Poor gas mileage...tried almost everything
Discussion in '1st Gen. Tacomas (1995-2004)' started by etprry, Jan 19, 2011.
  1. Jan 19, 2011 at 9:43 AM
    etprry
    etprry [OP] New Member
    I bought a 98 tacoma 2.4 5 speed a few months back as was getting terrible gas mileage (17-18) even with premium. It was throwing an O2 sensor code and throttle position sensor code so I replaced the pre-cat O2 sens and cleaned the throttle body. Mileage went up to about 23 and lights didn't come back. Still wasn't happy so I ran several cleaners through the system (including seafoam), change the air filter, cleaned the MAF, replaced the jiggle valve, replaced the spark plugs and wires and replaced the vacuum hoses, not to mention keeping the tire pressure up and an alignment. So far the light hasn't been on for prob 500 miles but still can't get more than 25mpg even with Chevron premium on the highway with a light foot. My old 96 Taco got 30+ on the highway.
    I have thought about changing the post-cat O2 sensor and throttle position sensor but without a code I don't want to throw away good money. Any suggestions??
  2. Jan 19, 2011 at 10:46 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    don't waste your money on the post cat sensor. First of all, it doesn't affect fuel trim. Plus you would have a code saying "catalyst efficiency below threshold" or something similar. It's only job is to tell if the cat is functioning. If your TPS is bad, it could affect mileage.
  3. Jan 19, 2011 at 10:47 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    What size/type of tires?
  4. Jan 19, 2011 at 10:48 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    what is the long term trim reading ?
  5. Jan 19, 2011 at 3:39 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    a gummed up/bad coolant temp sensor would give you shitty gas mileage...
  6. Jan 19, 2011 at 4:14 PM
    thatSchusterguy
    thatSchusterguy Well-Known Member
    Cincinnati, OH
    96 X-Cab
    OME/881 Dakars Demello HD sliders Marlin 1200# Clutch Rust and Duct Tape
    If the engine's not knocking you aren't doing any good putting premium into it, and if you want good MPG's get a car? 25 is decent for driving something with the aerodynamic efficiency of a brick...
  7. Jan 19, 2011 at 4:16 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I wish my 96 got 25 mpg!
  8. Jan 19, 2011 at 4:21 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    The best I ever got with my '99 Extended Cab 2.4 automatic was 26 MPG. The worst was 14 MPG. I think you're in the ballpark.
  9. Jan 19, 2011 at 4:29 PM
    BritMike
    BritMike Well-Known Member
    NJ
    10 Black TRD OR
    25 mpg during crappy gas season isn't bad at all.
    My old 96 2.4 regular cab 4x2 5 speed got 30 highway. The 98's may be a touch heavier plus that engine is probably 20hp down from new just from being that old. Heavier / more aggressive tires could contribute as well.
    I wouldn't worry about it too much.
  10. Jan 19, 2011 at 6:44 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    your mpg is average for what it is. shouldn't be anything wrong
  11. Jan 19, 2011 at 7:03 PM
    etprry
    Its got stock tires. Might take a look at the coolant temp sensor. Its not bad mileage. Just wanted to know if there was anything else obvious I'd overlooked.
  12. Jan 19, 2011 at 8:30 PM
    kingbrian
    kingbrian Resident Big mouthed Fat ass.
    brian
    I.E. CA.
    98 2.4 5 speed xtracab
    Fagtech spindles, Doug Thorley header, Spintech muffler, JVC headunit.
    i think you guys getting over 30mpg's are crazy. not impossible just if i had to drive that way i would shoot myself in the face (alot). i shift at 2000 rpm and i squeeze 24.6 mpg but my drive is very harsh.. i think 30 may be possible but i cant see these trucks getting any better. just my opinion.
  13. Jan 20, 2011 at 9:14 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    how do you get 24+ mpg?
    is it all highway driving?
