Pop lock tail gate lock
Discussion in 'Tennessee' started by Lfminto, Jan 6, 2019.
  1. Jan 6, 2019 at 2:18 PM
    Lfminto
    Lfminto [OP] Member
    Luke
    19 Tacoma TRD off-road
    Any one install one of those Pop lock tail gate lock
  2. Jan 7, 2019 at 5:54 AM
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Not sure where you are located but Chuck's Trucks in Nashville did mine, along with a bunch of other stuff.
  3. Jan 7, 2019 at 8:16 PM
    SemperHouse
    SemperHouse Well-Known Member
    Eric
    Nashville, TN
    2015 Tacoma TRD Pro
    I did the 8540 version (programs to your factory key and wires in to the door locks to use with factory key fob) in my driveway. A bit of a pain to route the wire up high under the truck to stay out of everything's way all the way to the forward cab, but the instructions are clear and they give a very good length of extra slack wire at the ends. Quality seems good, and so far zero issues. I do recommend, especially if you get a hard bed cover of some sort.
  4. Jan 18, 2019 at 5:21 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    I installed one on my 1st gen, non-electric or anything. If you're looking to DIY I'm pretty handy & can try and help. I'm located in Franklin.
  5. Mar 14, 2019 at 4:17 PM
    Liquidworld
    Liquidworld Active Member
    Ken
    Sarasota
    2019 Super White Tacoma DCSB TRD OR 4wd
    I installed the power tailgate lock on my 19' OR. Used kit PL8535 got off Amazon for about $80. Routing the wires takes a little time but other than that it's easy. Google you tube videos if you need help. There is also a guy on here that sells a plug and play adapter that makes connecting the wiring a no-brainer. I love mine. You might want to add a sound mat or dampener inside the tailgate to get rid of the hollow sound when the lock operates.
    SemperHouse likes this.
