Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Sep 11, 2015 at 2:53 PM
    #141
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    thanks man!! ordering now, so your saying by lifting on the slider till the wheel is 1" off the ground its very easy to get the upper bushing out and the big on in its place?
    Crom likes this.
  2. Sep 11, 2015 at 3:04 PM
    #142
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes for getting the old bushing out, But there is more you need to do to get the new bigger one in. Lifting by slider helps unload the joint and does create a lot of space, but the bigger bushing needs even more clearance to go in. Airdog and others used a piece of 4x4 wood and floor jack to push up on the cab sheet metal to gain clearance. I had to do this too but I didn't have a 4x4 block of wood, so I used a 24" breaker bar as a push rod, floor jack, and a small flat block of wood between the cab sheet metal and breaker bar. It worked great!
    It's a 30 minute job and it's a noticeable improvement.
    DaveEli likes this.
  3. Sep 11, 2015 at 7:55 PM
    #143
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Good stuff. Needed for my 110k truck.
  4. Sep 11, 2015 at 8:07 PM
    #144
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Anyone experience any squeaking with these bushings yet?
  5. Sep 11, 2015 at 8:16 PM
    #145
    Crom
    Nick
    San Diego, CA
    Millions
    @Torspd had had them in his truck the longest AFAIK, and he said in this thread, that his are all quiet. Per his build thread he did and apply a light coat of grease on his... I did the same to mine, used Super Lube PTFE bushing safe synthetic grease.
  6. Sep 11, 2015 at 8:46 PM
    #146
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Same here, no squeak.
    Crom[QUOTED] likes this.
  7. Sep 11, 2015 at 11:10 PM
    #147
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    subd cuz my wallet is beyond empty....need to log off for awhile lol :smash:
  8. Sep 12, 2015 at 10:04 AM
    #148
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    I would of had mine installed already but ups left them at their facility, so hopefully Monday!
  9. Sep 12, 2015 at 1:44 PM
    #149
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I didn't lube shit. You really don't need to if installed properly. I have never dealt with squeaks on poly bushings before unless it is installed incorrectly.
    Crom likes this.
  10. Sep 12, 2015 at 5:36 PM
    #150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you get the black bushings, they are impregnated with graphite. To help prevent squeaking. :thumbsup:
    GilbertOz and Crom like this.
  11. Sep 12, 2015 at 6:35 PM
    #151
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Is that a serious post or are you being sarcastic? Lol. I can't tell!
  12. Sep 12, 2015 at 6:47 PM
    #152
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    It's true, even Energy Suspension has said the black is superior, it's just some people want red. They used to make yellow and blue years ago too.
    The black and red are the same durometer, so with the graphite in the black bushings there's really no reason to get the red.
    I don't understand why All-Pro, Total Chaos, and others even put the red bushings in their parts. Maybe they don't know.
    Torspd and 12TRDTacoma[OP] like this.
  13. Sep 12, 2015 at 6:48 PM
    #153
    BadBrains
    AL
    With a radiator support and cab mount though, there shouldn't be any movement, so I'd think there wouldn't be much advantage in those locations.
    12TRDTacoma[OP] likes this.
  14. Sep 12, 2015 at 7:33 PM
    #154
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wonder if the nature of the using the color alone requires adding graphite into the mix in order to make it black. Just thinking out loud about it.
    I've always preferred black poly over red or yellow and anything else. It's just more inconspicuous that way.
  15. Sep 12, 2015 at 7:52 PM
    #155
    BadBrains
    AL
    Could be.
  16. Sep 12, 2015 at 8:32 PM
    #156
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Black does have the graphite.
    The poly lube does work ok for stoping squeaks,but the best for poly bushings against metal is a very thin coat of anti seize. Works wonders.
    I really like Energy Suspension's products. I bugged them for a year to develop a master kit for 2nd gen tacos.
    I just had a new frame put on and had the dealer install the ES body mounts bushings.
    Along with the new LCAs and bushings,it has never ridden so tight.
    Great thread by the way.
    I only have one concern. The thickness of the thick top bushing. Is it thicker than stock?
    What are your thoughts on a thicker than stock poly bushing (that gives less) on top,putting more stress on the already weak sheet metal supporting the radiator?
  17. Sep 13, 2015 at 6:39 AM
    #157
    MTopp
    05 SR5 4x4
    Yeah, my cab mounts for sure flex, I can hear the cab move/creak when goin over twist bumps.
    But I'm replacing those later, doin the radiator for now.
  18. Sep 13, 2015 at 7:27 AM
    #158
    Crom
    Nick
    San Diego, CA
    Millions
    Ditto. My rock sliders (welded to frame) have been scored by the pinch weld from extreme flex. So I know the cab is a movin. Not sure about any noise coming from them though.
    That's much harder to diagnose. My truck had a bad creaking sound right off the factory lot while off roading and opening door after driving. Annoying as F***. I made Toyota fix it. Turns out it was the sheet metal in the pinch weld rubbing. Sprayed penetrating oil into the pinch weld and all noise stopped.
  19. Sep 14, 2015 at 8:40 AM
    #159
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Much thicker over stock, which is not a bad thing. My take on it is this. The stockers are sloppy. They allow anywhere from a half inch to an inch of movement while offroading. In pothole ridden cities, dirt roads, country roads, the same issue will apply regardless. I feel that the bushings are a little undersized in the first place so these energy ones will apply more surface area to hold in place the support better.
    About the weak support. The issue is severely compounded by an already beast heavy 50lb+ battery. Compile this with sloppy bushings that allow bounce and that is a recipe for disaster with a soda can thin sheetmetal radiator support. That is why at this juncture I am a huge advocate of battery relocation to the frame where the metal is much more stout.
    I feel for the people who do AGM odyssey, Optima, or similar dual battery setups in the front who also like to offroad. Poor bastards never stood a chance. By the time they realize what's going on it's already too late and the damage has been done.
  20. Sep 14, 2015 at 9:37 AM
    #160
    MTopp
    05 SR5 4x4
    What damage does the battery do? If.you're not jumping your truck, should be fine, right?
