Pop and Lock Key - IL18
Discussion in '2nd Gen. Tacomas (2005-2015)' started by captainh00k, Oct 25, 2017.
  1. Oct 25, 2017 at 12:09 PM
    captainh00k
    captainh00k [OP] Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    Hi - I recently purchased a 2012 taco and it came with the Pop and Lock tailgate lock. The previous owner did not leave the keys when he traded the truck in and I have somehow locked the tailgate without the key... I was wondering if anyone has the same key would be willing to give up a spare key for a few bucks?
    I can order replacement keys approx. $15, but I'm cheap and I'm not convinced its not something with the lock.
    Any help would be greatly appreciated.
  2. Oct 25, 2017 at 12:11 PM
    Martimus
    Martimus Well-Known Member
    Martin
    'neath a cactus
    2012 PreRunner SR5
    I know this might sound like a silly comment but have you tried unlocking the pop-and-lock with your truck key?
    Many people, myself included, installed pop-and-lock's on their Tacoma's which are keyed to their ignition lock.
    ElBlancoTaco and tomwil like this.
  3. Oct 25, 2017 at 12:16 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    Yep. I tried to put the key in the one day to see if it worked and it did not.
  4. Oct 25, 2017 at 12:18 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    OP mentions IL18, which appears to be a P&L key. My P&L key is an IL key also, but not 18.
    A replacement P&L lock would be more costly, than a $15 replacement key. But, certain P&L locks are known to be defective, and self-locking. There are ways to bypass the lock to gain access to the tailgate.
  5. Oct 25, 2017 at 12:27 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    How can you bypass the lock? The tailgate is closed. I tried to remove the inner liner to access the lock assembly to bypass it, but I an not able to remove the inner liner.
  6. Oct 25, 2017 at 12:46 PM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    this is the only way i've been able to do it. unscrew the plastic and pull it back (if you cant get it completely off) and manually pull the tailgate release. if you can pull off the cap and the top part of the cover, you can fit your arm in there to do it
    tomwil likes this.
