3. Mar 7, 2017 at 5:39 AM
    #1083
    ChadsPride
    Is there a specific reason why?
  4. Mar 7, 2017 at 5:47 AM
    #1084
    Pigpen
    Dan
    Northwest Montana
    Just fucking with you!
    Moenin :hattip:
  5. Mar 7, 2017 at 5:48 AM
    #1085
    ChadsPride
    :rant:
    Good Morning sir!!!
    :wave::wave::wave:
  6. Mar 7, 2017 at 5:50 AM
    #1086
    Pigpen
    Dan
    Northwest Montana
    I remember looking at the red set. I think I remember reading that the red ones are a softer compound. I could be wrong - it's happened before.
    ChadsPride likes this.
  7. Mar 8, 2017 at 12:58 AM
    #1087
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How do I know if the cab mount ones are shot ?
  8. Mar 8, 2017 at 1:27 AM
    #1088
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    What I got from reading this thread is the cab mounts are generally good for the life of the vehicle. People that have swapped them have found them in good shape. Also apparently the cab mount swap is difficult, with some of the bolts being awkward to access.
    I have the universal radiator bushing kit on the parts shelf, but after reading this thread I'm going with the tacoma specific one.
    The above statements don't apply to those who wheel extremely hard/jump truck etc.
  9. Mar 8, 2017 at 2:11 AM
    #1089
    IronPeak
    AuggieX
    Back to Back
    For everyone's information I emailed ES and asked if I could purchase just the tacoma specific radiator mounts. Content of email below, answer was unfortunately no.
    Sent: Thursday, February 23, 2017 6:39 PM
    To: hyperflex@energysuspension.com
    Subject: Tacoma bushings
    I would like to purchase just the radiator support bushings from the Energy Suspension 8.4109G Body Mount Set , is this possible?
    Re:
    Unfortunately it isn’t, we only sell the complete kits.
    Thank You,
    [​IMG] [​IMG][​IMG][​IMG]
  10. Mar 10, 2017 at 5:05 PM
    #1090
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    I would disagree, my 08' has 151k miles and the cab mounts were shot... The ride quality is night and day, more like when it had 51k miles. Installation takes time but is easy, long as you don't have a seized bolt like I did. The cab mount and radiator mount bushing replacement is by far the best mod for the money if your taco is a bit older or been wheeled hard.
  11. Mar 18, 2017 at 7:09 PM
    #1091
    anthony250f
    Anthony
    San Diego, CA
    Just finished the mounts...what a pita...drivers side would NOT fit with the reducer...had to use a plethora of ratchet straps to pull the core support to get it in
  12. Mar 28, 2017 at 5:44 PM
    #1092
    anthony250f
    Anthony
    San Diego, CA
    Did anyone have issue with the fan rubbing the bottom of the shroud with the large bushing on top? It barely hit but I ended up putting the small one on top. Everything fit perfect that way.
  13. Mar 28, 2017 at 8:56 PM
    #1093
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes, it's what happens when you space the body too far up. The fan will rub on the bottom of the shroud, remedy to that is to use the thinnest bushing up top like you did.
    Problem solved, crisis averted.
    anthony250f[QUOTED] likes this.
  14. Mar 28, 2017 at 8:57 PM
    #1094
    anthony250f
    Anthony
    San Diego, CA
    Sweet!! Was pretty embarrassing when I started the truck up at the gas station haha
  15. Mar 28, 2017 at 9:05 PM
    #1095
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It'll self clearance itself otherwise. :thumbsup: :D
    Yeah it happened to me when I was messing with the heights until I figured out what the heck was going on. Then I spaced it down some and the issue receded and so did my worries. Lol.
    Kolunatic likes this.
  16. Mar 30, 2017 at 11:40 PM
    #1096
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    I'm getting ready to replace as many bushings as possible, my truck has 130k miles and some pretty heavy offroad abuse over the years. I am wondering what all would be a good idea to replace. Obviously cab mounts, radiator mounts. What else is everybody replacing? And what is the tacoma specific radiator bushing kit part number?
    I was looking at the master kit from energy suspension, do the bushings fit OME dakars and Light racing UCA's?
    Thanks
  17. Mar 30, 2017 at 11:46 PM
    #1097
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Part numbers are in the OP.
  18. May 6, 2017 at 10:11 AM
    #1098
    Taco'09
    Taco'09 Well-Known Member
    Uh, yes you can and I did. ES has a business relationship with a guy in CA that can obtain individual parts and sell to you. ES drop ships to you. I purchased the full kit elsewhere but used only the radiator core support bushings for now with plans on doing the rest of the body bushings in a few years. But I wanted to do all new bushings at the same time so I restored the kit's radiator pieces.
  19. May 6, 2017 at 10:36 AM
    #1099
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Will the body mount kits work with a body lift of 1" from Toytec??? When I did this body lift, my body bushings were just hanging on, so I know I'll need some soon?? Thanks in advance.....
  20. May 6, 2017 at 11:49 AM
    #1100
    IronPeak
    AuggieX
    Back to Back
    Great! Can you share with whomever they have this business relationship so we can order the rad bushings separate? I'm sitting on the universal ones but want the softer rad bushings. Don't want to buy the whole set. Thx.
