pop & lock manual tailgate lock for 2009's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zero niner, Sep 29, 2008.
  1. Dec 10, 2008 at 4:25 AM
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I saw the kits but I was in a hurry to get something on the gate. After installation of the clamps I filled in the screw driver slot with JB Weld then covered the hex head with heat shrink. Thieves would have to cut the heat shrink off then have a hex driver to get the clamps off. Still doable but might be just enough to slow them down so maybe they would go elsewhere.
  2. Dec 10, 2008 at 7:14 AM
    Teufel Hunden
    Teufel Hunden No Better Friend, No Worse Enemy
    Northern Virginia
    09 MGray DC SB TRD-OR 4x4 V6 Auto SR5
    Undercover tonneau, OEM tow package with hitch, OEM retractable roof rack, Front window tint (legal), WeatherTech FloorLiners, Door sill protectors, Tacoma bed mat, Rear leaf spring TSB, OEM DRL mod, Door edge guards, AFE Pro-Dry S Air Filter, Removed secondary air filter, Smoked LED 3rd brake light, Romik running boards, Go Rhino hitch step, Extra set of D-rings mod, Bed cargo net, TRD wheel locks, OBX sport pedal covers.
    I have an Undercover Tonneau also, so I have not been in a hurry to find a way to lock my tailgate. What kits are you referring too? Do you have a link or website where they are sold?
  3. Dec 10, 2008 at 7:23 AM
    Rickochet
    Rick
    Kentucky
    The kit I saw was called Gatekeeper. You remove one of the tailgate hinge bolts and bolt on a metal piece that prevents the gate removal without removing the Gatekeeper part. Here is a linky:
    http://www.jimmijammer.com/GK Inst Tutorial, Toyota Tacoma.htm
    Rick
  4. Dec 10, 2008 at 7:24 AM
    Joe B
    Joe B Well-Known Member
    I lost the site.
    It was a $20 kit with a metal collar with a different allen head bolt which replaces the Torx bolt..The hoseclamp works almost as well and is much cheaper.
    Do that until you get the Pop N Lock.
  5. Dec 10, 2008 at 7:25 AM
    Joe B
  6. Dec 10, 2008 at 7:39 AM
    Teufel Hunden
    Northern Virginia
    Thanks to both of you for the help!
  7. Dec 10, 2008 at 9:00 AM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    I believe the signal is either taken from the brake light or from the drivers side door. The electric lock I had on my Tundra was connected to wiring inside of my drivers door and wire snaked underneath into the tail gate. Hope that helps and someone may clarify how it hooks up with the Tacoma.
    Happy Holidays!
    Rob
  8. Jan 15, 2009 at 1:48 PM
    Rickochet
    Rick
    Kentucky
    I emailed Pop and Lock today about the lock for the '09 Tacoma and got this:
    "Pop & Lock should be shipping to our distributors by end of Feb/09"
    :mad:
  9. Jan 15, 2009 at 1:56 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    You are tight, it is the same that I hook up mind 2009 Tacoma
  10. Jan 28, 2009 at 5:58 AM
    txusa03
    txusa03 Well-Known Member
    does anyone knows if there is a version that is not electronic because my truck does not have power doors/windows.
    Ok, I found my answer. In my case, I can go with the Pop N Lock type.
  11. Feb 15, 2009 at 12:42 PM
    tacomian devil
    tacomian devil Canadian member
    LA Canada
    SexyBlack TRD Sport DC LB w/ heated leather
    Nerf bars, Alum Knight Grill, CatBack Exhaust, Bakflip G2 HD tonneau, Dynolock electric tailgate lock, Webasto TVS 940 ST 2 panel electric sunroof, VIPER 5901 Alarm/Remote start, 3M FX PREMIUM 5% tint on back seat & rear slider, 15% on front windows. Retrofited Morimoto Projector headlights in smoked lamp housings with 35W 5000K bulbs lit by Denso slim ballasts, Gatling Gun shrouds capped with 100mm Cold Cathode Fluorescent Light rings.
    Wing 103 -
    Great pics and tidy install job! It sounds like a good, well designed product. Were you able to get the High Security Actuator with your "with back-up camera" in the tailgate model?
    In the little video clip that Dynolock shows on their installation page for their "High Security Actuator / no back-up camera model", the device sounds and looks like it is failing (jamming?) in the open position. :confused:
    Have you had any jamming issues/malfunctioning issues in the ~5months you have been using yours? Not that Boston is close to the weather extremes in Alberta, Canada, but you have some frigid weather at times, right?
    Would you still recommend the electric Dynolock for owners with back-up camera? - Any limitations/considerations?
    Thanks!
  12. Feb 15, 2009 at 12:58 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I've been checking in periodically with the distributor, here's the latest estimate. It just keeps getting pushed out... :(
    "PL5300 should be released to our distributors mid to late March.
    Thanks again for your patience."
    We can only wait patiently...
    Rob
  13. Feb 15, 2009 at 11:00 PM
    wing103
    Boston
    The dyno lock is working wonderful, I do not have any issue or problem.
    Either in the snow & ice storm... it still 100% working without any problem.
    Iwill still recommend you to use it, remember if you use this lock, no one can steel your tail gate.
    If you do a search, you will see one of our brother tailgate get stolen. I wish he find his tail gate soon.
  14. Feb 20, 2009 at 1:20 PM
    Rickochet
    Rick
    Kentucky
    I checked with a vendor who shows it on their website but it was not in stock 2 weeks ago. I got an email from them today saying that they cannot get an answer from Pop & Lock about when it will be available. This is really getting me pissed. I don't really need the backup cam in my '09 Taca and am thinking about trying to find a 05' - '08 handle and see if it will fit. I need a locked tailgate more than I need the fetchin' camera. :mad:
  15. Feb 20, 2009 at 1:43 PM
    #35
    Joe B
    Don't give up the camera for the lock.:)
    You've waited this long,why not wait longer.
    Call/email Pop and Lock,not the vendor for a time frame.
  16. Feb 20, 2009 at 3:11 PM
    #36
    Rickochet
    Rick
    Kentucky
    I have done that and everytime I email Pop & Lock the date gets pushed back. This was supposed to be available in November and now we are into March maybe.
  17. Feb 20, 2009 at 3:22 PM
    #37
    wing103
    Boston
    If you want to sell the camera, I know one of my friend he is instresting.
    Please PM me if you want to sell it, he have a 07 Tacoma,
  18. Feb 21, 2009 at 8:54 AM
    #38
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '09 DC SB Magnetic Gray Metallic SR5 TRD-OR
    The 2 mounting bolts are the same on the '09, it should fit easily.
