Pop & Lock Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris1261, Feb 11, 2018.
  1. Feb 11, 2018 at 6:48 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Lol.
    This sounds an awful lot like something I would do. I fixed this though, I lost my other key fob. Can't call the wife if you don't have an extra fob...
    JS760[QUOTED] likes this.
  2. Feb 11, 2018 at 7:18 PM
    openspace4x4
    openspace4x4 Well-Known Member
    SF Bay Area
    2017 TRD OR DCSB
    OV Tune
    Thanks for the write up, the wiring directions it comes with are worthless. I tried youtube but the wiring didn't work. I'll give it another try with the connections you used OP. :cheers:
  3. Feb 11, 2018 at 9:08 PM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    lol
    That's where drone mobile comes in. Lock/unlock and engine start from my cell phone. Excellent mod.
  4. Feb 11, 2018 at 11:01 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    This was an easy and must install after i got a cover, imo. I too went thru the grommet under passenger side door. Seemed easier and more effective
  5. Feb 12, 2018 at 5:55 AM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    This was one of the first mod I did on my Taco. Definitely worth the $86 bucks but I agree it should have come factory from Toyota. Only bad thing I hate is that its so damn LOUD.
  6. Feb 12, 2018 at 9:29 AM
    Chris1261
    Chris1261 [OP] Member
    '17 TRD Sport AC/MT
    I just went into the settings and turned the auto relock timer off.
    I have a manual trans, so I don't have the keyfob/sensor issue. what's the range on the key fob? doesn't the signal reach if the fob's in the truck bed?
  7. Jul 28, 2018 at 5:51 PM
    MrSquigglepants
    MrSquigglepants New Member
    Andre
    Scottsdale, AZ
    2017 Pro
    I just did this today. Fun and easy to do. The only trick was a) making sure we had actually plugged in the two wire sets (the long one that runs under the truck and the short one that runs into the tailgate) before testing, and b) making sure we had wired into the right set of wires.
  8. Sep 15, 2018 at 4:11 PM
    yorkdiver
    yorkdiver Member
    Thanks for this. Glad that you pointed out the difference in the wiring taps from the Tundra.
  9. Oct 4, 2018 at 7:28 PM
    Venti
    Venti Member
    I just did this today as bed security was important to me. I didn’t drill through the plastic loom holders, I removed them, and enlarged the standard hole to accept the additional wires. I also didn’t jam a screwdriver through the body plug under the passenger seat, I disassembled the tape and loom passed the wires through and put the loom to plug connection back together.
    All that to say, I see that it could be done in an hour but my ocd wouldn’t yield.
    I also added sound deadening to the tail gate, which also added time.
    I enjoyed doing it, and would recommend it to anyone looking for bed security.
    I will say that the sound deadening material helped, however because the servo has to have slack between itself and the lock mechanism to allow manual operation, most of the noise is the servo physically smacking the hell out of the lock from a decent resting distance.
  10. Oct 23, 2018 at 7:21 AM
    Dcox
    Dcox Well-Known Member
    Dave
    Oregon
    2018 Tacoma Sport AC MT
    Grill swap, level, tires and wheels, bed lights, tailgate actuator
    Chris1261, thank you for your write up. I didn't use the pop n lock kit but your wiring code for the access cab was perfect and the same on the 2018.
    Chris1261[OP] likes this.
  11. Oct 23, 2018 at 10:10 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Slightly off topic, but is there a solution like this for a bed cap? Not the tailgate itself. I have the ARE Overland cap, and it's manual lock only. I'm looking for an aftermarket solution to automate locking for the CAP.
  12. Oct 24, 2018 at 7:08 AM
    Chris1261
    '17 TRD Sport AC/MT
    Pop & Lock makes kits for toppers too. here's one on Amazon: https://amzn.to/2CCXB9x
    vuTron[QUOTED] likes this.
  13. Oct 24, 2018 at 7:41 AM
    vuTron
    SF Bay Area
    nice. this must be a relatively new product, as I was looking for something like this about a year ago with no avail. thanks!
  14. Oct 24, 2018 at 7:44 AM
    Dcox
    Dave
    Oregon
    This is the actuator I used.. https://www.amazon.com/gp/product/B0088YE6YQ/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    If you are able to attach it to your cap then the wiring setup would be the same.
  15. Oct 24, 2018 at 7:47 AM
    #35
    vuTron
    SF Bay Area
    Any chance you can (or did) a step by step write up? This is tops on my mod lists to dos. I've been holding out on a pop and lock for a tailgate until I could find a similar mod for the cap, which this appears to be! I'm kind of a mechanical dunce, but I can follow directions.
  16. Oct 30, 2018 at 10:32 PM
    #36
    Dcox
    Dave
    Oregon
    I installed it on my tailgate but I would guess it would work on a cap.
  17. Nov 25, 2018 at 7:32 PM
    #37
    scott0_1
    scott0_1 Well-Known Member
    Scott
    2017 DCLB TRD Sport
    Anyone know the part number for the wire loom clip in the tailgate? I broke mine real good when drilling a new hole in it. My OCD say buy a new one.
    Thanks!
    toyorick likes this.
  18. Mar 12, 2019 at 2:08 PM
    #38
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Just purchased this kit. Instead of running the wires all the way down the passenger side to tap into power, I assume I can just tap into my SnugTop auto lock. With that said, does anybody know what wires to connect to?
  19. Apr 17, 2019 at 11:47 AM
    #39
    Willtaco
    Willtaco I Love Tacos!!
    Will
    SoCal LA
    18 Tacoma TRD OR 4x4 DC/SB
    •Xenon LED lights •EGR channel window visor/Hood Protector •total chaos bed stiffener •TRD cold air intake. •30” Rough country light bar •King’s suspension and springs •Camburg UCA/ replaced with JBA UCA •Method wheels •285/70/R17 Falcon wildpeak •slimeline bumper •All pro rock sliders •All pro skid plate •winch Plus a few more goodies and That’s all I have to say about that..
    Man the strip club you go to have a lot of Activities events !! Hahah
  20. May 23, 2020 at 7:32 PM
    #40
    Fuelforthebuell
    Fuelforthebuell Member
    I just tried to install my pop and lock on my 2006 tacoma 2dr access cab and the instructions said to splice into the blue and the blue with a white stripe wire... I did that and then all I got was a clicking in my passenger door speakers. Waiting for tech support to get back to me. Anyone able to help??
