  1. Jul 1, 2020 at 8:28 PM
    zippsub9
    zippsub9 [OP] Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Tacoma BIG BRAKE KIT, brand new in the boxes. This is the popular 13WH upgrade using 4th Gen 4Runner/Lexus GX470 parts. This is the largest you can go before needing an upgraded master cylinder to avoid soft pedal. I did not mount these since I swapped over to a Tundra master, dual diaphragm tundra booster and 14WB calipers. I also have a rear disc conversion that I will post up shortly that would pair nicely.
    EBC rotors & yellow stuff pads.
    Cardone Ultra calipers
    Over $450 new....400 shipped CONUS OBO
    Grumpy, seoulja99, whatstcp and 2 others like this.
  2. Jul 1, 2020 at 9:31 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Ping me when you get the rear conversion posted, might be interested in both depending on price
    Mgevry@gmail.con
    zippsub9[OP] and KnckleChldrn like this.
  3. Jul 2, 2020 at 8:07 AM
    BrianTaco75
    BrianTaco75 Well-Known Member
    Brian
    1995 Taco / 2019 Taco
    looks like a great kit, so does that mean you went aftermarket on big brakes with adding the Tundra brake master cylinder?
    zippsub9[OP] likes this.
  4. Jul 2, 2020 at 8:12 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I stripped a '19 wrecked Lexus GX 460 and modified all four corners for my truck but had to use a Tundra master and vacuum setup.
    I also have an adapter for a Tacoma to mate up with a Tundra master I can throw in for the right price on the whole setup.
    The rear disc does NOT have a parking brake option. I will post more details later, but it is used.
  5. Jul 2, 2020 at 11:58 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Might want to state that this requires 17” wheels. If that’s the case which I believe it is.
  6. Jul 2, 2020 at 12:03 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    yes sorry. I put it in another section but not this one. It requires 17” rims only unless first gen then requires 17” aftermarket or OEM 17” plus 1” spacer.
  7. Jul 2, 2020 at 7:35 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Posted up in the Other Buy Sell Trade Forum if interested.
    900 shipped for all four corners plus adapter to bolt on a tundra master cylinder to your Tacoma booster.
    Grumpy likes this.
  8. Jul 2, 2020 at 8:22 PM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Did you documented your front/back break conversion and took pics? You should start a new DIY thread with your upgrade!!:thumbsup:
  9. Jul 2, 2020 at 8:31 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I know, I suck at this. I will get some pics and capture key points but there are quite a few that have done this and the info is already out there. I am helping with a demo axle for Tom at SOS Performance. I will take pics of this process for that part and I still have the booster and master to go.
    STrooper[QUOTED] likes this.
  10. Jul 5, 2020 at 8:52 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  11. Jul 9, 2020 at 7:01 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  12. Jul 14, 2020 at 3:21 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  13. Jul 14, 2020 at 3:36 PM
    Tacotrd_17
    Tacotrd_17 Well-Known Member
    Tampa, FL
    2017 TRD OR Silver Sky Metallic
    Is the rear brake disc conversion also new in the box?
  14. Jul 14, 2020 at 3:44 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    no. I have pics up of it. It has less than 10k on it though. I was only run for about six months. January to June in PA.
  15. Jul 14, 2020 at 3:45 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  16. Jul 14, 2020 at 3:45 PM
    Tacotrd_17
    Tampa, FL
    how come you are selling the conversion?
  17. Jul 14, 2020 at 3:51 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    This kit came on an axle
    I bought. I bought the kit with parking brake option instead of keeping this one. The parking brake helps me set my trailer level.
  18. Jul 15, 2020 at 12:33 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    What is Big about this brake kit? Each calipers still have only 2 pistons each similar to the stock Tacoma brake calipers. Asking because I don't understand what's different?
    (On my last brake upgrade, I changed my pads to the TRD brake pads and replaced rotors to Stoptech slotted cryo rotors as my stock rotors had developed a lip and scratches. I put Bigger AM wheels, tires.)
  19. Jul 15, 2020 at 12:48 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    05-present are 13WG 319mm rotors, same number of pistons and same size piston.
    13WH are utilizing 338mm rotors for greater leverage and stopping power. This isn’t BIG in the grand scheme just the largest you can go on a stock Tacoma master and vacuum booster without getting a soft pedal. Hope that helps.
  20. Jul 15, 2020 at 1:57 PM
    bacon_st
    San Diego
    16' Taco TRD sport
    Isn't the larger brake pad that improves stopping? I get that the 13WH has a few mm's more of rotor surface area, but if the brake pad surface area is the same, and amount of hydraulic pressure, number of calipers all the same, there isn't any stopping improvement. Is that correct understanding?
