Pongo, my 2016 TRDOR, it's life stages, and travels
Discussion in '3rd Gen. Builds (2016-2023)' started by dorton, Sep 20, 2016.
  1. Nov 1, 2016 at 2:39 PM
    #61
    dorton
    dorton [OP] rockcreekoverland
    Winston Salem NC
    2016 TRD Off Road
    Old Man Emu Nitro Chargers, CS047R leafs w/ D29XL extra leaf, CBI front and rear bumpers, CBI armor, rock sliders,ditch light brackets, and bed rack, Free Spirit Recreation Extreme Series roof top tent, VTX Viper wheels, General X3 Grabber tires, 4.88 gears front and rear, Kenwood TM-710G UHF/VHF radio. Icom IC-706MKIIG UHF/VHF/HF radio,KC Hilites 20" Flex Bar and ditch lights, Safari snorkel, BedSlide Classic, SnoMaster USA expedition series fridge.
    Yes, both are OME Heavies. Only difference in the two is that mine has the OME extra leaf for the added weight in the
    rear. Both also are running 285's. This one has 16's though, so 285/75r16s instead of the 285/70r17s that mine has on
    it.
  2. Nov 7, 2016 at 7:06 AM
    #62
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Time for a couple of small updates:
    I recently decided to add TRD Pro tail lights to Pongo
    And added a vinyl insert on the hood:
    The main reason for the vinyl is to help make the solar cell I planned on adding not
    stick out like a sore thumb:
  3. Nov 7, 2016 at 7:25 AM
    #63
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    Cool idea on the solar panel
  4. Nov 7, 2016 at 7:42 AM
    #64
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Thanks sir. With the 63 QT ARB fridge(packed) I got to the 3rd day camping in one spot before the low power cut off
    disabled the fridge while in Idaho this past summer on the original equipment battery. I'm thinking this would be enough
    to supplement the draw from the fridge and allow additional days if I choose that route. Soon, I'll be replacing the factory
    battery with a NorthStar with higher reserve, but for now what I have works.
    trd_overland likes this.
  5. Nov 7, 2016 at 10:48 AM
    #65
    Blindside
    Blindside Member
    2016 Tacoma Limited
    @dorton - If you have time, would you mind showing me where you made the connections for the ARB Clearance Lights and Turn Signal lights? There was no wiring guide provided with the instructions so I figured I'd ask before I got out the multimeter.
    Also, are the included fog lights plug and play with the factory fog light wiring? Or will I have to cut and splice those also!
    I'll be putting the bumper on this weekend and would like a little guidance on the wiring!
    Thanks in advance for your help!
  6. Nov 7, 2016 at 10:57 AM
    #66
    Stu488
    Stu488 Well-Known Member
    Scott
    Parker, CO
    2016 Quicksand Tacoma TRD OR DCSB 4x4
    TRD Pro 17' with 265/70/17 BFG KO2, blacked out grill and emblems, Toytec Boss 2.0 kit w/aal, relentless fabrication 8" bed bars, Insain fabrication front bumper with Warn M8000S winch, Factor 55 flat link, cmc, RCI metal works front and control arm skids, bottle opener.
    How did you mount the maxtrax mounting pins to your prinsu rack? Thanks
  7. Nov 7, 2016 at 11:22 AM
    #67
    dorton
    Winston Salem NC
    2016 TRD Off Road
    I'll get some visuals to post up of the lights and turn signals.
    The fog light bulbs supplied with the bumper do not plug into the factory harness. I swapped the connectors onto the
    factory harness.
    Toyota part numbers used:
    90980-11096 x2(the actual sockets. They do not come with the wires)
    82998-12550 x4(the actual wires to go in the sockets)
    You could go to a part store and save money, or order the correct socket online. They were in stock at my work, and didn't want to spent
    the time to go hunt them or order them, so I used OEM parts.
    Take your time on the bumper and it will go fine. A tip after doing 6 of them: Before you ever touch your truck, take everything out of the
    boxes, and pre-assemble the trim, bumper pads, mesh insert, and fairlead. You can spend 2-3 hours(especially the first time) on the little stuff before you need
    to turn a single bolt on your truck.
    Blindside[QUOTED] likes this.
