Poor Man's Recovery Shackle "Hitch Mount" - under $25
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A7XT, Jan 13, 2011.
  1. Jan 13, 2011 at 5:10 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I admire your ingenuity however I would say that that setup is very unsafe. I would recommend either getting a shackle mount like what Warn sells or just using the recovery strap on the pin. I think the abrasive action on the strap is an acceptable loss considering the cost. I would be very concerned about the bolt, the shock load placed on the chain and a 5/8" shackle. When one of those fails you will have a very dangerous missile on your hands. Please read here for some valuable info regarding recovery and potential strain you could encounter.
  2. Jan 13, 2011 at 5:19 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    When it says "Maximum load capcity: 10,000 lbs." is this the WLL or the breaking strength?
    The other shackle brackets I've seen say ~10k capacity but don't specify WLL or breaking strength so I assume it to be WLL.
    A grade 'A' 3/4 shackle has about ~50k lbs breaking strength. A 5/8 shackle ~30k, and a 1/2 shackle ~20k. My straps have a rating of 27k breaking strength. So they should be the weakest link when I hook up using a 3/4 shackle. I'm just curious about these blocks.
    I personally wouldn't use the chain either though.
    Shackle strengths
    Another good read
  3. Jan 13, 2011 at 5:19 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    ^^ Gotta agree with Kilted. Do it right the first time and get a proper setup before somebody gets injured... Good luck!
  4. Jan 13, 2011 at 5:53 PM
    A7XT
    A7XT [OP] Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    Yeah i agree with the dangerous part if anything was to snap, probably should upgrade. Just thought I would throw an idea out thanks for the input guys
  5. Jan 13, 2011 at 6:04 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    My Buddy did something like that it bent the bolt.
  6. Jan 14, 2011 at 2:35 AM
    Edcrosbys
    Edcrosbys Active Member
    Northern va
    07 DC TRD
    The chain isn't the part is would have concerns about. If it was rated approximate 10k lbs, that ** SHOULD ** have been the WLL with a 4:1 safety ratio. The bad news is that the grade 8 bolt has between a 20k and 30k limit ( and that isn't accounting for the lack of even pressure across the bolt). Hopefully your using a 10k strap as the weak point.
    Straps stretch, if the bolt were the weakest point that chunk of chain would hurt.
  7. Jan 14, 2011 at 5:36 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
  8. Jan 14, 2011 at 5:48 AM
    Tinfish
    Tinfish Active Member
    2013 Reg Cab 4x4 5spd
    That was my first thought looking at that. A broken strap is no big deal, but a broken bolt (or if the chain breaks in the middle) can go right through the windshield. This is why you are supposed to use straps that don't have hooks on the ends.
    Youtube is full of videos of what happens when a strap breaks with something heavy at the end:
    http://www.youtube.com/watch?v=hAY0oVwuzNY
    http://www.youtube.com/view_play_list?p=1BE3683B45A0293A
    Just put a hitch pin in there and hook the strap onto that. It's ok if it gets frayed; that's way better than half-assing it to save $5 and killing someone by having that cheesy bolt/chain setup come through their windshield.
  9. Jan 14, 2011 at 7:31 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Gotta love youtube. Glad no one was hurt, that could have ended badly.
  10. Jan 14, 2011 at 8:01 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have an extra draw bar with no ball in it. I just put my shackle through the hole where the ball would usually be.
  11. Jan 14, 2011 at 8:12 AM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    What about the says 10k lbs only $20
  12. Jan 14, 2011 at 8:23 AM
    Sprink669
    Sprink669 Well-Known Member
    I will stick with my Warn receiver. There is no way I would trust that thing with the chain and bolt. You should always put a heavy blanket on the rope or strap so that wouldn't happen. If the strap or rope would break it would just fall to the ground if it had a blanket on it.
  13. Jan 14, 2011 at 8:38 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
