Pop n Lock not unlocking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caduceus, Mar 13, 2015.
  1. Mar 13, 2015 at 3:25 PM
    Caduceus
    Caduceus [OP] Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Anyone have this problem?
    Fortunately I have a soft tonneau and was able to fold it up, thus use the truck bed. Hasn't unlocked in a week, with either the key or alarm fob. I can hear the actuator making noise with the lock/unlock, but not physically unlocking.
    Ideas?
    Edit:
    Update on post 10.
  2. Mar 15, 2015 at 1:56 PM
    Caduceus
    in the Bluegrass
    09 DCSB TRD 4x4
    Nobody?
  3. Mar 15, 2015 at 1:58 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Have you opened the tailgate cover to see where it's binding?
  4. Mar 15, 2015 at 2:00 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Try WD40 and work the key back and forth if that doesn't work inspect for lose parts of bindings parts
  5. Mar 15, 2015 at 2:02 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    probably isn't able to if the lock isn't working ;)
  6. Mar 15, 2015 at 2:12 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Pull off the tailgate cover and see what isn't working. It could be a couple different things. The actuator may not be moving far enough. Something may have bent.
  7. Mar 15, 2015 at 6:31 PM
    theredofshaw
    this. wd-40 can gunk up on you.
  8. Mar 15, 2015 at 7:37 PM
    Caduceus
    in the Bluegrass
    09 DCSB TRD 4x4
    Thanks for the link.
    So update, I was able to remove the screws on the upper side of the tailgate plastic, remove the top piece, the flex the plastic enough to slide my hand in and move the bar.
    Not sure what isnt working. Once the tailgate cover was off I could watch the lock move with the lock button (and key), but no joy with the unlock. Nothing appears bent or binding.
    For now I just pulled the power connection. Will contact the company this week and see what they can do.
