Poor ride quality
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Mayo, Jun 19, 2025.
  1. Jun 21, 2025 at 5:08 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Interesting wheel/tire combination to go with the TRD Lift.
    I've got a 2021 TRD Sport and had the TRD Lift (2") done on April 3, 2025.
    TRD Lift uses existing OEM Coils up front and adds 1" block to the Leafs.
    I'm riding on OEM Wheels/Tires: 265/65R17s.
    The Hitachi shocks that came with the Sport were very soft and felt like an SUV suspension. (I previously owned a 2003 Honda Pilot)
    The ride is much improved to include tires take corners much better now.
    It's a firmer ride (I do mostly street driving) so I'm going out on a limb here to say, it may be your current tire set-up that's effecting your experience.
    As has been said, there are variables to your situation.
  2. Jun 21, 2025 at 5:17 AM
    D Mayo
    D Mayo [OP] Active Member
    Devin
    2021 Toyota Tacoma Off Road
    2” level with TRD lift kit. SPC UCA. 285/70/17 OME medium load leaf
    I’m on kmc 17s with ridge grapplers 285/70/17
    TacoTime55[QUOTED] likes this.
  3. Jun 21, 2025 at 5:32 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The wet noodle frame, the horrible digressive valving in the TRD Bilstein Shocks, and the E rated tires are probably the largest culprits here.
    eurowner and 71tattooguy like this.
  4. Jun 21, 2025 at 5:40 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Run those tires @ 30 psi cold. In my experience Nittos are also notoriously heavy. Do you have the stock wheels and tires to try?
    eurowner likes this.
  5. Jun 21, 2025 at 5:48 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    There are many opinions here...regarding this subject...I can't speak to the larger tires.
    Just providing the components that make up the TRD Lift on my truck as well as the difference I've noticed from the Hitachi Shocks on OEM Coils/Leafs.
    I hope you get the "poor ride" sorted.
  6. Jun 21, 2025 at 5:56 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    38 psi; yikes! Get them closer to 32 cold and see if that helps things
  7. Jun 21, 2025 at 6:02 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    TRD Sports ride like an SUV like it should. OR rides rough on roads like it should be cause they are made to ride nice off road oppose to the Sport.
  8. Jun 21, 2025 at 10:03 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My guess OP, it's the 285's.
  9. Jun 21, 2025 at 10:05 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My friend, I'm gonna guess you didn't test drive the OR because you have it backwards. The Sport has the firmer ride for better on road handling. The OR has the bigger cushier shocks for Off Roading.
    tonered and shakerhood like this.
  10. Jun 21, 2025 at 11:38 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The OR has a softer smoother ride on the street, Sport is quite stiff for spirited driving.
    tonered and MGMDesertTaco like this.
  11. Jun 21, 2025 at 2:17 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    My experience for 47 months driving the TRD Sport is, the shocks felt "spongy" on bumpy pavement making a left turn.
    The suspension would skip/hop and not engage the road...I would "slightly" go into the next lane because of the skip.
    After the TRD Lift, I tested the same left turn and found the Bilstein 5100s engaged/gripped the same road much better than the Hitachi's.
    The Bilstein's feel much firmer and negotiated the road better than the Sport's OEM shocks.
    I can compare the ride to the 2024 Tacoma Limited...which was the loaner I had while the TRD Lift was installed on my truck.
    I drove that Limited for 100 miles...from Newark, DE to Dover, DE and back to Newark.
    But as far as OP's situation, I would venture to say he needs to evaluate his wheel/tires set-up and get an alignment.
  12. Jun 21, 2025 at 3:00 PM
    twtaco$
    twtaco$ Well-Known Member
    I posted the same when I purchased my truck it was my first truck and the ride is garbage but I you’ll get use to it.
  13. Jun 21, 2025 at 7:35 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Valving makes a pretty big difference I'll say, but so does spring rate. Even with a stiffer spring rate, a pretty well valved shock will even out the stiffer spring rate, especially in the compression and rebound strokes. With a stiff spring rate and digressive valving, you'll feel every bump. Like others have said, those TRD bilsteins have that digressive valving bilstein shocks are known for. Coupled with the (I think) 700-730 lb/in, springs, the ride will suck, however you'll get really good control. I recommend looking into the OME nitrocharger sets with their coils, or a set of eibachs. I can personally attest to the OME, the springs are around 590 lb/in springs and tough the shocks are more in the middle of the road in terms of valving, the lighter springs lets the suspension compress with less force, so the ride will be softer. Coupled with the valving, they make for a pretty good ride.
  14. Jun 21, 2025 at 10:00 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    For the rear leafs, if you have the 111, they carry MEDIUM LOAD: Full passenger load with luggage weight varying from 440lbs to 771LB
    Do you have any weight in the bed? If not, you might try removing a leaf (3rd one down).
    I had Dobinson's 111 leafs, but they were way too stiff on an empty bed. Removed a leaf, and night and day difference. :notsure:
  15. Jun 22, 2025 at 1:14 AM
    #35
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    air pressure is too high.
    71tattooguy likes this.
  16. Jun 22, 2025 at 7:33 AM
    #36
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    With your cv angles I would guess your cranked up combined with tire air pressure psi ride won’t be so nice.
  17. Jun 22, 2025 at 3:53 PM
    #37
    D Mayo
    Devin
    Should they be more straight? Would a diff drop benefit me
  18. Jun 22, 2025 at 4:05 PM
    #38
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Hey OP. The Bilsteins are digressively valved which make them a bit firm for some. Depending on which OME leafs you got that could make the rear stiffer on top of the Bilsteins. And lastly the c rated tire at 38lbs. Add all those together and I could see the truck feeling really stiff. I’d personally start with putting the front tires at 30lbs cold and the rears at 28lbs. Then chalk test to see if you get the entire tread pattern on the ground. Keep us posted.
  19. Jun 22, 2025 at 4:21 PM
    #39
    D Mayo
    Devin
    Thanks will do
  20. Jun 28, 2025 at 7:53 AM
    #40
    D Mayo
    Devin
    Just a little update. Adjusted my SPC a little and aired down to 30 in all four tires. I believe this is the biggest difference maker in improving the ride. I think the tires at 30 are what’s giving me a much smoother ride. Thanks for the recommendation
