Poor fuel mileage and very sooty tailpipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steadfast, Aug 23, 2022.
  1. Aug 23, 2022 at 1:52 PM
    Steadfast
    Steadfast [OP] Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Based on these two things, I will assume I am running rich. My 2013 Limited 4L is not throwing any codes, IE, the check engine light is not on. My mileage is 17 Miles per US Gal (14L/100km). with mostly highway driving. I think that should be 20 and 12 respectively.
    From the google searches that I've done, the major causes of running rich are MAF sensor, O2 sensor and/or MAP sensor. Is there anything I'm missing? Because the truck is 9 years old and has over 200,000 km /120k miles on it, does it make sense to just replace all the sensors? Do they degrade gradually over time even though they are still operating within the parameters... possibly. What are your thoughts and or experiences? Thanks
  2. Aug 23, 2022 at 1:58 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Watching
  3. Aug 23, 2022 at 2:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    17mpg at 70mph unloaded is about right for a stock truck.
    Monkeybutt2000, DocJ, Auzea and 2 others like this.
  4. Aug 23, 2022 at 2:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Fuel trims will tell you if there is a problem
  5. Aug 23, 2022 at 2:22 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Mine does 20 to 21 under those conditions.
    wi_taco and Steadfast[OP] like this.
  6. Aug 23, 2022 at 2:28 PM
    nd4spdbh
    SoCal
    I guess full stock (im 2in lift, 265/75R16 lighter tires which is mostly stock) that sounds about right.
    Much above 65mph though these trucks brick aerodynamics suck.
  7. Aug 23, 2022 at 2:30 PM
    Raylo
    MD, USA
    Moreso if you have a lift or "level". There is an aerodynamic reason for the slight rake. And it is, IMO, also the best look.
  8. Aug 23, 2022 at 2:33 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    It certainly sounds like you're running rich. Just because the MIL hasn't been set doesn't mean there aren't one or more pending codes. You need a scan tool with live data capability so that you can view your fuel trims in real time; assuming they're going to be totally out of whack, you then need to work on why. Any, some, or all of the sensors mentioned could be a culprit, but with no MIL, it's unlikely as circuit high/low/out of range errors will normally set the MIL almost immediately (one or two trip detection logic).
    DO NOT just fire the parts cannon - you could have an 02 sensor that isn't working, but it might not be the sensor, it could be a broken wire in a harness five feet away. You could replace 02 sensors all day and not solve the problem. You will likely need to have some basic trouble-shooting skills, wiring diagrams, a good DVOM and scan tool to sort this out.
    Evostaco and Steadfast[OP] like this.
  9. Aug 23, 2022 at 2:39 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Depending on your driving style that isn't too far off. My 2007 DC 4X4 is usually somewhere between 18-19 mpg for road trips. Around 16-17 for my normal everyday driving. I've hit 20 mpg a few times under ideal conditions. That is keeping speeds UNDER 70 mph. 70 mph seems to be the threshold. Above that and fuel mileage goes down fast, 15-16 mpg at 75 mph. I've had a couple of tanks since buying the truck where I hit 22 mpg. But that was on 2 lane roads were the typical speeds were around 50-55 mph with no stops or slowdowns.
    wi_taco likes this.
  10. Aug 23, 2022 at 2:42 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    What tester do I need for that?
  11. Aug 23, 2022 at 2:44 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    My tester does not show any codes or problems. A green light was lite.
  12. Aug 23, 2022 at 2:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A scan tool that can display live data, fuel trims ideally shouldn't be more than +/-10% total trim (long term+short term) on both banks.
    Have you ever changed your spark plugs? If not you are about 90k overdue.
    Raylo and Steadfast[QUOTED][OP] like this.
  13. Aug 23, 2022 at 2:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Any tool that can look at generic OBD2 data
    Dm93 likes this.
  14. Aug 23, 2022 at 2:54 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Thanks. The plugs were changed last year and the injectors were cleaned. I will have to buy a live scan tester however. Is there a brand that is recommended?
    I have an OBD2 scanner but it does not test live data as far as I can tell.
  15. Aug 23, 2022 at 3:00 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    My tester is the Innova 3100 abs. It shows all good. No fuel trims shown.
  16. Aug 23, 2022 at 3:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The data info isn't a pass or fail type of thing. You're looking for live data on the screen while driving down the road. Coolant temp, calculated load, engine rpm, etc
    Might need a different tool
    Raylo and Steadfast[OP] like this.
  17. Aug 23, 2022 at 4:00 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Is this vehicle bone stock right down to the tire sizes?
  18. Aug 23, 2022 at 4:04 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Lifted 2 inches and tires are 32"
  19. Aug 23, 2022 at 4:14 PM
    nd4spdbh
    SoCal
    Oh yeah, perfectly normal MPG's with that.
    Raylo likes this.
  20. Aug 24, 2022 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    My thoughts? That's just about right. What make you think it's running rich? Soot in the tailpipe is normal it's the coldest part of the exhaust system. My 2011 had a O2 sensor fail at about 80K they don't go half bad. My manual trans 4L truck will do 20 at reasonable speeds but that's about it.
