Poor fuel mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma girl 2021, Jan 30, 2021.
  1. Mar 3, 2021 at 6:38 PM
    #161
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    It seems some trucks just get poor gas mileage. I complained about mine for the entire warranty period. No one did anything but say we will look at it next time. i could either give up or drive it through the front doors of the dealership. I like my truck. Everyone who says it's how you drive it or this or that is wrong. It gets horrible mileage.
    215Grappler and taCOMA54 like this.
  2. Mar 3, 2021 at 6:58 PM
    #162
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    What about all the owners who get 25+ MPG? I would consider anything about 20 pretty good for a truck, especially one with a V6.
    Vmax540 and Junkhead like this.
  3. Mar 3, 2021 at 7:01 PM
    #163
    BOSS-DS2
    Sam
    Texas
    I noticed the same with my truck. When it was stock and I was averaging 16-17 I towed a trailer a couple times, once with a Japanese mini truck (around 2,000 lbs) and once with my 91 MR2 (around 2,800) and the trailer along weighs 2,500. Even towing that at highway speeds and through the city I only lost around 2-3 MPG, I couldn’t believe it. I drive with a heavy foot, even more so when I first bought it. I know if I drove “normal” I could get pretty good gas mileage, that and if I didn’t have 34” mud terrain tires.....
  4. Mar 3, 2021 at 7:11 PM
    #164
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Downhill all the way... :rolleyes:
    balljoint likes this.
  5. Mar 3, 2021 at 7:15 PM
    #165
    BOSS-DS2
    Sam
    Texas
    The difference in your tires is 8%, meaning if your computer says you’re averaging 18 MPG, you multiply that by the percentage difference and then subtract. Which in that case would mean you’re really averaging around 16.56 MPG as opposed to 18.
    helix66[QUOTED] likes this.
  6. Mar 3, 2021 at 8:23 PM
    #166
    Sunsetsearider
    San Francisco
    Yep, I think there is some reason that fuel economy varies for some reason. There are people are bewildered that others get the opposite, because no matter how they drive, theirs is the same.
  7. Mar 3, 2021 at 8:42 PM
    #167
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    How did you track yours?
  8. Mar 3, 2021 at 9:03 PM
    #168
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    This is my first new vehicle in 15 years and I have always used my trip odometer to assure me that I will not run out of gas—I just like planning my gas trips and will not stop just because I am getting low. Well, with my new Tacoma last week the computer said I had 5 miles until empty and I was really afraid that I would run out, being on the freeway about 15 miles from where I was stopping for gas. Well, it just didn’t move anymore because it really is a fake value. I got gas knowing I should have a few gallons left relative to my odometer calculations and I did. Has anyone ever gone “negative”on the mpg computer? Really, manual calculations are the only dependable method. I can’t tell you how many times I have driven with the low fuel light on over my many years of driving.
  9. Mar 4, 2021 at 6:04 AM
    #169
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yeah, but when i've been up there many refer it takes about 4.5 liters to make an imperial gallon vs about 3.8 for our u.s. gallon. If your from the u.s., and go by them you'd get more mpg when driving up there. You also empty your pockets a lot quicker to.
  10. Mar 4, 2021 at 6:20 AM
    #170
    BOSS-DS2
    Sam
    Texas
    It simply goes to zero and then says “please refuel”.
    Edit: I now think you were referring to the MPG mode itself and not the “miles left in tank”, whoops.
  11. Mar 4, 2021 at 6:24 AM
    #171
    Barrister
    Dennis
    Mesa, Arizona
    No, you were right. I meant “miles left in tank.” Thanks for the info.
  12. Mar 4, 2021 at 6:26 AM
    #172
    BOSS-DS2
    Sam
    Texas
    You’re welcome. There is a sort of “reserve” in that the system tells you it’s empty when it really isn’t. In six years I only got that low twice, so I don’t remember how much fuel was left, but if you’re getting sub 15MPG it isn’t enough to make you feel like you should keep driving. That being said in the city it’s likely fine, but here I may have to drive 15-20 miles to get gas.
  13. Mar 4, 2021 at 8:45 AM
    #173
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Both my Gen1 and Gen2 Tacoma's had ~3 gallons left once the low fuel light indicator came on.
    Gen 3 "0 miles left" indicator happens at the same point the Gen2 and Gen1 low fuel light comes on.
    Charlie Too and BOSS-DS2 like this.
  14. Mar 4, 2021 at 12:56 PM
    #174
    taCOMA54
    taCOMA54 Active Member
    Jacksonville, FL
    2021 Cement TRD Off-Road DCLB
    Ceramic Pro Silver
    I’m fairly certain that any owners getting 25+ mpg are either doing 80% of their driving consistently cruising below 60 mph or their settings are set to Imperial gallon and not US gallon.
    gman2431 and Malvolio like this.
  15. Mar 4, 2021 at 12:58 PM
    #175
    BOSS-DS2
    Sam
    Texas
    It’s not as if the Government tests the fuel efficiency at 85, 60-65 is usually their baseline.
    Malvolio, usmc2msu and RedWings44 like this.
  16. Mar 4, 2021 at 1:27 PM
    #176
    Fast1
    Minneapolis, MN
    You can drive down from the top of a mountain pass.. say Eisenhower tunnel to Denver in Colorado and get 25 mpg easily.. I got near 30 mpg with my 4 banger 4x4 Std Cab last year doing this.
  17. Mar 4, 2021 at 1:32 PM
    #177
    taCOMA54
    Jacksonville, FL
    Ceramic Pro Silver
    I get that. But I find it odd that my first gen v6 PreRunner got 18 mpg cruising at 80 mph, and my 2021 cannot even match that.
    And yes, of course you can get 25-30 mpg in certain circumstances. But averaging that with this truck over the long run is damn near impossible, hence my statement.
  18. Mar 4, 2021 at 1:35 PM
    #178
    BOSS-DS2
    Sam
    Texas
    It’s also a larger truck than the first generation Tacoma.
    Malvolio likes this.
  19. Mar 4, 2021 at 1:39 PM
    #179
    boiledowl
    boiledowl Well-Known Member
    a friend said his friend is getting 30mpg in a new full size chevy. These Tacomas get horrible mileage for some reason and now gas is hitting close to $2.70 a gallon.
  20. Mar 4, 2021 at 1:41 PM
    #180
    taCOMA54
    Jacksonville, FL
    Ceramic Pro Silver
    Yes it is. Overall I’m happy with the truck. But considering there are proven and relatively easy ways to make ICE much more efficient I wish Toyota would have done so. The ranger has also gotten bigger but their fuel economy is the same as their old 4 cylinders, and with even better power ratings than the Tacoma. And I am by no means a Ford guy. I hate fords. But downsizing and turbocharging was a fantastic move that Ford has been implementing in all of their vehicles and the rest of the industry should have followed suit by now.
