Pop-n-lock vs OEM tailgate lock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ScotWithOne_t, Oct 22, 2024.
  1. Oct 23, 2024 at 7:51 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    It's noticeably louder than the actuators for the cab doors. To me, it doesn't matter. Its not like you'll need ear plugs when you operate it ...
    As I posted previously, when it clunks, I know it's working. Not a big deal to me.
    Watch Chloe's review and install. The noise it makes can be heard over the "beeps". Judge for yourself.
    https://youtu.be/5h2Z6PBE2hQ?si=aszUfdvBhkxbib9y
  2. Oct 23, 2024 at 7:53 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    You might be able to hear it on PNL reviews on YouTube. Kinda similar to power lock on old cars, remember the lock pops up when unlocking and goes down when locking that had sound coming out of the door? That's how PNL does. I think it locks so fast which is why it's loud.
    It's up to you to get either PNL or OEM lock. It's your truck.
    dcmsideshow[QUOTED] likes this.
  3. Oct 23, 2024 at 8:08 AM
    dcmsideshow
    dcmsideshow Well-Known Member
    Dan
    Arvada, CO
    2019 Toyota Tacoma TRD Off-Road
    Eibach suspension; Deaver Springs; Black Rhino wheels; Toyo tires; RSI SmartCap
    Great video, thanks for sharing. I now officially don't care about the noise. ;-)
    TAZMINATOR likes this.
  4. Oct 23, 2024 at 8:37 AM
    HeyB
    HeyB Well-Known Member
    2022 TRD OR DCLB
    I put the OEM lock in my '22. It works great.
    I put the PnL in my '11. It worked great for 11 years (and probably still works fine.)
    I've got a slight preference for the OEM since it's a fused factory harness (not taps) and works on passenger door - which means it's actuated much less frequently. Also noticed a bunch less metal, more plastic on the current PnL that the one I installed in '11, but I'm sure it's still just fine.
    One bonus w/the OEM (and maybe the PnL too?), you can use a sealed T-connector for the OEM harness just outside of the tailgate, and tap that to actuate an additional solenoid for a tonneau or cap lock. Works like a charm on my Leer. It feels like magic when you can un/lock everything in one go without ever touching a key or fob. So convenient...
  5. Oct 23, 2024 at 9:55 AM
    ScotWithOne_t
    ScotWithOne_t [OP] Active Member
    Scot
    Twin Cities, MN
    Red 2023 TRD Sport
    Ordered the PnL kit from Amazon
    https://www.amazon.com/dp/B08T59YR22?ref=ppx_yo2ov_dt_b_fed_asin_title
    I'll hopefully install this weekend. Selling point for me is that it is not direct coupled, like the OEM kit, so using a physical key if the actuator craps out is still possible.
    I doubt the noise will bother me.
    Anyone know if the wiring harness is the same on the passenger side? I know the OEM one can be hooked into the passenger side, which is nice to have the option if don't want it unlocking every time I get in the vehicle....but it will lock every time anyway, so it's only saving half the actuations/wear and tear.
  6. Oct 23, 2024 at 1:01 PM
    ULURU
    Never looked into it, but I imagine the harness you tie into is different, and therefore the t-harness provided with the kit may not be plug and play...
  7. Oct 23, 2024 at 1:52 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    This. After experiencing both Oem and PNL...
    Why would anyone buy a cheaper version of the Oem Lock?
    (especially the pop n lock with its poor record and loud operation.)
    Its like the people that buy used electrical parts, a crap shoot for a 20 dollar savings.
  8. Oct 23, 2024 at 3:49 PM
    ULURU
    Is there an OEM part for all third gens? I was under the impression that the electronic tailgate lock was a later addition to the run... (but I imagine it could still be backward compatible?)
  9. Oct 23, 2024 at 5:20 PM
    TAZMINATOR
    2017 Tacoma
    Mine is a PNL which is connected on passenger side.
  10. Oct 24, 2024 at 4:45 AM
    crockett8513
    crockett8513 Member
    Good luck, let us know how it goes. I went OEM last year and haven't looked back.
    BillF1564 likes this.
