Pop&Lock 8520 and 8521 Guide
Discussion in 'Audio & Video' started by dk6487, Feb 25, 2010.
  1. Jan 21, 2012 at 9:04 AM
    Mav44
    Mav44 Well-Known Member
    That looks like the top bundle on the drivers side but I do not believe that it will allow two clicks to open. When I opened up the passenger side the wires were right in front of me. Just to make sure I tapped into the wires and connected the lock. Two clicks of the remote confirmed I had the right wires. I want to make sure I had the electrical figured out before I spent an hour running wires.
  2. Jan 21, 2012 at 9:07 AM
    sparkhill
    sparkhill Well-Known Member
    It is the passenger side, but I have a double cab, so maybe that is the difference. Certainly not just jumping out at me. THanks.
  3. Jan 21, 2012 at 12:34 PM
    sparkhill
    Thanks to everyone for the info in this thread. I especially appreciate the PM's from Mav44.
    On my 2012 Double Cab, I went on the passenger side. The photo in my is what I saw: lots of wires. I do not have too much to add to the info above but I would just suggest opening the front passenger door and tracing the wires back from there. There were two bundles of wires attached to the connector. The wires I needed were the lower wires labeled B in my photo. Both bundles of wires had a thick black tape-like coating, which I removed. My colors were the same as Mav44: blue/pink and blue/black. The bundle A wires were really small. The wires I used were also pretty small but larger than the smallest wires.
  4. Jan 21, 2012 at 12:35 PM
    davelac
    davelac Well-Known Member
    Capital Region
    2011 SR5
    Where did you poke through from under the passenger side to get to the wiring?
  5. Jan 21, 2012 at 12:39 PM
    sparkhill
    There are a couple of little black rubber plugs about 4 or 5 inches from the edge of the car. I just slid under the truck, pulled the plug near the passenger seat, made a slit in it pulled the wires through and them put a glob silicone on the wires and over the slit. I ran the two wires only, not the black plastic covering, through the plug. I used the black covering before and after the plug cover. Just cut off the connectors and crimp the new ones on once you shortens the wires.
    Edit: I should add that I have the backup camera and there were no open drain holes in the tailgate. I just drilled a hole in the bottom center of the tailgate. I also shortened the tailgate wires and crimped on new connectors from RadioShack.
  6. Jan 27, 2012 at 4:54 PM
    The Jimmer
    The Jimmer Member
    Just finished my install in a 2012 double cab. I ran wires to the passenger side so as not to have the lock activate all the time. Between the instructions and all I have read on the posts, decided to call Pop N Lock tech support to confirm wire tie in colors...BLUE -RED STRIPE(kinda pink) and BLUE -BLACK STRIPE.
    Works like a champ and don't have an extra key to carry! Only concern is how do I access bed through BakFlip if the solenoid fails?
  7. Jan 28, 2012 at 7:47 AM
    Mav44
    I had the same thought. Hopefully if solenoid starts to go I can get it to open "one more time" to repalce or maybe get a coat hanger under the lip of the backflp and fish around till I hook the release cable.
  8. Feb 5, 2012 at 1:43 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    what should I use to splice into the wires? My friend says to soldier them but that seems a bit much. What are the square things OP had in his how-to:
  9. Feb 5, 2012 at 4:57 AM
    The Jimmer
    The Jimmer Member
    Your kit should have come with 2 wire taps. These are the blue things you reference in the photo. Basically how it works is you place the wire you want to tap into u-shaped metal section of the device. When you close the tap cover onto itself it will splice into the wire. It takes some pressure to close and snap shut. This insures the metal taps into the wire. Then on one end there is a recepticle to connect the Pop-n-lock wire fitting. Presto you are done. You do this to both wires. Test the connection before you close things up.
    Hope this helps - Wish I took some photos during install for you.
  10. Feb 5, 2012 at 11:42 AM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    thanks jimmer. I have the 8521 now and see how these blue taps work. +1
    are these called vampire taps? my friend who mentioned to soldier them said they aren't the best? is he just being a perfectionist? he's like you should solider them and use a heat gun and that shrink tape... stuff I don't have :D
  11. Feb 5, 2012 at 1:10 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Soldering the wires in is light years better than using the scotchlocks. Your friend is right, but not everyone wants to/knows how to put that effort level into their work.
