Pop & Lock Install Problem 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sawtooth, Apr 6, 2012.
  1. Apr 6, 2012 at 8:12 AM
    Sawtooth
    Sawtooth [OP] Member
    Newton, NJ
    Tacoma SR5
    I just tried to install the PL5300 in my 2012 and I could not get the camera to fit without cramming it in. Maybe I got a defective unit because the fit and finish was terrible. Is the camera been a problem for anyone? Thanks, John
  2. Apr 6, 2012 at 9:14 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I installed one in my 2009 and no problem. I don't think there is any difference in the tailgate on my 2012. See what others say.
  3. Apr 6, 2012 at 9:22 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The only thing I have heard is that you need to re route the camera cable and this step is not mentioned in the instructions manual?
  4. Apr 6, 2012 at 9:34 AM
    Sawtooth
    Newton, NJ
    Tacoma SR5
    My problem was with camera fitting in the Pop Lock. If that had worked it would have been an easy install. The only way to get the camera to fit would have been to enlarge the opening in the handle assembly. I called their tech dept but they must be closed. I'm sending it back and I hope the replacement is a better fit.
  5. Apr 6, 2012 at 9:55 AM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    I install the remote Pop & Lock. All you do is install the solinoid inside the tailgate. You don't even touch the handle and camera.
  6. Apr 6, 2012 at 11:22 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    OP, return the 5300 and get the 8521.
  7. Sep 19, 2013 at 6:35 PM
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    Hey. So just installed the 8521. I had one issue where I would unlock the truck and then it would lock itself within 30seconds. ?????didnt have time to fix it cause I was already late to work. Left the truck at home and the wife says the backup camera doesn't work either. Anyone else have these issues? I'll just have to wait until tomorrow morning to do anything.
  8. Sep 19, 2013 at 6:37 PM
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    Never mind the camera issue. I forgot to plug the camera connector. But I still have the lock issue.
  9. Sep 19, 2013 at 7:18 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    The Tacoma auto locks after 30 seconds all the time, it has nothing to do with the pop and lock. It's supposed to, to stop it from doing this you need to open one of the cab doors.
  10. Sep 19, 2013 at 7:28 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Good catch, bj! The system will re-arm if no doors are opened. So, if you're checking the tailgate by unlocking it via the remote, and didn't open and close a cab door, then you're experiencing normal system re-arming. It's just a failsafe to prevent you from unlocking it and leaving it that way.
    Try that and see if it corrects your issue.
  11. Sep 19, 2013 at 8:31 PM
    rockhopjohn
    rockhopjohn Well-Known Member
    ID, MT, ND, I'm a transient
    2013 Tacoma T|X Baja
    I didn't have to do any cramming, but I didn't feel like the camera seated all the way down like it should into the Pop and Lock assembly, and when I screwed the retaining plate back down to the back I really have to work to get the holes to line up because it wasn't really seated very well.
    All that being said, it went back together and seems to work just fine. Although I did have a problem with it wanting to lock itself after opening the bed a few times, so you might want to watch for that.
    http://www.tacomaworld.com/forum/pr...tailgate-after-opening-few-times-how-fix.html
  12. Sep 19, 2013 at 8:42 PM
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    Yeah thanks man. I'll try that. I'll update later tonight. Never noticed the auto lock. I've only had my truck for 3 weeks. So if I unlock the tailgate via the remote but don't open any doors, then will the tailgate still lock? I'm kind of answering my own question. I think it does but I can't remember since I had to leave for work immediately and can't remember.
  13. Sep 19, 2013 at 8:56 PM
    TxFireman
    San Antonio, Texas
    I don't have the pop-lock myself, also only 3 weeks old, but since it's on the system, yes it should relock if you don't open a cab door. I don't know that opening the tailgate in that time will interrupt the default or not, since I don't have it to try. But I do know you should have to press the button twice, once is for the drivers door, and twice unlocks everything else, and in your case, should be when the TG unlocks. Open a door and close it, and see if that stops it from relocking after 30 secs.
  14. Sep 20, 2013 at 6:41 AM
    bjboucher
    Brad
    San Antonio, Texas
    Yep, it relocks all the doors, which will also lock your tailgate since you tied into the door locking system to make it work.
