Pop and Lock PL8521 Power Tailgate Install (2012 Tacoma)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTyfz450, Apr 13, 2012.
  1. Sep 7, 2012 at 7:48 AM
    #81
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    i also installed mine using this write up... great job and thank you!!! i'll post a few pictures to help clear anything up with the wiring through the backup camera wire loom. Also i chose to strip some covering off the wires and solder them to the wires up front under the kick panel. I've never had any luck with those quick connectors. and for the plug under the cab i just poked a very small hole in it with a screw driver and ran the wires up though it then put the wire loom back on when i was finished.
    *thanks for the sponge hint!*
    this is how i wired it through the gate... i put the weather proof plug under the truck near the back up camera plug so removing the gate would be very easy.
    i put the pop&lock wires in the back up camera wire loom and ran them the exact way the back up camera is ran.
    underneath.. black is pop&lock white is back up camera
    into the cab
    in the cab
    final soldering/taping
    and put back together looks like it's completely factory.
    thanks again for the write up! made it SO much easier then figuring it out myself (particularly what tires to tap into.)
    jkuniverse likes this.
  2. Sep 7, 2012 at 8:09 AM
    #82
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Where did you run the wires into the cab? Under the back seat? There's large, very flexible, plugs under both front seats. Most use one of those, depending on which side of the truck (driver or passenger) they're connecting the wiring to. Both plugs easily stretch enough for the wires, along with the plastic protective sleeve, to fit into (in addition to the wire bundles already there).
  3. Sep 7, 2012 at 9:22 AM
    #83
    2006KJ
    Front Royal VA
    the plug i used was under the front passenger seat. i wanted to keep it sealed as much as possible.
  4. Sep 7, 2012 at 9:02 PM
    #84
    stewartx
    Huntsville AL
    Just curious after seeing the images. I didn't see that plug under my front seats, but, of course, wasn't really looking for it. Instead, I ran my wiring (protective sleeve and all) through the large plug used by the existing wire bundle. It stretched easily with a screwdriver, closing to create a very effective seal afterwards. Anyway, your setup looks good, so certainly nothing wrong with it.
  5. Sep 8, 2012 at 8:02 AM
    #85
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    The plug I used was just to the outside of the frame and under the passenger seat. I'd guess it was between quarter and half-dollar sized.
  6. Sep 8, 2012 at 11:59 AM
    #86
    joes06tacoma
    Joe
    Central Coast, CA
    I have not bought one of these yet, I'm not all that concerned about security. I figure a campershell is pretty easy to force open, with or without a tailgate lock, and glass is easy to smash. With that said, it seems to me that for maximum security with one of these, you would install an aftermarket alarm or keyless entry, with an available auxillary channel that can be connected to just the tailgate actuator. Less wear and tear on the actuator to wear it out and cause you grief when it fails locked, plus if someone smashes the cab windows and hits the unlock button, the tailgate stays locked, and there does not need to be an auxillary switch mounted anywhere, the remote could be the only way to unlock it. This has the potential to save you from having large, locked toolboxes, or large equipment from being stolen out of the back of your truck. Anything that would not be removable by simply forcing the shell lid open is that much safer. Something to think about anyway.
  7. Sep 9, 2012 at 7:16 AM
    #87
    2006KJ
    Front Royal VA
    that is true.. the pop&lock doesnt make the truck bed fort knox but it does help ALOT with security. I have a soft tonneau cover so if someone really wants in all they have to do is cut it with a knife... however without the pop&lock all they have to do is open the tail gate... take whatever they want.. and close the tailgate (it would look like it was THEIR truck). Where if they are breaking windows or knifing my tonneau cover and someone saw it they would Know it was a thief. plus the pop&lock locks the gate so it cant be opened.. if it cant be opened the gate its self cant be taken. In my opinion the pop&lock is well worth the $94 shipped.
  8. Sep 9, 2012 at 10:17 AM
    #88
    joes06tacoma
    Joe
    Central Coast, CA
    That's why I wound up with a hard campershell instead of a softtopper. No locks on the soft ones, so just unzip and look casual and nobody knows it's a thief.
    I was just thinking of the guys who use their trucks for work and have expensive stuff back there under a shell. It's all about adding time for the thief.