  12. Feb 12, 2012 at 5:55 AM
    rigoodma
    rigoodma Member
    Riggs
    Atlanta, GA
    2012 DC 4x4 AT TRD Sport
    +1 for me. I just finished installing my Pop-and-Lock 5 minutes ago and works great. I did it on the passenger side, so only opens on two clicks. There are at least 3 sets of blue/pink and blue/black wires on the passenger side. Of course, my luck it was the third set before it was the right set. Word of advice, follow instructions on the thread and look at all the pictures. The bundle A/B pic was what helped me the most. It would saved me half of my Saturday last weekend and having to buy more taps if I would have looked at all the pictures posted, instead of assuming. If I would have picked the correct wires the first time, it would have taken me 20 minutes to complete.
    Thanks everyone who posted to this.
  13. Feb 21, 2012 at 9:43 AM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
  14. Feb 26, 2012 at 10:06 AM
    abesserman
    abesserman New Member
    Los Angeles
    2012 Double Cab Long Bed PreRunner SR5
    Black tube steps Bak Flip G2 Tonneau Cover
    Thanks for this helpful post. I installed my PL8521 on my 2012 Tacoma quick and easy, with your help.
    I'm having a problem. Wondering if anyone has ideas to help fix it...
    The lock works fine 90% of the time. But, some mornings, if it's cold outside, and the truck has been idle all night, the lock WILL NOT RESPOND. After driving around and warming up the truck, the power lock suddenly works again.
    I have a Bak Flip tonneau cover, so when the PL8521 fails, I'm completely locked out of my truck bed.
    Any ideas why the lock fails to work on cold mornings? I've tried just about EVERYTHING and about to give up on this, and just go with a basic key lock instead.
  15. Feb 26, 2012 at 10:08 AM
    #35
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    I used some WD40 on mine cause it didn't sound very smooth when actuating...maybe it's just a lil stiff in the cold AM? No idea why the cold would affect electrical but I'm not an expert by any means! GL :D
  16. Mar 13, 2012 at 8:30 PM
    #36
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    Used this write-up today and the install went perfect. TW FTMFW!
  17. Apr 6, 2012 at 9:08 AM
    #37
    petyanca
    petyanca Well-Known Member
    Tacoma, WA
    09 AC 4cyl 4x4 5spd
    Thanks for the writeup. I didn't have to undo the plastic clips in step 2, it is possible to bolt the lock without messing with them.
  18. Apr 29, 2012 at 10:52 PM
    #38
    harvey1228
    harvey1228 Member
    Harvey
    castro valley, ca
    2012 PreRunner
    Your picture in step 8 shows four red wire taps. I have similar wire taps that I disconnected while installing my pop n lock PL 8521 on my 2012 Tacoma. I don't have a wiring diagram to tell me how to reconnect them. I need the wire color connection combinations for the tapped and tapping wires.
    Currently, I've noted that at least my passenger side power window and key warning chime do not work because the taps aren't correctly connected.
    Can you help?
    harvey1228@yahoo.com
  19. May 12, 2012 at 5:14 PM
    #39
    mungeremt
    mungeremt Member
    Mississippi Gulf Coast
    Just installed on 2012 DC SR5. All the info was great. Ran wires to passenger side and tapped into blue/pink and blue/black. Mine has the back up camera so I had to drill a 3/8 hole in the bottom of the tailgate to run wires through. Then through the spare tire hole.
  20. Jul 29, 2012 at 11:53 AM
    #40
    Rames
    Rames Well-Known Member
    James
    Oakland, CA
    OME 3" lift, BAMF sliders, Demello front bumper
    just a heads up for my 2012 double cab sr5/w back up camera, i followed the bundle of wires out from my passenger door and used the lower bundle b at first but didn't work for me. second try i followed tw member JTyfz450 post/ photos and used the bundle from the "y" split worked like a charm.
