Pop n lock not unlocking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FranksGotTacos, Sep 27, 2019.
  1. Sep 27, 2019 at 9:24 PM
    FranksGotTacos
    FranksGotTacos [OP] donkey
    SB
    Denver
    16 DCSB. Geared, Dual Locked, 35s, Topperlift, wet AF
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, cab and bed cap, Outgear solutions rear bumper, custom swingout. 35's. Icon rebound pros x 5, OME BP-51s. Topper ez lift. Decked. Full RCI full skids, misting system with 4 gal plumbed into 270 ironman awning, air plumbed to all 4 corners + decked, DK upper shear kit, Marlin LCA brace kit, 10 pc rock light kit, scene pods, u bolt flip, stage 3 deavers, poly bushings all around, archive garage hammer hangars, sumo springs rears, TC gusseted spindles, spiker hood struts, aux beam 8 gang, 50 watt solar on top of 2x pelican cases, Cascadia 4x4 mppt solar charge controller, jackery 1000, alpicool 45L fridge. Rear seat delete with fridge slide on passenger side (by me). Meso overhead rack, Meso cab, dome, rear interior lights, Meso x morrimoto tail lights. CVJ high angle boots,
    I got the pop n lock installed and it worked for a few months. Then all of a sudden it will no longer unlock my tailgate.
    I contacted Pop n Lock and they sent me a new actuator. Install it, and it works for a week then same symptoms, no unlock. It locks great, but unlocks about 1 out of 20 times.
    Has this happend to anyone else? Anyone have suggestions?
  2. Sep 27, 2019 at 9:36 PM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    I've used them for over 3 years without a problem. How are you splicing into the wires?
  3. Sep 27, 2019 at 9:46 PM
    FranksGotTacos
    SB
    Denver
    I tapped into the Passenger side foot well just as they recommend. The only difference is that I also put a T-tap that runs to my bed cap for that actuator so I can lock my cap as well. I tapped into the wire right below the tailgate and ran it up to the control box inside the cap.
    I figured that it draws such little power It shouldn't effect the PnLs operation. I am going to pull the quick connects on the bed cap actuator and see what happens
    Jdairy and El Chivo Norteño like this.
  4. Sep 28, 2019 at 1:12 AM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    I had to disconnect mine last winter when it stopped working. I had it open and watched as the actuator no longer flipped the lever. It would try but couldn't do it. I thought it needed a little alignment, but no matter how it was positioned it didn't work. Haven't looked at it since and just have it floating in my tailgate.
    Does it sound like your's tries to close everytime?
  5. Sep 28, 2019 at 3:41 AM
    sabotanker
    sabotanker Well-Known Member
    Lee
    Coastal Georgia
    19 OR DCSB 4x4
    I have the opposite problem...pop n lock works every time but the cap unlocks when it damn well pleases. locks every damn time, though
  6. Sep 28, 2019 at 4:27 AM
    IsotopeGear
    IsotopeGear Member
    Jim
    2019 Tacoma Off Road (Cement)
    Do you have a multimeter? You can 1) check for continuity and then, 2) see if current is getting to the actuator? I have read of others having issues with splices and intermittent "power" sounds like that to me. You might repair/reconnect the splice (solder). I plugged directly into the harness (solder wire end from Pop & Lock to make stiff and just plug into harness slot (with some dielectric grease - see pic). Then I ran a pigtail with a plug at the end that was pretty easy and gets around splicing. If there is an issue I just unplug. The black/red connectors are Anderson powerpoles (used in HAM radio/Ecomms).
    [​IMG] [​IMG]
    Siblue likes this.
  7. Sep 28, 2019 at 5:56 AM
    FranksGotTacos
    SB
    Denver
    Yup it tries and it is loud in its trying. When I opened it up its like the throw of the actuator leaves it right in the middle of the unlock process. It has enough throw to lock, not enough to unlock.
    When will Meso just make us one that works?
  8. Sep 28, 2019 at 5:58 AM
    FranksGotTacos
    SB
    Denver
    Great advice. Thanks man! I will give that a try today.
  9. Sep 28, 2019 at 12:26 PM
    sabotanker
    Lee
    Coastal Georgia
    19 OR DCSB 4x4
    KTJO 4x4 likes this.
  10. Sep 28, 2019 at 12:35 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Try lubricating the moving parts both at the lock and latches.
    pkshooter_ and Deathdealer like this.
  11. Sep 28, 2019 at 12:38 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    At circuit isn’t designed for that much current. You’re running 3 actuators. You’ll need to wire up an additional relay to boost the power
    D.A.S. Taco, nartmot and hfjeff like this.
  12. Sep 28, 2019 at 12:55 PM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    What all did you do here? I have a plug-n-play Harness I sell so you don’t have to tap into OEM Wiring. I know popnlock unfortunately makes it so people still have to tap into their factory wiring. :/
    I’m sorry to hear about your issues with the Actuator. Unfortunately, with some trucks I have found out that some Actuators with certain trucks and other Actuators don’t. I haven’t been able to explain why yet. If you send me a address I can send you an Actuator to try out and see if it will fix your issue with this style free of charge. Send me a PM with your info and just remind of the situation because it will get in the masses of PMs. I’d love to help you out and get this squared away. If this doesn’t work I have one other Actuator I will suggest to you after.
  13. Sep 28, 2019 at 1:35 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    If everyone had a FREE harbor freight multimeter, we would’ve have any TW electronic questions.
    TomTwo likes this.
  14. Sep 28, 2019 at 1:37 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It’s called a Pop ‘n Lock not Pop ‘n Unlock. :anonymous:
  15. Sep 28, 2019 at 1:38 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    True, but the battery died in mine. Now I need a free battery from Radio Shack...
    Siblue[QUOTED] likes this.
  16. Sep 28, 2019 at 2:02 PM
    hastingsrussell
    hastingsrussell Well-Known Member
    Russell
    Allen, TX.
    2016 Tacoma TRD Sport
    Pretty stock for now
    I had the same problem a few months when I installed mine. I took it apart and saw the actuator not engaging all the way so I added a zip tie to the actuator to make it bigger and it has been going strong now for at least 3 years.
    bagleboy likes this.
  17. Sep 28, 2019 at 2:22 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’ve found it often to be the case that things don’t work as they should but with a bit of ingenuity can be made right. It shouldn’t be this way but I’d rather deal with it and get it to work than spend my time getting someone else to if possible.
  18. Sep 29, 2019 at 6:19 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I had the problem of mine not locking. I slipped a piece of rubber hose over the actuator to make it bigger.
    Eventually the rubber hose fell off and it stopped working again.
    The next time, I figured out how to bend the metal tab to give it a little more throw.
  19. Sep 29, 2019 at 7:20 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    When you said doesn't open, does it make a sound or nothing at all?
    Could just be connections. Did you give it some slack at the rear? Maybe it's pulling and has too much tension where the tailgate moves? Just a thought.
  20. Sep 29, 2019 at 12:56 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Is it for the cap or tailgate? The caps sometimes need to have the cable tension adjusted to work properly and I'd bet that the tailgate rods can be diddled to work better as well. My Snugtop wouldn't latch/unlatch properly on the driver's side until I tightened the cable on it.