  8. Nov 7, 2016 at 11:27 AM
    #68
    linnmarb
    linnmarb Well-Known Member
    2017 Inferno TRD OR DCSB 4WD
  9. Nov 7, 2016 at 11:28 AM
    #69
    linnmarb
    Let's try this again. Name it Auburn. WDE!
  10. Nov 7, 2016 at 11:31 AM
    #70
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I've found my biggest issue with my Tacoma has been glare driving home from work, with the sunset bouncing off the hood. How reflective is this insert, how much did it cost, and where did you get it? I'm very interested in this, so any details help.
    Thank you!
  11. Nov 7, 2016 at 11:59 AM
    #71
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Thank you so much! I've contacted a couple local dealers and I'm waiting to see if they have the part numbers in stock and available.
    The bumper is being powdercoated right now and I'll pick it up Thursday for a Saturday install. Thanks for the words of advice on the installation. My biggest concern is making the cuts on the bumper/flares.
    Looking forward to the pictures for the clearance lights and signals!
  12. Nov 7, 2016 at 1:43 PM
    #72
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Just used the Maxtrax mounting pins, and drilled/installed them in the Prinsu Designs crossbars.
    Stu488[QUOTED] likes this.
  13. Nov 7, 2016 at 2:30 PM
    #73
    kumis81
    kumis81 Well-Known Member
    2016 Tacoma SR5 V6 4x4 TRD PRO 17" wheels
    Awesome.
  14. Nov 9, 2016 at 7:10 AM
    #74
    Skeeter42
    Skeeter42 Well-Known Member
    Colorado
    2017 TRD OR DCSB 4WD Quicksand (MT)
    This build is some serious inspiration! Solar panel on the black vinyl was a great idea. I'd love to see a write up on your solar electrical set up and parts! Also did you purchase the vinyl pre-cut?
  15. Nov 9, 2016 at 8:25 AM
    #75
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Thanks. The vinyl was done by a local guy, I've had some people contact me about it, and might could even get some made.
    and a better pic of the Quick sand, as I've been asked.
  16. Nov 9, 2016 at 8:23 PM
    #76
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Just wanted to follow up again to see if you had a chance to grab the pictures of the connections for the signals and clearance lamps.
    Thanks!
  17. Nov 11, 2016 at 3:42 PM
    #77
    RANGER13
    RANGER13 RLTW
    So Cal
    2017 Black Tacoma DCSB TRD OR 4x4
    Icon Stage 4 lift kit w/17 in ambit 4RR wheels and toyo open country at2 tires, ARB Twin air compressor, ARB breather kit, Plasti-Dip Grille, emblems and rear bumper, windo tint. Prinsu cab rack and black oak 30" single row 5 watt orsam LED bar enroute.
    Waiting on my 17 to come in... definitely going to be stealing a few of these mods... awesome build bro!! SUB'D
    mtnlobo1 likes this.
  18. Nov 11, 2016 at 3:53 PM
    #78
    ctfriel
    ctfriel @Overland_NC
    Winston-Salem, North Carolina
    2017 TRD OR AT (@overland_nc)
    Basic overland stuff...
    I'll give you $500 for the truck. All kidding aside JD runs Mid State Toyota's service department in Asheboro, NC and has been a huge help to our build. Excellent prices and a dealer that understands modified Tacomas.
    I'd bet he can match the price for any ARB item you're looking for.
    Mitch09 and dorton[QUOTED][OP] like this.
  19. Nov 17, 2016 at 7:19 AM
    #79
    dorton
    Winston Salem NC
    2016 TRD Off Road
    I have been looking forward to my ARB Safari Snorkel arriving for a while now. We received a shipment with them on Tuesday, so like a kid wearing a
    new pair of shoes out of the store, I had to go ahead and put it on.
    The install is easy(hardest part besides getting the nerve up to cut the hole, is removing the fender liner clips), and the fit/finish
    is as you'd expect from and ARB product. I'm really happy with it.
  20. Nov 17, 2016 at 7:44 AM
    #80
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Odd Question: What is the height of your truck? With rack, without tack?
    Are you pleased with the ARB bumper, that is the one I wanted but I struggle with how far it sticks out in front of the wheels?
