Pop & Lock Troubles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sdwf, Feb 21, 2021.
  1. Feb 21, 2021 at 3:37 PM
    sdwf
    sdwf [OP] Well-Known Member
    2016 Tacoma Sport 4x4 DCSB
    Bought mine in 2018 for my 2016. Worked great till now. Will lock but not unlock. Appears that the actuator will not fully compress to move the locking lever into the unlock position.
    Anyone have any luck with any other brand of product?
  2. Feb 21, 2021 at 4:37 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I had a similar issue, try spraying grease into the back of the locking mechanism. That worked for me.
    go to 3:27 in this video. Hope it helps.
    https://youtu.be/XJY1fBrTf38
  3. Feb 21, 2021 at 4:51 PM
    sdwf
    Thanks! Just finished the video. Have been sub'd to your YouTube channel for some time now, just hadn't gotten around to watching the Mountain Hatch install yet. What your actuator was doing is exactly the same as mine. I had taken my Mountain Hatch off this afternoon to try and figure out what was going on. Will try WD-40 tomorrow! Thanks again!
    ClassyTacos likes this.
  4. Feb 21, 2021 at 5:18 PM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Seems to be common. Mine has been exhibiting the same behavior for a few months now. Only hangs while unlocking.
  5. Feb 21, 2021 at 5:23 PM
    Lunabird
    Lunabird Well-Known Member
    I’ve had the same problem with my 2017. I ended up finding a replacement actuator from aliexpress for under $10. If you don’t want to wait a month for shipping, pop and lock sells the actuator but are way more pricy $50ish
    Also try realigning the rails of the pop&lock. I found that helped a lot.
  6. Feb 21, 2021 at 5:27 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    I fixed this issue with mine earlier today by spraying silicone lubricant on everything that moves in the tailgate.
  7. Feb 21, 2021 at 5:40 PM
    Slideeslide
    Slideeslide Member
    Yup, needs lube. Especially creeps up in the cold.
  8. Feb 22, 2021 at 2:15 PM
    sdwf
    Lubed the pop & lock up, works like a champ! Thanks @ClassyTacos!
  9. Feb 22, 2021 at 4:58 PM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    No, worries. Glad it helped.
