Pop & Lock PL5300 Review
Discussion in 'Product Reviews' started by NAYo2002, May 16, 2010.
  1. Feb 16, 2013 at 4:26 PM
    #61
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I'm going to have to move my camera when I get a HC with a tire carrier, would like to replace the tailgate handle with this when I do. Anyone know if I can get just the standard without the camera? Or do I have to get the one designed for the camera and then just leave it out?
    Does that make sense?
  2. Feb 16, 2013 at 6:10 PM
    #62
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    It can be used on tailgates w/o the backup camera. If you look at the first picture I posted, you'll see that there's a square to the left that was pre-cut for the camera. If a tailgate does not have a camera, you just leave that piece in.
  3. Feb 16, 2013 at 6:18 PM
    #63
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Not sure what you done here but it should have fit. Here is some information, please let me know if this sounds correct...
    1) The camera was mounted with 2 screws to the original fixture.
    2) The camera has 2 guide pins.
    3) When you place the camera on the new camera mount the guide pins and screw holes lines up with the holes in the new mount.
    4) If the guide pins do not fit in the two guide holes, run a drill bit through those two holes of the appropriate size to allow the guide pins to fit.
    5) Mount the camera to the mount using the two screws.
    6) Mount the assembly into the Pop & Lock.
    It should be good at this point. Too bad you cut up that mount but it looks like you can salvage it. It looks like you don't even have the screws installed to hold the camera to the mount but cut out the locations where the guide pins are. I recommend you take it apart and mount the camera properly so it mounts flush with the mount using the two screws. This will adjust the angle and fix your viewing problem.
  4. Feb 16, 2013 at 6:51 PM
    #64
    Kevinztaco
    none yet
    Hi there,
    There would be no way I can get that mount to fit the camera and bolt it to those two bolts without cutting and bending it. The 2013 Tacoma's backup camera is either too bulky and long to fit in it or that mount isn't the correct one. I'll show a picture of the oem vs pop&lock tailgate lock when I get a chance. Thanks!
  5. Feb 16, 2013 at 6:59 PM
    #65
    JoeSchmuck
    Joe
    Virginia
    Please provide as much data as you can. I'm sure many 2013 Tacoma owners would like to know about the problems you are having and if there is a proper solution. If you could take many good photos so we could compare the two locks and mounting areas. A ruler to measure the holes would be a nice touch if you believe those don't line up.
    As I recall, I have a tuff time fitting mine in but I think it was just needing to drill out the guide pin holes a little.
    And please don't think that I think you are stupid or anything, that is not the case. You own a Tacoma, you are smart enough to me :D.
  6. Feb 16, 2013 at 7:00 PM
    #66
    benbacher
    Anchorage, AK
    Ah gotcha. Thanks!
  7. Feb 16, 2013 at 7:18 PM
    #67
    Kevinztaco
    none yet
    OEM
    Pop&Lock
  8. Feb 17, 2013 at 6:16 PM
    #68
    Kevinztaco
    none yet
    LOL....., WTF is this kind of comment for?
  9. Feb 17, 2013 at 7:46 PM
    #69
    JoeSchmuck
    Joe
    Virginia
    I'm sure you have tried this but....
  10. Feb 17, 2013 at 9:13 PM
    #70
    Kevinztaco
    none yet
    Tried that and it wouldn't work. I also tried turning the camera in every possible angles to get it to sit but it wouldn't fit. That plastic mount was not designed for that 2013 Tacoma backup camera. That plastic mount has to molded in an angle that allows the camera to sit in its intended position.
  11. Feb 18, 2013 at 2:19 AM
    #71
    JoeSchmuck
    Joe
    Virginia
    Have you tried to contact Popandlock.net and ask them for a new mount for the 2013? I would expect they would only replace the mount section. Of course that assumes they even have it made.
    Good luck to you on this and please post if you get any resolution from that company.
  12. Feb 18, 2013 at 6:05 PM
    #72
    JoeSchmuck
    Joe
    Virginia
    I have contacted the PopandLock company because I was concerned that there was an issue with the 2013 Tacoma's and they assured me that the camera in a 2013 Tacoma does fit. I wish I had taken photos of the camera mounting. Maybe the next person who successfully does this installation could take a series of photos and post them.
  13. Feb 18, 2013 at 8:03 PM
    #73
    Rellikcro
    Rellikcro Active Member
    Western Washington
    2013 Tacoma SR5 4x4 4.0 V6
    Remote start with alarm
    I just ordered one of these for my 2013 Tacoma and will let everyone know when I get it and give updates on what I find.
  14. Feb 18, 2013 at 8:48 PM
    #74
    Kevinztaco
    none yet
    I emailed Pop&Lock and they confirmed that the tailgate lock I order should fit my 2013. The lock does fit but the mount that secures the backup camera in place is the issue. I had to re-route the camera wires because of the switch of the camera position from right to left. I'd be very interested to see feedbacks from guys who have ordered or will be ordering the pop&lock for their 2013 Tacoma. Please give us updates.
  15. Feb 19, 2013 at 3:22 AM
    #75
    JoeSchmuck
    Joe
    Virginia
    Everyone has to reroute the camera wires as the camera moves from the right side to the left side for the PL5300 series. That is a very minor change and covered in step 9 of the installation instructions and is covered in this thread as well.
    I too am interested to see if the 2013 Tacoma is a perfect fit. If anyone has problems, contact Pop and Lock. Also, read this thread. Keep in mind that I personally had to open up the holes for the guide pins a little bit to make mine fit properly.
  16. Feb 19, 2013 at 3:53 PM
    #76
    Kevinztaco
    none yet
    JoeSchmuck, are you one of the guy or an associate of pop&lock? I'm just curious.
  17. Feb 19, 2013 at 4:11 PM
    #77
    ksands
    ksands Member
    Keith
    St. Augustine FL
    Tacoma TRD Sport
    Hi guys,
    I was reading the post and sorry you had a problem with the install.I installed the pop n lock on my 2013 with camera and did not have the problems you had.
    I did not have to cut or bend anything and when viewing the camera, nothing is blocked. It fit as it should. :)
  18. Feb 19, 2013 at 4:17 PM
    #78
    Kevinztaco
    none yet
    Care to share some pictures?
  19. Feb 19, 2013 at 4:26 PM
    #79
    ksands
    ksands Member
    Keith
    St. Augustine FL
    Tacoma TRD Sport
    i took a few pics. I hope this helps. I didn't take many pics when I did it, this is all I have.
  20. Feb 25, 2013 at 7:12 PM
    #80
    Rellikcro
    Western Washington
    Received my Pop N Lock today and installed it without issue on my 2013 Tacoma, I did not get many pics as I was doing most of this work in low light (was getting dark fast) but the whole thing took less then 30 minutes. I did have to drill the two setting holes just very slightly larger but other then that it was all drop in.
