Poor Air Flow after blower motor connector replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Allypally04, Aug 5, 2022.
  1. Aug 5, 2022 at 11:01 PM
    Allypally04
    Allypally04 [OP] New Member
    Alaini
    I have a 2011 Toyota tacoma and i had to replace the blower motor connector today (little white plastic piece), I got it all plugged back in and the blower motor is blowing but I'm not sure it’s blowing as much as it used to. the air is coming out of the vents at about 40% on all settings and I was wondering if anyone thought that maybe it could be the resistor (it worked perfectly fine before the connector replacement) or maybe i need to resplice the wires. Thanks for your help in advance!
  2. Aug 5, 2022 at 11:05 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Most likely the resistor, they fail pretty often and getting a good connection at the plug may have changed the current draw and blown yours that was probably on its last leg.
    JoshS and Allypally04[OP] like this.
  3. Aug 6, 2022 at 6:11 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you reversed the wires, if the motor is running in reverse it's not gona blow much.
    Key-Rei and Allypally04[OP] like this.
  4. Aug 6, 2022 at 7:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    On high you do not use the resistor so that should help you determine if its the problem. Do you have a clean filter in there.
  5. Aug 6, 2022 at 2:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Blower Motor Connector - Is two wires + and - and plugs directly into the blower motor. If connected backwards it will run in reverse and produce very little air.
    Speed Resistor Connector - Is four wires, plugs into the resistor pack inserted into the air duct under the glove box. If connected incorrectly will cause incorrect air flow.
    Which connector did you replace?
