pop n lock wont let me open my tail gate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by delrayrasta, Jun 6, 2010.
  1. Jun 6, 2010 at 10:46 AM
    delrayrasta
    delrayrasta [OP] Well-Known Member
    Paul
    Delray Beach, FL
    2011 4X4 TRD OFF ROAD
    pro comp stage II lift kit, retro projection HID headlight and fog, bullbar, bed cover and afe S dry intake.
    i've had it for a few month and had it installed by the guys at 4wheelpart, it worked fine but always kinda stuck a little. Now it just wont even open, if i'm lucky and push my tail gate in the right way i might be able to open it. does anyone know or have any advise on what i should do? i'm thinking of just reverting to the oem part just to not deal with it anymore.
  2. Jun 6, 2010 at 11:33 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    x2...On the mechanical pop 'n lock you may have to use the extensions that it comes with. On my '06 tailgate I didn't have to use them. It's very easy to install, just take off the tailgate skin and take a look at it.
  3. Jun 6, 2010 at 11:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you try to put the key in it and cycle the lock? Perhaps spray some lubrication in the lock - something might be stuck in half locked position?
    Just guessing..... I have one but haven't had any problems with it in 2 years.
  4. Jun 6, 2010 at 12:14 PM
    delrayrasta
    Paul
    Delray Beach, FL
    it was weird cause they installed it in like a couple min (i didn't actually see them doing it) and then gave me the box and just my old handle. i didn't get anything else so maybe they did install the extenders but idk.
    its not locked cause i tried some wd 40 on it and putting the key in it and locking/unlocking it so thats fine. like i lift the handle and sometimes hear one click, i think it might be releasing one side and not the other but it feels like both are still stuck.
    should i go to the toyota dealer ship or to 4wheelparts where i got it installed?
    thank you guys for the advice.
    p.s its the manual one not the electric one.
  5. Jun 6, 2010 at 12:37 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Try applying pressure to the gate like you're closing it, at the same time lift the the handle. The latches might be binding. If that works? take apart the gate and remove those plastic extenders.
    Good luck!
  6. Jun 6, 2010 at 12:40 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If it doesn't work I'd got to the guy that installed it and while you are at it I'd ask to look over his shoulder. They will probably give you some BS about insurance in the work bay but it's worth a shot. There really isn't much to it. If you don't get any satisfaction try it yourself and follow the instructions that came with it.
  7. Jun 12, 2010 at 3:23 PM
    MJonesTrumpet
    MJonesTrumpet Well-Known Member
    Michael
    Central PA
    I have the same problem, or at least similar. I had one on my old tacoma, and I loved it. I got one for my 2009 maybe 6 months ago, with the back up cam so i had to wait like 6 months to get it. Anyway, it NEVER felt right, and i did put the extenders on. With my old one, I could leave the thing unlocked if i wanted to, this one, I can't. Like, I cant get my key out unless i start to turn it to locking...and its like, half locked, half not. and when you pull the handle it just like missed and then is locked. My problem is when you turn the key to unlock it, the handle wont lift quite right and it turns a bit...it always opened, until yesterday. I had to freaking unbolt the backing and manually pop the lock. I looked around, tinkered, and it looks like the spring is crappy. I'm debating on getting a different brand, or just getting another pop n lock and hoping that this one was just a dud....has anyone else had that problem? Is anyone else fully capable of leaving their tailgate completely unlocked with a 2009 with a back up cam?
  8. Jun 12, 2010 at 4:54 PM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    I have an 09 and my Pop n Lock used to lock itself every time i closed the tail gate, they have a replacement spring to fix the problem.
    Call Pop n Lock ( 1-800-342-5911) and tell them you need the upgraded spring for the PL5300 maybe it will help.
    I installed the new spring last week and so far it works fine.
    Denis
  9. Jul 8, 2010 at 3:41 PM
    eguiney
    eguiney Member
    Houston Tx
    09 Prerunner Double Cab
    I had the exact same problem. The issue is that the lock is so poorly made that the whole unit flexes when you pull the handle so that the lever cannot move the mechinism that pulls the rods that unlock the tailgate. Since the unit was installed and used, the return policy from Autoanything only gave me the option to have the piece of junk replace with a duplicate piece of junk.
  10. Jul 8, 2010 at 6:13 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I've had one installed on my 06 for about 4 years now. From day 1 it made the latch a little tougher to open, but hasn't gotten any worse over time. If I try to slowly open it, it won't open, but if I give it a solid pop, it'll open every time. Maybe that'll solve your problem.
  11. Sep 2, 2010 at 6:07 AM
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    mine has the same problem. i had to push the tailgate in and then really pop it open. took about 3 tries. now it's broken completely and i can't open my tailgate! any suggestions? by the way, i have a tonneau that opens from the underside!