  9. Sep 9, 2012 at 12:06 PM
    #89
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    FWIW, I got my powered PnL for like $65 shipped on Amazon a few months ago.
  10. Sep 9, 2012 at 8:25 PM
    #90
    stewartx
    Huntsville AL
    No tonneau cover or camper shell, so my lock was installed just to keep people honest when it comes to the tailgate itself (mostly for my own peace of mind). My tools and similar are stored in metal toolbox in the otherwise open bed.
  11. Sep 15, 2012 at 11:11 AM
    #91
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    do you need the pop tail gate lock handle for this or will the oem one will do?
  12. Sep 15, 2012 at 1:27 PM
    #92
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
  13. Sep 20, 2012 at 7:24 PM
    #93
    Spot50
    Spot50 Member
    Bob
    Kansas
    2012 2WD V6 Prerunner
    Curtis Front End Hitch BaKFlip VP Tonneau cover Pop & Lock PL 8521 AMP Power Steps AMP-75142-01A
    JTyfz450 -
    That was a great write up. I followed your directions to the letter, only found a way to avoid removing the plastic piece that holds the backup camera wires (I can send a pic of this if anyone wants) and did not use the Radio Shack squeeze connectors. Things work well, but I do have a question. When I use the FOB to unlock the doors, the tailgate unlocks as it should, but a few seconds later re-locks along with all the doors. Also, only pressing the fob one time to unlock the drivers door works, but again, a few seconds later everything locks back up. Electrical short possibly because I did not use the Radio Shack squeeze connectors? Any ideas would be helpful. Unlocking the doors by using the keys and turning them twice keeps them unlock, so something is amiss with the fob. Thanks for any help.
  14. Sep 20, 2012 at 7:45 PM
    #94
    joes06tacoma
    Joe
    Central Coast, CA
    You are describing normal operation. Mine does the same thing when unlocked remotely. It's been discussed on here before, particularly in regard to power tailgate locks. So far nobody seems to have an answer, unless you were to install an aftermarket alarm or keyless entry. The stock system isn't programmable to turn off the auto relock.
  15. Sep 20, 2012 at 7:54 PM
    #95
    Beers
    Colorado
    12 TRD OR
    The only option right now to keep it from relocking is to open one of the doors on the cab after unlocking the truck remotely. Our Highlander has the same feature. If you unlock the car via the remote but don't open a door within a short period of time the car will relock itself. Like the previous poster said, this is a normal operation and not a short.
  16. Sep 20, 2012 at 8:09 PM
    #96
    JTyfz450
    JTyfz450 [OP] Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    It isn't an electrical short. If you don't open your doors (not the tailgate) after you unlock the truck the truck will lock automatically (safety feature). Unlike the passenger and driver doors the tailgate doesn't have a sensor that indicates if it is open or not. So if you unlock the truck as you would and only open up the tailgate a few seconds later the passenger and driver doors will lock along with the tailgate.
  17. Sep 20, 2012 at 8:10 PM
    #97
    JTyfz450
    Jeryck
    SoCal
    Also I didn't take the plastic piece off of where the backup camera exits the tailgate. I cut a piece of the plastic off to accommodation both of the wire bundles.
  18. Sep 20, 2012 at 8:41 PM
    #98
    Spot50
    Spot50 Member
    Bob
    Kansas
    Wow, thanks for the quick responses, this forum is fantastic. Joes06Tacoma, Beers, TJYfz450, all of you - thanks for easing my mind. I am a retired biology instructor, this electrical stuff rather baffles me. Murphy's law seems to haunt me when I'm outside my normal comfort zone, nice to know that I didn't screw up this time.
  19. Sep 20, 2012 at 8:43 PM
    #99
    Spot50
    Spot50 Member
    Bob
    Kansas
  20. Sep 24, 2012 at 1:58 PM
    #100
    PT2000
    PT2000 Member
    tacoma sr5
    Thanks for the awesome picture guides. Much easier to follow than the instructions.
    One hint, helpful to atleast me. Once you've made the final connections and are testing the lock / unlock, make sure the cab doors are shut. I thought I had a problem when the unlock function worked fine, but the lock function produced a steady beep and no movement. :eek: once the doors were shut, everything worked perfectly. It took several minutes longer than I'd like to admit to figure that it was not a wiring fail!
