ponethousand's build
Discussion in '1st Gen. Builds (1995-2004)' started by ponethousand, May 12, 2012.
  1. Feb 28, 2013 at 7:30 AM
    #221
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    I normally try to run .025 because it's the most universal for what I weld on a regular basis, but I got a hookup on a 30lb spool of .030 for free, so I'm stuck using that unless I'm welding something really thin, then I'll grab a small 2lb spool of .025 .... I keep a medium sized bottle of Ar/CO2 for steel, and a little bottle of straight Argon for doing stainless, but I don't mess with the stainless a whole lot.
    You do some nice work BTW.
    Where can you get a small rod oven ? I've seen bigger ones, but I barely use mine, so I can't justify spending much... I've heard a small refrigerator with a regular lightbulb kept on work well also for keeping moisture out of your rods, the poor man's setup.
  2. Feb 28, 2013 at 7:41 AM
    #222
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    this holds 10lbs http://store.cyberweld.com/phrodov10lbd.html
  3. Feb 28, 2013 at 7:51 AM
    #223
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
  4. Feb 28, 2013 at 8:49 AM
    #224
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    If you do not get the ubolt flip, you will need new ubolts for the expos...i say go for it, they are just about the same price as new ubolts.
  5. Feb 28, 2013 at 9:05 AM
    #225
    ponethousand
    ponethousand [OP] Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Just put in the order linwood. Burry is going to help with the shock relocation. Did you change your own gear oil?
  6. Feb 28, 2013 at 10:38 AM
    #226
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Don't get your hopes up too high with the new gears. It's going to feel better on the road for sure, but it's not going to feel like a crawler. Anyone that has driven with a real crawler will know that it's a whole other level of gearing with a crawler.
    Either way, I'm sure you'll like the new gears.
  7. Feb 28, 2013 at 11:10 AM
    #227
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Expectation not to high
  8. Feb 28, 2013 at 12:25 PM
    #228
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Shit...with 4.56 gears in 4 low in 1st gear it is like 90:1....that is pretty damn close to me....:rolleyes:
  9. Feb 28, 2013 at 12:41 PM
    #229
    EL TACOROJO
    BURRY
    south mills NORCAK
    Lol.
  10. Feb 28, 2013 at 1:26 PM
    #230
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  11. Feb 28, 2013 at 3:38 PM
    #231
    jandrews
    '09 FourDubDee TRD OR
    That calculator fails to take into account that a torque converter at full stall multiplies tranny output about double, essentially acting as another 2:1 reduction (give or take). It assumes the tranny is operating with the torque converter locked up, which it isn't most of the time on the trail.
    See here:
    http://en.wikipedia.org/wiki/Torque_converter#Efficiency_and_torque_multiplication
    It's variable depending on how close to stall you are, but the slower an auto goes, the closer it is to stall.
    Thus, assume say 2.0 reduction on average. Plug in 2.0 as the underdrive on your same gear calculator up there and it'll spit out 82.5:1 in 1st gear, 4Lo, with 4.56 gears and 285 tires. If you're a bit closer to stall and getting 2.2 reduction out of the Tq converter, then you get 90:1.
    The main disadvantage is your crawl ratio isn't a set ratio with an auto.
    This is why auto guys with crawlboxes (Chad) can't stop their trucks in compound low unless they put 'em in neutral. The crawlbox gets DOUBLE input from everything in front of it, then multiplies that, and the brakes can't handle it.
    Gearing an auto won't give you the same control as a crawler, but for the shit you can actually do in these trucks, it won't matter. It's not like they're competition rock crawling.
    Edit: IMO the big advantage of crawlboxes in manny tranny Tacos is being able to hill start without melting your clutch and having much more control. They're basically required equipment.
    The downside of near-stall operation (i.e. crawling) with an Auto tranny is it produces a lot of heat. A LOT of heat. For this reason, I drain/fill the trans pan every year to help keep the fluid fresh. There's no way in hell with all the crawling this truck does that I'd go Toyota's 100,000mi or whatever they recommend without servicing the trans lube. I'd be shelling out for a trans rebuild at 75k.
  12. Feb 28, 2013 at 4:07 PM
    #232
    Box Rocket
    Adam
    Syracuse, Utah
    Totally agree on the benefits of a crawler in a manual trans truck. I had 4.88 gears in my '93 SAS pickup then added a Marlin dual-ultimate crawler (230:1). Made it a completely different truck.
    With an auto trans the 4.88 gears will be most noticeable on the road. But the auto trans and torque converter make the truck easy to crawl with on the trail even with stock gears.
    92:1 isn't exactly accurate. 4.88s put you at 41.25:1 but the torque converter is "doubling-down" so it feels like lower gearing.
  13. Feb 28, 2013 at 5:13 PM
    #233
    wrmathis
    Bonaire, GA
    parts and stuff
    hmmm i dunno what you are talking about in that situation :anonymous:
  14. Feb 28, 2013 at 5:24 PM
    #234
    jandrews
  15. Mar 1, 2013 at 5:57 AM
    #235
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Thank you for all the information. I'm not even going to try an act like i know anything on these subjects. All i know is that i want a functional truck to drive and have fun in. I know i'm not a rock crawler but it sure looks fun tackling objects in some of the trail riding we do. With that said i am learning a lot from all of you. I am humble and know when to ask. It is comforting to know that i will never call the stealership and get ripped off. I will ask you guys all the questions first. :humble:
  16. Mar 3, 2013 at 12:26 PM
    #236
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Where did you get your toyos? Having some second thoughts on tires
  17. Mar 3, 2013 at 7:06 PM
    #237
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Pungo off-road in virginia beach. They are a direct dealer for toyo. Pretty good deal on 305/70/16
  18. Mar 5, 2013 at 6:03 AM
    #238
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    I have an idea for a temporary strengthening bracket to allow a roller fairlead to work. I'm making a rough sketch of it and posting it my build thread, let me know what you think.
  19. Mar 7, 2013 at 8:56 AM
    #239
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Another order came in when I was out of town. BAMF LCA skid and Light bracket for behind the grill came in as well as my regulator for my Co2 Setup. If only the Allpro order would come in before the Flagpole meet on the 16th...
  20. Mar 7, 2013 at 8:58 AM
    #240
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
