Pop & Lock Tailgate issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cavemanclay1, Apr 26, 2022.
  1. Apr 26, 2022 at 3:25 PM
    Cavemanclay1
    Cavemanclay1 [OP] New Member
    2020 TRD OR DCSB
    TL:DR Pop & Lock remote tailgate lock is not working with my key fob.
    I’ve got a 2020 TRD OR DCSB and the locking tailgate is no longer working with my key fob. I can still physically turn the key though to lock and unlock it.
    I recently had it at the dealership for service and asked them to check why it’s not locking and unlocking with the fob and the tech just looked at me and said Tacoma tailgates don’t have that function. I could have sworn it did but was like ok whatever and trusted the guy. He said there’s an aftermarket kit you can buy to do that so I went on Amazon and bought the pop & lock kit with the Tacoma specific wiring harness and stuff.
    I go and take apart the tailgate cover and go to install it and realize it already has it installed (a little annoyed the tech didn’t bother to check even though I asked and he supposedly did) So I’m guessing the dealer I bought it from (in another state than where I am now) must have installed it as a dealer add on and I’m not crazy and misremembering my truck having that functionality at one point.
    I figured I already had the new part so I swapped out everything but the actual long wire going from the tailgate under the truck to the cab (I swapped the actuator and wiring harness inside the cab for the new ones) hoping that this would help fix it however it still doesn’t lock or unlock with the key fob.
    Any ideas what could be the issue here? The fob still works for the regular doors just not the tailgate.
  2. Apr 26, 2022 at 3:28 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You're going to have to trace wires. I bet wherever they tied it in to the door power, it was done with a cheap butt or t-tap and it's worked it's way loose.
    shakerhood and Cavemanclay1[OP] like this.
  3. Apr 26, 2022 at 3:30 PM
    Cavemanclay1
    2020 TRD OR DCSB
    Thanks for the suggestion. I’ll check that out after work and hopefully it’s a quick find and solution
  4. Apr 26, 2022 at 3:37 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I think you already know the answer!
  5. Apr 26, 2022 at 3:51 PM
    TendererBeef
    TendererBeef Member
    2018 Cement TRD Off Road
    Cavemanclay1[OP] likes this.
  6. Apr 26, 2022 at 4:24 PM
    Froth
    Froth Well-Known Member
    fred
    2016 taco
    Usually the tailgate lock goes underneath the passenger seat and is either plug n play, or spliced by the side panel.....you can also unplug the blue and green wires at the lock itself and just attempt to trip the solenoid to lock and unlock....if that works plug back in and go to the passenger door and do the same with the wires disconnected from the truck itself...that way you know the wiring is good.....but before you do anything hit the unlock button twice, if its wired to the passenger side it will need two instead of just a single unlock...I have installed 5 of these kits, and just finished the Toyota version on a 22.....
  7. Apr 26, 2022 at 4:40 PM
    Cavemanclay1
    2020 TRD OR DCSB
    Are you 100% on passenger side? The one already installed on mine went to driver side and the instructions with the new kit said to run it to the driver said
  8. Apr 26, 2022 at 4:47 PM
    TendererBeef
    TendererBeef Member
    I definitely did mine on the passenger side.
    piratepegleg likes this.
  9. Apr 26, 2022 at 6:31 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Toyota instructions for pre 2019 state drivers side and connect in the drivers side footwell. On this forum many go passenger side. I have not looked at any instructions since then and around 2020 Toyota did change some of the wiring, so it may well be passenger side now.
  10. Apr 26, 2022 at 6:38 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    My ‘19 ran up the passenger side, through the unused grommet hole under the passenger seat then plug and play under the passenger side kick panel.
  11. Apr 26, 2022 at 6:38 PM
    Froth
    fred
    2016 taco
    Screen Shot 2022-04-26 at 6.44.54 PM.jpg Mine was wired to the passenger side on the 22, I wired my 16, 17 also to the passenger side.....the only real difference is when you go to unlock, the drivers side is one unlock, the passenger side is 2.....I should have looked at the drivers side connectors as I just add a break glass....Note: this is for the factory harness, you would just use the existing grommet for a different kit, like the pop n lock.
  12. Apr 26, 2022 at 7:00 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Mine was also on the passenger side.
