Pop & Lock is not working and my bed has BAKFlip G2. Please help
Discussion in 'Tonneau Covers, Caps and Shells' started by takoashihaisen, Mar 17, 2017.
  1. Mar 17, 2017 at 11:55 AM
    takoashihaisen
    takoashihaisen [OP] Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    Hi all,
    I was about to load some debris from my home repair, then I noticed I could not open the tail gate. I can insert the truck key into the key hole of Pop & Lock and rotate counter clock-wise (or clock-wise). But I cannot open the tail gate. The bed is currently not accessible as I cannot open the tailgate or BAKFlip G2. My Pop & Lock is bundled with a back-up camera, which was purchased from Camera Source. My Pop-Lock is the type you use your own truck key (coded).
    I like to avoid destroying the Pop-Lock (and the back-up camera), if possible, as the back-up camera has been very valuable to me.
    Is there a way to open up the BAKFlip G2 without damaging it? If yes, then can I remove the screws of the panel of the tail gate, which is facing to the driving direction?
    Thanks
  2. Mar 17, 2017 at 12:14 PM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    try to run a bent coat hanger between the cover and the tailgate to grab the release wire. Or a long skinny screwdriver...
  3. Mar 17, 2017 at 12:20 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    This is a known issue. I was worried about this when my key coded version started struggling to lock/unlock. I sprayed all the components with some WD-40 but it didn't help matters. Switched to the actuator model a year ago and haven't had a problem since. Spend the extra money, it's worth it.
    Zac of all trades likes this.
  4. Mar 17, 2017 at 12:27 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Go to the auto parts store and buy a can of graphite in a airsole can. Stick the little hose nozzle in the key slot and spray a bunch, followed by your key working back and forth in the key slot.
    I bought a pop and lock (coded) last spring. After install I never actually locked it as I don't keep much valuable stuff in the bed. When I did try and use it this winter the key would not turn. Used the graphite to fix it. Have done this on motorcycle ignition in the past when they sit outside.
    Do not use wd-40. While it may work to get the lock working again, the oily fluid will attract dirt making it clog up quicker.
  5. Mar 17, 2017 at 12:28 PM
    Zac of all trades
    Zac
    fwpfab.com
    i have the power pop-n-lock, have had 0 issues so far.
  6. Mar 17, 2017 at 12:43 PM
    takoashihaisen
    island, WA
    Thank you all for your valuable inputs. I could manage to open the BAKFlip. With a little help of a pry bar, I could insert my fingers and pull the rope that secures the BAKFlip cover. I now have an access to the tailgate. I will unscrew the bolts and remove the plastic cover. Once I successfully unlock or destroy the lock whatever it is, I do not think I will ever use this lock again:mad:
    Yes, I have seen the threads about non-functioning Pop&Lock. Thought about it might happen to me, but oh well:ballchain: I guess I waited too long!
