Pop n lock not unlocking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FranksGotTacos, Sep 27, 2019.
  1. Sep 29, 2019 at 1:04 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound and Truckin
    Totaled 2012 TRD Sport, 2013 TRD Double Cab Sport
    True and True, .......Mine lasted about 3 years and then locked me out of my bed with my hard bed cover closed took me about an hour to break into my own truck.......:annoyed:......... I said screw it and put my OEM latch back on.
    D.A.S. Taco and MannyS like this.
  2. Sep 30, 2019 at 6:32 AM
    FranksGotTacos
    FranksGotTacos [OP] Well-Known Member
    SB
    16 DCSB. Geared, Locked, 35s,
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, Outland rear bumper. true 35's. OME BP-51s. Topper ez lift. Decked. full RCI skids
    This assumes that I know how to read a multimeter. I leave all the electrical to qualified people, I stick to fabrication
  3. Sep 30, 2019 at 10:09 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It's not rocket science.
    1B4C74D4-2DCD-4253-92A1-59D24B920F97_zps_cab4bf16e5e5e1ea70ce206899960741774a2c68.jpg
    TomTwo likes this.
  4. Sep 30, 2019 at 11:39 AM
    FranksGotTacos
    SB
    Yeah neither is welding but people that have never touched a stinger have no idea what to do with it. I have never messed with a multimeter hence it would be foreign to me
    TomTwo likes this.
  5. Sep 30, 2019 at 12:07 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The difference though is that welding requires special skills but a reading a meter doesn’t. There’s no “technique” and nothing produced but information, just turn the knob and stick the probes. Seriously, a tv remote takes way more effort to learn. All you need to know can be learned in an hour. Yes the subject has great depth but using a meter just touches on the surface stuff.
    Tacodelphia likes this.
  6. Sep 30, 2019 at 1:28 PM
    FranksGotTacos
    SB
    I get it bagelboy, you are smarter than me! I would add emojis to try to show you that I am joking around but I cant figure that out either
    bagleboy[QUOTED] likes this.
  7. Mar 3, 2020 at 5:37 PM
    ClassyTacos
    ClassyTacos I must know whats on page 47
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
  8. Mar 3, 2020 at 5:39 PM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    Does the actuator sound like it's working? I had to lube the parts up VERYY well after a few months. Works great now
  9. Mar 4, 2020 at 8:00 AM
    FranksGotTacos
    SB
    yeah I did the same, lubed it like crazy and it works way better. A little wd40 solved my problem
  10. Mar 4, 2020 at 8:04 AM
    FranksGotTacos
    SB
    Nice vid. I put some lube in mine that seems to help that spring from binding and getting stuck. It hasnt stopped working on me since I lubed it.
  11. Mar 8, 2020 at 9:27 PM
    yaycolin
    yaycolin Well-Known Member
    Colin
    Orange County, CA
    2016 4x4 White DCLB Sport
    King 2.5 CO, Total Chaos UCA
    Have any pictures?
  12. Mar 15, 2020 at 6:50 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I would like to see a pic of the zip tie fix as well. So far working well.
  13. Apr 4, 2020 at 3:37 PM
    tmclaughlin1
    tmclaughlin1 New Member
    Tim
    Charlottesville, VA
    2016 Tacoma Dark Grey TRD Off Road
    PopNLock tailgate lock
    Thanks to FranksGotTacos! WD40 solved my unlock issue!
  14. Sep 28, 2020 at 7:24 PM
    Jdairy
    Jdairy Member
    Jed
    '18 TRD Off Road
    none
    Does anyone know if there is another location to tap into besides the passenger side? Do the same wires exist on the driver's side?
  15. Sep 28, 2020 at 7:49 PM
    #35
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Toyota sells an OEM complete plug and play. I had zero problems with mine. The actuator is different from the pop n lock and better built from what I can see. Just in case someone is throwing the towel on the PnL and wants to try the OEM.
  16. Sep 28, 2020 at 8:02 PM
    #36
    Jdairy
    Jdairy Member
    Jed
    '18 TRD Off Road
    none
    The pop and lock was working great until I added the actuator for the topper to it. It's not enough power though to run them both. So I'm more just looking for just another, different spot to draw power from for the topper.
  17. Jan 15, 2023 at 12:13 PM
    #37
    AvaTaco
    AvaTaco Member
    Reisterstown, MD
    '18 TRD Sport Barcelona Red
    I have had continuous problems with mine. I had to put graphite in the lock cylinder and lithium grease on the actuator. Mine recently started to chatter and not move at all. I have disconnected it as it is becoming more of a headache than using the key.
    I have used a meter to determine that I am getting 6 volts at the harness tap, at the tailgate removal connector and at the actuator itself. Even hooked the actuator directly to the tap and it did the same thing. If i get another, it will be the factory one. Mine last just long enough to get out of warranty.
  18. Oct 12, 2023 at 6:42 PM
    #38
    Rigz22
    Rigz22 Well-Known Member
    California
    2019 tacoma sport 4x4
    Had mine for less than a year and it stopped working. It doesn’t lock anymore
    Disappointed with this item
  19. Oct 12, 2023 at 7:25 PM
    #39
    dietcokefiend
    dietcokefiend Well-Known Member
    Why does the aftermarket item exist with splices when the OEM kit exists in the first place? Is it really to save a few bucks?
  20. Oct 13, 2023 at 4:01 AM
    #40
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The aftermarket lock was available long before there was an OEM option.