  11. Oct 24, 2024 at 8:16 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    It's also worth noting that you can plug it on either side and not just the drivers side. While the initial instructions refer to installing it on the drivers side, connecting it on the passenger side makes it so the tailgate only unlocks/locks when the passenger door lock is clicked on/off. Now, having written all that, for me, even that was not good enough! I am not a construction worker, so I do not need my tailgate to be constantly locking/unlocking, every time I unlock the door to get in. SO, after looking a little, I learned that PopNLock actually offers a rocker switch that you can mount anywhere, that you can connect the cabling to from the tailgate lock, so that the tailgate is locked/unlocked only by hitting the rocker switch either way. I actually made a video on this when I did it to my 2019. I mounted the switch on the lower left bottom of the dash panel, and it actually looks like it came that way with the truck. By the way, initially, the tailgate did not even have the option of a power tailgate lock, and then it became only available to the southeastern US dealers. I actually ordered mine from a Toyota dealer in NC! When I got it, it was actually a genuine PopNLock only with a Toyota part number on it, added to the original popnlock bag. So no doubt about it, the two are the same. Here is a link to my video where I show how I installed it. I am not monetized, so this is only to help my fellow tacoma owners! https://youtu.be/9qeKhgnc3UI
    ULURU and TAZMINATOR like this.
  12. Oct 24, 2024 at 11:27 AM
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    I ordered the R4T kit and it's also PnP. Can't attest to how loud it is compared to OEM or PnL though but I can definitely hear the clunk when locking it. It isn't a huge deal for me though but I've had it for about 2 years so far and no issues. It's so awesome not having to manually lock and unlock my tailgate.. should've came from the factory this way
  13. Oct 24, 2024 at 4:09 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I just installed the pop n loc and I am very happy to be able to lock/unlock tailgate with the doors remotely. It is loud …. But you know it worked. ONe thing I noticed that after about 5 minutes the truck self locks. Maybe this has always been the case but with the new tailgate lock I hear it.
  14. Oct 24, 2024 at 5:03 PM
    MGMDesertTaco
    Yes.
    PK3B6-35JS0 is for the dcsb 5ft bed and the access cab tacoma's.
    PK3B6-35JL0 is for the dclb 6ft bed tacoma's.
    MagicToolbox[QUOTED] likes this.
  15. Oct 25, 2024 at 8:24 AM
    #35
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I installed the OEM kit on my '23 DCLB a few months ago. Installation was easy and it works great. Yes, you can still use the key to lock/unlock
  16. Oct 25, 2024 at 10:38 AM
    #36
    ULURU
    Re: Truck self-locking... I haven't testing my theories, but I believe that if you exit the vehicle by simply pulling the driver's door handle, and walk away, it will self-lock. Now, if you unlock all the doors with the power lock switch, the truck's doors will remain unlocked. Not sure if you need to have the door open when you press "unlock", though...
    I have been able to leave my truck unlocked overnight, and then some, when I am up at my farm.
    Looks like a good science experiment.
  17. Oct 25, 2024 at 10:52 AM
    #37
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    OEM All The Way!
  18. Oct 25, 2024 at 11:11 AM
    #38
    TAZMINATOR
    2017 Tacoma
    The truck has timer for the self lock. Mine does same thing. If you don't want that, you can change it via settings in head unit or OBD2 kit with app. But I don't remember if it has feature to allow to change self lock settings since self lock is a security feature. So far I know, the app can allow you to change turn signal from 3 to 5 which means it blinks 5 times then stops.
    That time, my truck was only months old, I didn't get all information that time on what the truck has. So, I remember I opened the door and get something then closed it but I know I didn't lock it, I went out back by tailgate to discuss with a girl... then went back to driver door to open but it's locked, I was like fuk, did you lock it? She said no I don't have keys with me. I looked up online and realized it has auto lock. I was like oh great.
  19. Oct 25, 2024 at 12:05 PM
    #39
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    I've had the pop n lock on my 2020 for 4 years and it works flawlessly. So nice being able to lock and unlock the tailgate with the FOB.
  20. Oct 26, 2024 at 3:35 AM
    #40
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I added the PnL to mine 4 or 5 years ago, and wired it to the passenger doors. Not a single issue in that time. Only time I think about it, is when I want to remove the tailgate...
