Popcorn sound coming from under shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kindler, Jan 19, 2020.
  1. Jan 19, 2020 at 11:40 AM
    Kindler
    Kindler [OP] New Member
    2014 Tacoma 5-speed
    Popcorn sound when driving. Just started. Sounds like an air popper. Still happens when coasting in neutral, as well as in drive. Any suggestions? Thanks in advance.
  2. Jan 19, 2020 at 11:43 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    :popcorn:
    Sorry man...got nothing else.
    Curious though.
  3. Jan 19, 2020 at 1:47 PM
    Kindler
    2014 Tacoma 5-speed
    I discovered it only happens in 4wd. So I’m thinking it’s a problem with the transfer case. That make sense?
  4. Jan 19, 2020 at 1:55 PM
    Muddinfun
    Muddinfun Well-Known Member
    Grease the front driveshaft U joints and see if the noise changes.
    Kindler[OP] likes this.
  5. Jan 19, 2020 at 1:56 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  6. Jan 19, 2020 at 2:52 PM
    Muddinfun
    U joints typically make a click, clack, click, clack, or a squeak, squawk, squeak, squawk sound when you are driving real slow. The driveshaft turns almost 4 times faster than the wheels and as the U joint bends, it usually makes noise every 180 degrees of rotation. The result is a noise with a frequency almost 8 times faster than the tire rotation.
    R242 and Kindler[OP] like this.
  7. Jan 19, 2020 at 3:32 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Crawl under truck and remove the nylon tie-wrap(s) your prankster buddy put on the front driveshaft
  8. Jan 19, 2020 at 6:15 PM
    Taco'09
    Taco'09 Well-Known Member
    Just throwing darts here but perhaps the air relief valve on either the transmission or transfer case is burping due to the valve partially clogged, or too much gear oil and it is expanding. ToyMoCo has a newish bulletin out specifically focusing in these and says to replace them whenever the transmission/transfer is pulled. They must have had a number of reported problems.
  9. Jan 20, 2020 at 1:06 AM
    Kindler
    2014 Tacoma 5-speed
    Thanks everyone. Bought a grease gun, crawled under in this lovely 10 degree weather. Greased the u joints. Problem solved! Thanks muddinfun!
    Muddinfun and EdgemanVA like this.
  10. Jan 20, 2020 at 9:16 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    you have damaged them already with lack of grease
    grease will only help for a while
    JC15Taco, Jimmyh and Muddinfun like this.
