Pop n lock on a 3rd gen with JBL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FirstTacoma!!, Apr 1, 2017.
  1. Apr 1, 2017 at 3:31 PM
    FirstTacoma!!
    FirstTacoma!! [OP] Well-Known Member
    Austin
    2017 TRD OFF ROAD
    PRO GRILLE, RIGID FOG LIGHTS, Katzkin leather, TRD skid plate, LED conversion throughout, Toyota love.
    IMG_7114.jpg Hey guys, not sure if the JBL matters but here we go.
    I have installed a 8535 popnlock for my Tacoma OR. 2017. I cannot seem to splice the wires properly. To be clear, I am 90% sure i installed everything correctly.
    In the tail gate. The green to green and blue to blue. Short harness to long harness. And finally for the passenger side electrical input.
    Green to green.
    Blue to red.
    Does anyone know of a better wire splicer? My fingers are killing me.
    Thank you
    Rus$ likes this.
  2. Apr 1, 2017 at 3:32 PM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
  3. Apr 1, 2017 at 3:46 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
  4. Apr 1, 2017 at 3:47 PM
    RIDERED67
    Aren't you supposed to tap the wires in the black connector? It's been while since I did it
  5. Apr 1, 2017 at 3:57 PM
    T6A1C9O
    San Diego, CA
    It's the red and green wire in whatever connector is in the top left of the inside of that main connector block.
  6. Apr 1, 2017 at 4:00 PM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    I'm about to install mine and also read to tap from black connector.
  7. Apr 1, 2017 at 4:00 PM
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    You need to use lineman's pliers to push the metal part in the connectors, otherwise it will not work.
    FirstTacoma!![OP] likes this.
  8. Apr 1, 2017 at 4:03 PM
    Tacuache345
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I did mine yesterday.
  9. Apr 1, 2017 at 4:15 PM
    T6A1C9O
    San Diego, CA
    Here's a pic of mine. This setup is if you want it in sync with the passenger doors.
  10. Apr 1, 2017 at 4:19 PM
    FirstTacoma!!
    Austin
    2017 TRD OFF ROAD
    Thank you everyone. This is a pain to get it with the clips that come with the kit. I will tackle this to,or row after I pick up some better clips
  11. Apr 1, 2017 at 4:57 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Don't use clips! Solder the wires, you'll be happier in the long run. I soldered mine (JBL here) and it works perfectly.
    Solder the wires FTW! I don't believe in cheapo wiring taps that can/will fail over time.
  12. Apr 1, 2017 at 5:41 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    I recommend Planet Rock for pop n locking on the JBL system.
  13. Apr 1, 2017 at 7:11 PM
    FirstTacoma!!
    Austin
    2017 TRD OFF ROAD
    Did anyone figure out a way to make the wires fit through the tailgate and the bed to fit nicely??
  14. Apr 1, 2017 at 7:15 PM
    FirstTacoma!!
    Austin
    2017 TRD OFF ROAD
    My tap is gray like yours. Why are others saying black??
    UPDATE: I think this is because I opted for the passenger side route.
  15. Apr 1, 2017 at 9:06 PM
    HV_Taco
    HV_Taco Well-Known Member
    MJ
    Copeland Forest, Canada
    2016 Inferno TRD
    Still Stock but working on changing that fast
    I did. I unraveled the factory loom going through to the tailgate. It's a small plastic loom inside a bigger plastic loom. I stripped the insulation off the pop and lock wire leaving me with just the red and blue wires. I ran these two wires in with the factory wires and re-loomed everything back as it came. Looks factory.
    rlj251 and bruce316 like this.
  16. Apr 2, 2017 at 8:48 AM
    Tacuache345
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I did the same but witouth stripping the insulation.
  17. Apr 3, 2017 at 8:06 PM
    FirstTacoma!!
    Austin
    2017 TRD OFF ROAD
    Thanks everyone! It was the wire splicers. It works like a charm now, don't know why people keep saying it makes such a loud noise. The tailgate is hollow and will make a clump. No insulation
  18. Apr 4, 2017 at 8:09 AM
    HV_Taco
    MJ
    2016 Inferno TRD
    The only noise i really here besides the locking mechanism is the metal on the P&L rattling when i slam the tailgate closed.
  19. Apr 4, 2017 at 10:17 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Huh the taps that come with the kit are super simple to use, used them for years. Clip over existing wire, slide new wire in to the stop, crimp metal clip down with pliers, clamp plastic cover, done.
  20. Apr 4, 2017 at 2:05 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Not sure how many have already agreed with this but he's right. Using T taps is easy and it can work but, it's not the right or best way to so this. Strip back wire and solder your connection, use electrical tape to protect your connection and your good to go.
    That's what the proffesuonals do and it's not difficult.
    No offence to all of you who are choosing not to solder.
    airborndad and mrkabc[QUOTED] like this.
