Pop Lock tailgate wiring question..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chadabear, Apr 2, 2018.
  1. Apr 2, 2018 at 8:39 AM
    chadabear
    chadabear [OP] Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    2018 DCSB...wanted to know which wires were designated for the rear door locks?? I wanted to be able to hit the button twice to lock and unlock tailgate, instead of it locking and unlocking at the first hit of my remote..been trying to locate any info or a schematic, but not having any luck
  2. Apr 2, 2018 at 8:54 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Green and Red wire on the top connector in the front passenger side kick plate area. Green to green of the pop and lock, red to blue of the pop and lock.
    chadabear[OP] likes this.
  3. Apr 2, 2018 at 8:59 AM
    OdiN1701
    Colorado
  4. Apr 2, 2018 at 9:00 AM
    OdiN1701
    Colorado
    He says green to red and blue to green - now I can't remember which one I did. But if it's backwards it will lock when you unlock and unlock when you lock so it's easy to know and you just flip them.
  5. Apr 2, 2018 at 10:17 AM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    Thanks a bunch man, going to get that hooked up this evening
  6. Apr 2, 2018 at 10:46 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Just installed mine this weekend! green to green and blue to red
    chadabear[QUOTED][OP] likes this.
  7. Apr 2, 2018 at 10:48 AM
    OdiN1701
    Colorado
    Yeah I think there were some of the pop and lock units that were backwards wired. Who knows.
  8. Apr 2, 2018 at 10:52 AM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    So yours operate from the rear door locks? You have to hit your remore 2 times to activate/deactivate it?
  9. Apr 2, 2018 at 10:52 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    not sure, i set my truck to unlock all doors with one click
  10. Apr 2, 2018 at 12:34 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Follow that video instructions and you will be all set for the passenger door unlock. Do yourself a favor and double check that it's right before you put the panel back on your tailgate. I did it just like the video but I guess my pop lock was wired backwards. I didn't catch it until everything was buttoned up and then had to take the panel off and switch the wires. :annoyed:
  11. Apr 2, 2018 at 12:37 PM
    OdiN1701
    Colorado
    Same here but I do have to hit the fob button twice.
  12. Apr 2, 2018 at 12:44 PM
    CortezJB
    CortezJB Well-Known Member
    Juan
    San Francisco
    2017 Tacoma TRD Sport
    NADA
    I found on my 2017 Sport, that I could connect the actuator to the rear left door, (driver side post left of the driver),
    in there you will find 2 pink wires with a green and a red line. I connected my tail gate actuator there. When I unlock the truck, first touch, the front driver side door unlocks, at the second touch the other doors open including the tail gate.
    When locking, one touch locks everything, inckuding tailgate.
    Operate tail gate before closing everything to make sure it is working. If when testing the conection is closing when it should be opening, just switch the wires at the driver side post and try again.
    I hope the picture helps.
  13. Apr 2, 2018 at 12:48 PM
    OdiN1701
    Colorado
    I think the passenger side of the vehicle is easier for running wires, just my thoughts on that.
  14. Apr 2, 2018 at 12:55 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    agreed, i ran the line up under the passenger seat too. didn't take it all the way to the engine bay made it much easier
