Pop n lock info needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by igno1tus, Aug 6, 2017.
  1. Aug 7, 2017 at 3:37 PM
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
    I have the powered one on my truck (Pop & Lock PL8521 Power Tailgate Lock). Install was very easy and the convenience of having a power lock is very nice. Plus, you keep all your original hardware so that the handle is sturdy and factory. My only recommendation for the install would be to run an extra wire down the frame with the pop & lock one so you can install bed lights later down the road.
    Norton likes this.
  2. Aug 11, 2017 at 10:33 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This is EXACTLY what I did, splicing into the PASSENGER SIDE wiring to reduce the number of cycles on the mechanism.
  3. Aug 12, 2017 at 3:29 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I have the dynolock electric for 8 years and it works great. The actuator did come loose once and jam the latch and I had to go back in and repair it... new screws and some glue. To be safe when I got a tonneau I got one with an external key lock (Pace Edwards Jackrabbit) so I can access the tailgate inside if the electric actuator ever again jams. Alternatively, if you get a tonneau with an inside release I would run a hidden emergency release cable out under the bed.
    http://www.dynoproducts.net/locks/dynolock/dyno-elelock.htm
  4. Aug 13, 2017 at 9:13 PM
    nocturne
    nocturne Well-Known Member
    Erin
    San Antonio NM
    2015 TRD Off-Road
    Bone stock
    How much does the pop and lock handle throw off the back up camera?
  5. Aug 18, 2017 at 9:51 AM
    loco usmc
    loco usmc Well-Known Member
    Gabriel
    Houston
    2014 4X4 DCSB trd offroad
    None at all
  6. Aug 18, 2017 at 11:53 AM
    igno1tus
    igno1tus [OP] Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Well got it in , works good I like it .
    Norton likes this.
  7. Aug 22, 2017 at 12:14 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    To those who have the power one. All the reviews says its loud. How loud is it? I mean will people standing nearby think my truck is a POS or is it a locking sound. If it sounds horrible and broke every time i will cringe. But I like the idea of having a key and power so if one fails the other works. Would you do it again or go with just a standard locking handle
  8. Aug 22, 2017 at 11:13 PM
    Norton
    Unfortunately, it's easily heard and does not sound good. The mechanism is sounds like dry metal pieces grating together when actuated, and lubrication seems to have no effect. All of that said, I'd do it again for the convenience of knowing it's locked whenever my truck is.
