poor starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hanrock, Sep 27, 2015.
  1. Sep 27, 2015 at 3:03 PM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    hi my 2012 dclb 4.0 has begun takeing more cranks to start latley probably 80%of the time hot or cold. all seems fine to me batt has 12 volts also around the same time it seems to kick off at the pump early and can be a pain to top off . i dont know if the two are in some way relatedi have driven away from a full service pump with 3/4 of a tank due to this any advice appreciated thanx.
  2. Sep 27, 2015 at 3:15 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Vapor recovery valve or charcoal filter may be the cause for the pump shutting off before its full. I would start by making sure the vent line is ok.
    1GR-FE FUEL: FUEL TANK: COMPONENTS
  3. Sep 27, 2015 at 3:45 PM
    hanrock
    craig
    sask
    thanx sir does that vent line run to the canister and then vent some where else ive read of bugs or dirt getting in a vent line causing same prob
  4. Sep 27, 2015 at 3:57 PM
    Drivesector
    TRD sport
    Look all the way at the bottom of this, hope this helps.
    Removal
    1GR-FE EMISSION CONTROL: CANISTER: REMOVAL
    1. DISCHARGE FUEL SYSTEM PRESSURE
    See: Fuel Delivery and Air Induction\Service Precautions
    1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
    2. REMOVE FUEL TANK PROTECTOR SUB-ASSEMBLY NO.1
    3. DISCONNECT FUEL TANK MAIN TUBE AND FUEL TANK RETURN TUBE See: Fuel Delivery and Air Induction\Fuel Tank\Service and Repair\Removal
    4. REMOVE FUEL TANK ASSEMBLY See: Fuel Delivery and Air Induction\Fuel Tank\Service and Repair\Removal
    5. REMOVE CHARCOAL CANISTER FILTER NO.2
    (a) Remove the bolt, then remove the ABS wire harness clamp from the charcoal canister.
    (b) Release the EVAP pipe from the hose clamp.
    (c) Disconnect the breather hose from the pipe.
    (d) Disengage the hose clamp.
    (e) Disconnect the breather hose from the charcoal canister.
    (f) Remove the nut, then remove the charcoal canister filter No. 2.
    1. REMOVE CHARCOAL CANISTER ASSEMBLY
    (a) Disconnect the connector.
    (b) Disconnect the EVAP tube.
    (c) Remove the bolt and 2 nuts, then remove the charcoal canister.
    (d) Disconnect the fuel tank vent hose.
    (1) Pinch the retainer and pull the fuel tank vent hose connector out of the charcoal canister to disconnect the fuel tank vent hose from the charcoal canister.
    NOTICE:
    * Remove any dirt and foreign objects from the fuel tank vent hose connector before performing the work.
    Do not allow any scratches or foreign objects on the parts when disconnecting, as the fuel tank vent hose connector has the O-ring that seals the pipe.
    Perform the work by hand. Do not use any tools.
    Do not forcibly bend, twist or turn the nylon tube.
    Protect the disconnected part by covering it with a vinyl bag after disconnecting the fuel tank vent hose.
    If the fuel vent connector and pipe are stuck, push and pull them to release.
    hanrock[OP] likes this.
  5. Sep 27, 2015 at 4:47 PM
    hanrock
    craig
    sask
    wow thankyou very much for the drawings and info i just washed in there there was a lot of dirt and mud in and around the area should be easier to see
  6. Nov 5, 2015 at 5:58 AM
    hanrock
    craig
    sask
    the battery was pooched but the starting issue still persists have not had a chance to repair the charcoal cannister or filter
