Poor acceleration/power when a/c or blower is on
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmazur, Sep 1, 2013.
  1. Sep 1, 2013 at 5:00 PM
    jmazur
    jmazur [OP] Member
    Justin
    Pittsburgh, PA
    04 SR5
    I've recently noticed when the a/c is on, or even just when the blowers are on, the acceleration/power is not the same as when their off. It also sounds like the compressor is cycling on/off more frequently. Any chance it's not the compressor that needs replaced? I plan to replace the belts soon as they haven't been changed and truck has 145k-not sure if that could be related to the issue I'm having. Thanks.
  2. Sep 1, 2013 at 7:09 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    that's normal, unless the compressor is dragging or the belt is too tight
  3. Sep 1, 2013 at 9:07 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    If you've never replaced the belts then I doubt they are too tight unless you've tweaked them yourself. Compressor could be going bad and getting tight, but they won't do much compressing when too tight and you should quickly notice your A/C not blowing cold if the compressor is heading south.
    I would guess the compressor sucks 20 HP+/- when engaged.
  4. Sep 4, 2013 at 4:05 PM
    jmazur
    jmazur [OP] Member
    Justin
    Pittsburgh, PA
    04 SR5
    Thanks for the info. Gonna replace the belts and see what happens.
  5. Sep 4, 2013 at 4:37 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I feel the power drain when my A/C is on. The truck is only 140hp at the wheels, so any drag is going to be felt.
