Pop and Lock Back Up Camera Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jacpa, Aug 9, 2020.
  1. Aug 9, 2020 at 8:47 AM
    jacpa
    jacpa [OP] Well-Known Member
    Jim
    2021 4Runner TRD ORP
    Alright so I installed the flimsy pop and lock tailgate so I can at least have the option to lock my tailgate. Man what a piece of shit. I cannot believe the quality of this product and am disappointed in Toyota for not offering an OEM option for the second gens.
    While uninstalling my original tailgate lock the plastic bracket holding the backup camera broke. Now my camera is held on by only one bolt which is also on a piece of the plastic that is about to break off.
    Does anyone know where I can get a new bracket that just houses the backup camera? Not sure if you guys will know exactly what I’m talking about or if I should post pictures.
    verynearlypure likes this.
  2. Aug 9, 2020 at 10:15 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Post a picture. Someone might have what you're looking for but I think that part is part of the camera.
  3. Aug 9, 2020 at 10:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Yeah, it’s the housing of the backup camera that it’s installed onto. 1 screw should hold it fine though.
  4. Aug 9, 2020 at 10:58 AM
    jacpa
    Jim
    Yeah it’s not part of the camera but it holds the camera housing in place. Yeah I would be totally fine with one screw but unfortunately that one screw is literally cracking the plastic so it’s hanging on by a thread. It cracked when I took it off originally, didn’t even tighten it down to make it crack. Not sure how long it will hold up
  5. Aug 9, 2020 at 2:14 PM
    TexasWhiteIce
    Texas
    Just superglue the crack. Should be fine since it’s not a moving part
  6. Aug 9, 2020 at 2:19 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Olathe McGeorge online Toyota store has fair OEM pricing. Agreed on pop n lock quality. You can feel in the handle mechanism what a pos it is.
    After the color faded horribly, I put my OEM one back on. Toyota doesn’t care about us 2nd gens anymore (we lost them enough money for frame repairs and replacements.), so I don’t see an OEM option ever in our future.
  7. Aug 10, 2020 at 2:05 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Comes as part of the camera so option is buy a used camera on eBay or make 2 bracket arms out of metal and mount them as I did. No pics as done when I mounted a new pop and lock handle. You use the embedded screw inserts as the base to secure on the handle. My old pop and lock handle self destructed after 10 years which had a different camera mount and as luck would have it the new 2019 handle used the original mount which was long gone ha ha.
    jacpa[OP] likes this.
  8. Aug 10, 2020 at 6:30 AM
    jacpa
    Jim
    Thanks for this info. Should be easy enough to make a new bracket from some thin metal. Might post pictures and dimensions later on this thread to help someone out in the future when I do it.
