Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Jul 13, 2018 at 10:57 AM
    #1201
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    Well that’s good food for thought. I just assumed the stock coil overs and leaf springs were fairly forgiving.
    On my 2006 I had +200lbs in the front with winch/bumper. Then added the stiff OME spring. That was my normal for 12years.
    Then I got this truck a few months ago. It drove like a limo until I swapped out these cab bushings.
    But yes I will be upgrading the suspension soon. Just stuck analyzing options.
  2. Jul 13, 2018 at 2:13 PM
    #1202
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Dclb here with icons on 650lb coils and ome leafs with the add a leaf. Im oversprung because I wanted the lift/clearance for last year at Moab. I'm on 285s falken wikdpeak at3w. I did all the bushings including the LCA and steering rack. I can assure it definitely magnifies nvh. I knew it going in but to me the trade off was okay. I'm rebuilding the suspension over the next couple months to hopefully offset it. Going sua with Kings all around.
    It's almost unbearable at this point if you have a stiff suspension or your tires are fully aired up.
  3. Jul 25, 2018 at 10:49 AM
    #1203
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Forgot to update when I moved things around a few weeks ago:
    Originally I had small bushing on top w/ washer. I have no heavy bumpers or anything. Fit was good but still squeaked.
    Swapped them around, but did not use the metal washer with the big bushing on top. "Squeaky" noise stopped, but I think there is something else causing some creaking up front.
    Now, when I went to the big bushing on top, I do have a noticeable gap in my hood spacing towards the front. It doesn't affect the latch but I can tell the difference. If I had the washer as well I'm almost positive my hood wouldn't pop. It's not bad enough for me to worry about...but others have mentioned it so I putting it here for reference.
    So, a theory I have is that maybe my IFS skid is causing some noise down there? It only happens when I have the steering and suspension really loaded up (i.e. close to full lock when pulling in and out of a parking spot). The creak noise sounds like just metal on metal right when the suspension unloads and is maybe amplified by the enormous flat piece of steel. Oh and everything on my front end is tight, only 67k on the truck. All the bushings and boots look great. I do have Camburg ball joint uca's though if that could cause noise, or maybe the eibach springs loading/unloading and popping in the 5100's. Who knows...:annoyed:
    Thoughts?
  4. Jul 25, 2018 at 10:51 AM
    #1204
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I get all sorts of noises coming from my truck, including the noise you describe. I just chalk it up to off-roading and driving a modded truck. They key is to be able to differentiate between normal noises and bad noises.
  5. Jul 25, 2018 at 10:52 AM
    #1205
    AugustaTaco
    Josh
    Augusta, GA
    Haha, that's what I told my wife. It doesn't really bother me much, especially when I know everything is tight
    EatSleepTacos[QUOTED] likes this.
  6. Jul 31, 2018 at 11:49 AM
    #1206
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Hey guys, I created another thread looking for the front rad mount bushings that come with the 8.4109 kit. I already have the 9.4101G kit installed but I want to take some measurements of both kits installed. I have called energy suspension and they wont sell me the parts. Another company, energy suspension parts, will sell them to me via special order with a 2-4 week lead time. I figured someone in this thread might want to sell the 2 front bushings sets from the body mount kit that they didn't use? I would be happy to come back and report all the number I got with everything installed and some pictures for future reference.
  7. Aug 2, 2018 at 10:02 PM
    #1207
    Nixinus
    Oregon
    2010 4x4
    I haven't put my IFS on yet but I think you are on to sonething. I put a 3/8" metal skid on my dirt bike and it's noisy. All types of weird sounds reflecting off that thing.
    AugustaTaco[QUOTED] likes this.
  8. Aug 11, 2018 at 2:22 AM
    #1208
    Nixinus
    Oregon
    2010 4x4
    A quick update for anyone who might be on the fence about which kit to install on their rad supports.
    I had the universal 9.4101G bushing on my truck for about a week. Fat puck on top. After that week I measured 20.5mm (with washer). I used a micrometer and since it's hard to get a good angle on the gap, I might be off a bit. I then measured the 8.4109G kit bushings, using the exact same technique and got 17.5mm right after finishing the install. The 8.4109 kit sits about 4mm lower than the 9.4101 kit. Hood lined up better and no issues with fan shroud clearance with both kids.
    I don't have a good measurement of the stock bushings on the truck since mine were shot. Might go to the dealer and ask to poke a mic up the fender for a minute.
  9. Aug 11, 2018 at 9:09 AM
    #1209
    SaphiraTaco
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    That's pretty much what I came up with also. And chose the 8.4109G for final install. But my front end is currently stock. I understand some people have significant added weight (dual batteries, steel bumper, winch). When I get there I check to see if the installed measurement has changed. In any case, I have the 9.4101G as backup if needed down the road.
  10. Aug 11, 2018 at 2:32 PM
    #1210
    Nixinus
    Oregon
    2010 4x4
    Thats the justification I used for the lighter bushings. I figured that even if the stock bushings we're under-supported, the 8 series bushings we're already beefier and sat taller with more cushion. The other reason was my OCD and the hood :annoyed:
    AugustaTaco likes this.
  11. Aug 11, 2018 at 2:47 PM
    #1211
    AugustaTaco
    Josh
    Augusta, GA
    Not gonna lie, the hood gap with me using the 9.4101 is bugging me
    I intend on doing an SOS streamline w/ winch so I’ll leave it until then
  12. Aug 11, 2018 at 2:51 PM
    #1212
    Nixinus
    Oregon
    2010 4x4
    Even with the 8 series there is slight misalignment in the grill/hood mating area. Might have been that way before but never noticed it until I changed the bushings out.
  13. Aug 11, 2018 at 3:02 PM
    #1213
    AugustaTaco
    Josh
    Augusta, GA
    Dammit
  14. Oct 26, 2018 at 5:52 PM
    #1214
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    @12TRDTacoma i cannot get the front of the cab to lift high enough to get the stock front mounts out, any suggestions?
  15. Oct 26, 2018 at 5:52 PM
    #1215
    AR15xAR10
    I really need help on this one. I’m struggling.
  16. Oct 26, 2018 at 6:02 PM
    #1216
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Front of cab, radiator support or where your feet are when your driving?
    Did you loosen/remove all cab bolts from one side of the truck.
    Could be the steering shaft.
  17. Oct 26, 2018 at 6:26 PM
    #1217
    AR15xAR10
    i got it. used a pry bar to separate the frame and cab. did driver's side rear, passenger side rear, passenger side front, now I am finished those three and moving on to the driver's side front.
    not doing the radiator mounts until everything else is done
    12TRDTacoma[OP] and Biscuits like this.
  18. Oct 26, 2018 at 6:31 PM
    #1218
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Nice. Looking through your build now. Saw parts that I didn't think were available.
    Biscuits and AR15xAR10[QUOTED] like this.
  19. Oct 26, 2018 at 6:35 PM
    #1219
    AR15xAR10
    thats my goal!!!!! :D
    Biscuits likes this.
  20. Oct 26, 2018 at 6:49 PM
    #1220
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Interested in those Gear Tech splash guards. One on my passenger side is ripped and I was going to replace it with a factory one. Think I'll just buy the 4-piece set from Gear Tech.
