Poor Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Msmith89, Aug 27, 2016.
  1. Aug 27, 2016 at 7:28 PM
    Msmith89
    Msmith89 [OP] Member
    Melissa
    Brooksville, Fl
    2013 Tacoma TRD Sport Manual
    Bf Goodrich all terrain 285. The tires that were on it before were the big Sky mud tires. 285 as well. I would like to put a cold air intake on soon to help a little. And ito probably help if I didn't drive it like I'm in a Baja race.
  2. Aug 27, 2016 at 7:28 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Yeah, if it was going down before the tires, then something else. Tune up on these trucks is pretty easy. No cap, rotors, spark plug wires, or fuel filters to deal with. Just plugs and engine air filter.
    Msmith89[QUOTED][OP] likes this.
  3. Aug 28, 2016 at 7:34 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    A cold air intake won't do anything for the gas mileage. If the truck is running well a plug change will be marginal. Stop driving like your in a Baja race will have the biggest effect.
    Msmith89[OP] likes this.
  4. Aug 28, 2016 at 9:53 AM
    Pigpen
    Dan
    Northwest Montana
    Melissa
    Are you compensating for tire size in your mpg calculations? 32.5/ 30.5 X miles driven/ gallons pumped?
  5. Aug 28, 2016 at 10:01 AM
    Msmith89
    Melissa
    Brooksville, Fl
    Yes. Just figured these toyota trucks got shitty mileage
  6. Aug 28, 2016 at 10:02 AM
    Msmith89
    Melissa
    Brooksville, Fl
    I bought this truck when I lived in Billings. I purchased it from Denny Menholt on the west end
  7. Aug 28, 2016 at 10:03 AM
    moondeath
    Pa, Gardners
    Not all get terrible mileage. I currently average 20 mpgs. When I first got it with the factory tire size I was getting 22 mpg.
  8. Aug 31, 2016 at 6:32 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Yes. Stop driving it hard and change out those plugs. You should be on your 3rd set by now - every 30k.
    Abrams65 and Msmith89[OP] like this.
  9. Aug 31, 2016 at 6:40 PM
    Msmith89
    Melissa
    Brooksville, Fl
  10. Aug 31, 2016 at 6:50 PM
    eon_blue
    Azusa, CA
    If you're running the stock copper plugs and haven't changed them yet at 66k miles, then I bet that's a big part of your problem.
  11. Aug 31, 2016 at 6:54 PM
    Msmith89
    Melissa
    Brooksville, Fl
    Yes I have to get a tune up because they haven't been changed yet in the life of the truck...
  12. Aug 31, 2016 at 7:03 PM
    charliedeltajuliet
    charliedeltajuliet Well-Known Member
    Mountains of NC
    2006 Impluse Red TRD-OR
    I am averaging 19.5-19.7mpg it the last 5 tanks of fuel. Mine is an 4.0l automatic. Mine has been leveled. I would definitely check the air filter, plugs, etc.
  13. Aug 31, 2016 at 7:10 PM
    Msmith89
    Melissa
    Brooksville, Fl
    The air filter was a little while ago, but I'm gonna change it when the tune up is done.
  14. Aug 31, 2016 at 7:10 PM
    Msmith89
    Melissa
    Brooksville, Fl
    The best mileage I've ever got was 15 in town, whether I drive like a granny or not.
  15. Aug 31, 2016 at 8:07 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Welcome to the forum Melissa. :wave:
    Which brand stations do you use to fill up, if you don't mind?
    I might have over looked it, since so many asked, but what is you current tire pressure, with the tires cold?
    Most everyone else covered the basics of what is needed to cover a good tune up, so no need to go there.
  16. Aug 31, 2016 at 8:12 PM
    #36
    Msmith89
    Melissa
    Brooksville, Fl
    I use Murphy USA, Shell, 7 Eleven and Wawa. I'm not sure what the current tire pressure is. I just got my tires rotated and balanced. They over filled the tires so my husband let some out.
    The mileage has been going downhill for at least the last 6 months. It's just terrible now so I gotta get it in.
  17. Aug 31, 2016 at 8:14 PM
    #37
    Msmith89
    Melissa
    Brooksville, Fl
    A 30 mile commute into town and back burns almost a quarter tank. ( round trip)
  18. Sep 1, 2016 at 3:21 AM
    #38
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    The only way to accurately calculate MPG is to fill up until the nozzle automatically shuts off. When its time to fill up again calculate the gallons filled with the miles driven. An example would be 298 miles divided by 17.63 gallons filled. Once you arrive at that number if you have 33 inch tires you multiply that number by 1.05. 298 divided by 17.63 equals 16.90 then multiply by 1.05 equals 17.74. The extra calculation is to compensate for the difference in the odometer with a larger tire. In my case that is 5%.
    The changing of the plugs will not make a noticeable difference in MPG unless the plugs are extremely worn. That effects emissions. The air filter loading will not effect MPG unless extremely loaded up as the computer will compensate for loading of the filter.
    Fuel can cause some degrading of MPG since some fuel contains less additives or quality of additives. The freshness of the fuel is also a factor. Top Tier fuels will normally contain better additives which will deliver slightly better MPG. I get better MPG with Mobil or BP.
    The best fuel economy is retained by reduction of throttle response from stopping. If you do a lot of stop and go and your RPM's go above 2000 each time you will consume a greater amount of fuel. Another way to save some fuel is to use full synthetics in differential, motor, etc..
  19. Sep 1, 2016 at 5:45 AM
    #39
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Around town I only get between 15-17, I dont drive like a grandpa like the guys that get 20+mpg plus.
    It's your all terrains and larger tires guaranteed. You can change the sparks but Im willing to bet that wont due squat to improve your mpg
  20. Sep 1, 2016 at 5:52 AM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @sgtnewundies , you knew exactly where I was headed with the brand of fuel.
    @Msmith89 , I highly recommend against any grocery store gas station. They do not have the same high standards or additives as sgt mentioned. Gas mileage dropping as a result of potentially to much water in their gas, higher ethanol content, and to much debris/sediment in their storage tanks which will clog filters.
