Pop up (Palomino ) camper
Discussion in 'Tonneau Covers, Caps and Shells' started by CK49, Jan 11, 2017.
  1. Jan 11, 2017 at 7:45 AM
    CK49
    CK49 [OP] New Member
    2017 Tacoma Sport
    Non
    Hi, just wondering if anyone has put a pop-up,slide-in camper on their 2016-17 Tacoma? As I bought the truck with the intention of doing just that. Now I hear the truck won't handle the weight.
  2. Jan 13, 2017 at 4:07 AM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
    Forget the Palomino and opt for either a FWC or ATC shell model, which will be less than 850 lbs with a single lead acid battery installed. You'll still need to do some suspension upgrades. Both FWC and ATC use welded aluminum frame construction.
    https://www.allterraincampers.com/Shell
    The shell models are rather spartan - but any added luxuries to include a forced air heater, fridge, stove or hot water heater just add weight.
    The ATC Bobcat as far as I know needs a 6 foot bed. The FWC Swift fits a 5 foot bed and they do make a Fleet model for the 6 foot bed.
    http://www.fourwh.com/product/empty-shell-model-popup-truck-camper/
  3. Jan 13, 2017 at 5:59 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Another lightweight option that allows you to build out the intererior as you want is the Tacoma Habitat from Adventure Trailers. It's not self contained and it's not going to be as warm as a slide in though.
    http://adventuretrailers.com/campers/toyota-habitat/
  4. Jan 14, 2017 at 5:48 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
