Poor Gas Mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by bandersnatch, Oct 24, 2023.
  1. Oct 24, 2023 at 11:42 AM
    bandersnatch
    bandersnatch [OP] Active Member
    Ross
    1999 Tacoma TRD
    Recently purchased a 99 3.4L RWD Auto. 220k. running on 265/70/17
    I have completed a host of deferred maintenance.
    Spark plugs
    Thermostat
    Coolant flush
    Crank and Cam sensors
    Drive shaft bearing
    Fully clean throttle body and IAC (new gaskets on both)
    Cleaned MAF sensor.
    New air filter
    Oll change with filter
    greased every zerk I could find..
    Just did the math on my last tank and it came out to 10miles/gal.
    CEL works but not illuminated. No Codes
    Where should I start to get better mileage?
    edit for more info:
    45 mph
    1450 rpm
    Stft -0.78
    Ltft 2.34
    Maf 14.81 g/s
    idle
    705 rpm
    Stft -1.56
    Ltft 5.47
    Maf 4.76g/s
  2. Oct 24, 2023 at 12:07 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Are you absolutely certain about your mpg calc?
  3. Oct 24, 2023 at 12:12 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Filled the tank last week and set the trip meter. Today I thought I would be making a trip out of town and decided to fill up before I left. When I arrived at the pump the trip showed that I had traveled 120.2 miles since last fill up. I put 11.79 gal in the tank. 120/11.79=10.17. I will be the first to admit I am terrible at math but I think that is correct. But I have been wrong before…
  4. Oct 24, 2023 at 12:17 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Your estimate should be accurate for a rough estimate. Start using an app to track mileage over a handful of fill ups to get a better gauge but certainly 10mpg ain’t right if that’s actually accurate. Does the engine appear to run and idle fine? Maybe do a test on the coil packs and wires to see if they need replacing?
  5. Oct 24, 2023 at 12:20 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    What test can I do?
    Never tested wire or coil packs before. Those generally throw a code when they are bad? Also added some fuel trim data to the orginal post
  6. Oct 24, 2023 at 12:31 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    What size are your tires compared to what's on the door sticker?
    Clearwater Bill likes this.
  7. Oct 24, 2023 at 12:40 PM
    ztwatson
    Milwaukee, WI
    Not sure about how to test a wire. This is how to test the coil pack…
  8. Oct 24, 2023 at 12:41 PM
    EL DUDE
    EL DUDE Well-Known Member
    My single cab 99 with 50k miles and 4cyl got 17-20 max. If the truck is paid off, live with it.
    my 05 gets 13-16.
  9. Oct 24, 2023 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Run a GPS speed test and see how far off your speedo is. My guess is those tires are 'under reporting' both speedo and odo.
    Take the tire calculator and compare stock to what you have, use that % to up your miles driven, and you'll get a better number.
    Digiratus likes this.
  10. Oct 24, 2023 at 1:01 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Per the door. 225/75 r15
  11. Oct 24, 2023 at 1:07 PM
    Clearwater Bill
    Billy
    Largo Florida
  12. Oct 24, 2023 at 1:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am not convinced what the door sticker states is always accurate. FWIW, mine says the same 225/75r15, but it is a TRD model that came with 265/70r16s with 4.10 gears.
    Some of it is going to be the larger than stock tires. Do you have a lift on it? Weight will cause a sharp decrease in MPGs too.
    Andy01DblCabTacoma likes this.
  13. Oct 24, 2023 at 1:41 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Truth be told, I'm not either, but it's a start
    Digiratus[QUOTED] likes this.
  14. Oct 24, 2023 at 2:41 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Mine is the TRD off road also, hard to imagine such small tires/rims being stock.
    No lift
  15. Oct 24, 2023 at 2:49 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
  16. Oct 24, 2023 at 3:06 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is that city or hwy mileage?
    Is the torque converter locking up when it should?
    How are the vacuum hoses?
  17. Oct 24, 2023 at 3:09 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    City mileage.
    Umm, I don't know. How can I tell if the torque converter isn't locking up as it should?
    I have replaced a lot of the vac lines. It is a work in progress...
    I am actually looking at the FSM for the Vac line diagram, but i cant find it. Anyone know what section that is in?
  18. Oct 28, 2023 at 3:55 PM
    Babyota
    Babyota Member
    Jay
    1998, base, auto 2wd sc
    Bone stock
    I recently replaced my O2 sensors with denso. The previous owner used an unknown brand. I went from 23.3 to 25.01mpg. I got 23.3 for 38,000 miles. Never less or more my commute is very consistent. I was shocked the last two tanks. I normally have to fill up every Thursday. I can make it all week now.
    Reg cab, 5 lug 2.4L.
    Make sure the coolant temps are correct. My fan was locked up for about 1000 miles and the mpg dropped to 22ish
  19. Oct 28, 2023 at 3:57 PM
    Babyota
    Babyota Member
    Jay
    Bone stock
    Get up to about 50 mph and hold the speed. Without taking your foot off the accelerator tap the brake pedal. The engine rpms should just jump slightly.
  20. Oct 28, 2023 at 4:20 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Will try this
