poor mpg someone help!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Yotadtc, Sep 24, 2013.
  1. Sep 24, 2013 at 9:35 PM
    2004Yotadtc
    2004Yotadtc [OP] Well-Known Member
    JAIME
    San Antonio
    2004 Pre Runner
    I recently had 265 75 16 e rated kevlar tires with a leveling kit on a 2004 tacoma 3.4 , gas mileage went down bad then I did my plugs cleaned the throttle body good and maf what else can I do to fix this sorry couldnt search the forum phone wont let me thanks any advice will help
  2. Sep 24, 2013 at 9:39 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    define bad, any actual numbers?
  3. Sep 24, 2013 at 9:42 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Installing larger size tires throws off your speed/odo. The odo will read fewer miles than you actually drove. What size tires did they replace?
  4. Sep 24, 2013 at 10:09 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    try cleaning the upper cylinders (seafoam), cleaning the injectors (concentrated techron or Redline SI-1 (redline has highest PEA of any cleaner)(PEA is the injector cleaning solvent)(avaliable at oriellys)
    When did you last change your fuel filter?
    What is your tire pressure?
    Hows your brakes? do you have a sticking caliper?
    When did you last grease your driveline, and change gear fluids?
    When did you last change your air filter?
    When were O2 sensors changed?
    Where do you get your gas? Is it a reputable brand, or is it a no-name gas station in the sticks?
    Theres a variety of things that come into play when trying to maintain good fuel economy.
  5. Sep 24, 2013 at 10:52 PM
    2004Yotadtc
    JAIME
    San Antonio
    2004 Pre Runner
    Fuel filter idk got it from grandfather I might have a sticking caliper idk 02 sensors never been changed gas is from heb bore do I grease driveline
    I'll try sea foam and that stuff!
  6. Sep 24, 2013 at 10:54 PM
    2004Yotadtc
    JAIME
    San Antonio
    2004 Pre Runner
    I got 33 12.5 15 before that had 265 75 16 e rated I get about 60 to 70 miles on half of a tank
  7. Sep 24, 2013 at 10:57 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    What % larger are the new tires than the old? did you adjust for that when you figured gas mileage? also the added weight of the larger tires will effect mileage. You can do all the standard things to improve the engine efficiency but you won't get back to the original MPG with the bigger heavier tires.
  8. Sep 24, 2013 at 10:59 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    :confused:
  9. Sep 24, 2013 at 11:01 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    so you have a 4.4% difference in overall height, but you added 20% to the width. How many gallons is half a tank?
  10. Sep 24, 2013 at 11:03 PM
    2004Yotadtc
    JAIME
    San Antonio
    2004 Pre Runner
    When I put 20 dollars it'll go to halfway at around 7 gallons not sure if it right someone told me it could be wrong
  11. Sep 24, 2013 at 11:03 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    And the gas-hand on the dash is not 100% correct
  12. Sep 24, 2013 at 11:08 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    I think the main issue is that the new 33's are far heavier and slightly taller than the old tires. you should fill up, and check how far off your odometer is by checking over a known distance or with a gps app. then see what your real MPG is. I would also check to see if the pressures are correct in the tires. with that much tire width your alignment might be off as well.
  13. Sep 24, 2013 at 11:08 PM
    2004Yotadtc
    JAIME
    San Antonio
    2004 Pre Runner
    Your saying its not?
  14. Sep 24, 2013 at 11:19 PM
    2004Yotadtc
    JAIME
    San Antonio
    2004 Pre Runner
    Do yall think my needle could be wrong?
  15. Sep 24, 2013 at 11:33 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    It could be wrong (mine doesn't move evenly or at all until I drive 80 miles or so) but you should be able to see what your mpg is anyway.
  16. Sep 24, 2013 at 11:35 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I drove 60 miles on full before it moved down.
  17. Sep 24, 2013 at 11:59 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I would do all maintenance and checks mentioned above. Then fill the tank, drive a hundred or so miles, refill the tank, and calculate the mileage. Then you'll know what your tires are really costing you :facepalm:
    Seriously, get your speedo adjusted!
  18. Sep 25, 2013 at 6:50 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Guys it's fairly simple. He's running an E-rated tire, a tire designed for V8 Full size quad cab trucks designed to tow 12,000 - 15,000 + lbs and transport trucks like UPS and Fedex trucks. This is the reason why it makes no sense unless you are heavily into rock crawling to run these kind of tires. These are puny little 190 HP V6 trucks.
    Besides regular maintenance and up keep, if you want better MPG you need to go to a passenger or lower Load range tire. Simple as that.
  19. Sep 25, 2013 at 8:22 AM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    ^ This. Why would you get E-rated (10 ply) tires for a light truck? I use a C (6 ply) or at the most a D (8 ply). The ride is much better too. A 10 ply tire will be much stiffer.
  20. Sep 25, 2013 at 8:28 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Some tires only come in some sizes in E rated
